Im running Fedora 39 with both the gnome and kde desktop environments. When I change the display settings (either explicitly in the settings or connecting a second display) the screen goes white with only the mouse present. In the journal, I get the errors:
Jan 30 11:47:16 <user> kwin_wayland[3353]: This plugin does not support raise()
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bd4000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc8000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc7000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc6000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc5000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc4000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc3000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc2000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc1000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amdgpu 0000:c1:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffd2bc0000 flags=0x0000]
Jan 30 11:47:15 <user> kernel: amd_iommu_report_page_fault: 46055 callbacks suppressed
Jan 30 11:47:13 <user> kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
Jan 30 11:47:11 <user> kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
Heres some details of my build:
chip: AMD 7640U
kernel version: Kernel: x86_64 Linux 6.6.13-200.fc39.x86_64
bios version: 03.03
I’ve noticed this was an issue with the intel chips, however I’m running AMD so the fixes therein don’t apply to me.
This is quite the issue for me because I do presentations and such and so I need to frequently connect multiple displays, but this issue completely prevents me.
Thanks for any help.
