There is a guide for the WiFi card replacement on the FW 13, can we get one for the FW 16 as well? Including a list of compatible WiFi cards would also be nice. Thanks!
Well you do not need a Replacement Guide. I installed the AX210 nonVpro during initial Build of my diy.
Its 1 screw a bracket and to antenna connectors. And when the input deck is go e its literally 30seconds to swap it.
The incompatibility list is basically anything intel that doesn’t have a 0 at the end and the be200 (that may or may not get fixed in a future agesa update).
And 2 antenna connectors straight from hell XD
damn i missed some Letters while typing my last message on my phone
The two Antenna Connectors where easy with the spatula end of the FW screwdriver
