[Release]battery meter for the framework LEDmatrix (win11)
I just released FW16-BatteryMatrix — a little tray app that turns your Framework 16’s LED matrix into a beautiful real-time battery display.
Features:
  • Shows exact battery percentage on the 9×34 matrix
  • If WMI works on your system, you also get a smooth scrolling pulse line that moves up (charging) or down (discharging) — speed reacts to your actual charge/discharge rate
  • Right-click the tray icon to:
    • Change COM port (defaults to COM3)
    • Adjust brightness (±10)
  • Runs completely silently in the background (no console window)
  • Want debug output? Just add --console to a shortcut or run it from PowerShell/CMD
I’ve included both:
  • A compiled .exe (ready to run on Windows 11)
  • Full source code (batt4.py) if you want to compile it yourself or modify it
Would love a few people to test it on their machines and let me know how it goes — especially if you’re on different Windows versions, have WMI quirks, or use a different COM port.
This is my first real public application, so any feedback, suggestions, or bug reports are super welcome!
The compiled .exe is broken. It’s looking for a python .dll in the downloads folder. I had to compile it from source to get it to work. I added the option “–onefile” and it seems to not require the .dll.
Once I got it working, it looks great, but it does need a console window open to continue running.
