Nope! I didn’t know there was an alternative fix.
I’m testing out a variant of it based on the pre-existing System76 “No Headphone Mic” quirk:
diff --git a/sound/pci/hda/patch_realtek.c b/sound/pci/hda/patch_realtek.c
index 4c0c593f3c0a..54442ec36af9 100644
--- a/sound/pci/hda/patch_realtek.c
+++ b/sound/pci/hda/patch_realtek.c
@@ -7012,6 +7012,7 @@ enum {
ALC245_FIXUP_CS35L41_SPI_4,
ALC245_FIXUP_CS35L41_SPI_4_HP_GPIO_LED,
ALC285_FIXUP_HP_SPEAKERS_MICMUTE_LED,
+ ALC295_FIXUP_FRAMEWORK_LAPTOP_MIC_NO_PRESENCE,
static const struct hda_fixup alc269_fixups[] = {
@@ -8806,6 +8807,15 @@ static const struct hda_fixup alc269_fixups[] = {
.chained = true,
.chain_id = ALC285_FIXUP_HP_MUTE_LED,
+ [ALC295_FIXUP_FRAMEWORK_LAPTOP_MIC_NO_PRESENCE] = {
+ .type = HDA_FIXUP_PINS,
+ .v.pins = (const struct hda_pintbl[]) {
+ { 0x19, 0x01a1913c }, /* use as headset mic, without its own jack detect */
+ .chained = true,
+ .chain_id = ALC269_FIXUP_HEADSET_MODE_NO_HP_MIC
static const struct snd_pci_quirk alc269_fixup_tbl[] = {
@@ -9294,6 +9304,7 @@ static const struct snd_pci_quirk alc269_fixup_tbl[] = {
SND_PCI_QUIRK(0x8086, 0x2074, "Intel NUC 8", ALC233_FIXUP_INTEL_NUC8_DMIC),
SND_PCI_QUIRK(0x8086, 0x2080, "Intel NUC 8 Rugged", ALC256_FIXUP_INTEL_NUC8_RUGGED),
SND_PCI_QUIRK(0x8086, 0x2081, "Intel NUC 10", ALC256_FIXUP_INTEL_NUC10),
+ SND_PCI_QUIRK(0xf111, 0x0001, "Framework Laptop", ALC295_FIXUP_FRAMEWORK_LAPTOP_MIC_NO_PRESENCE),
#if 0
/* Below is a quirk table taken from the old code.
I’m seeing a little bit of trouble where the headset mic doesn’t report the right levels after coming out of sleep. However, connecting to the NO_HP_MIC quirk chain feels appropriate. The pinmux config in the above patch is based on the dell-headset-multi one without the headphone mic.
I will of course look at your pinctl as well.
