OS: Fedora Linux 39 (Workstation Edition) x86_64
Host: Laptop 16 (AMD Ryzen 7040 Series)
Kernel: 6.8.4-200.fc39.x86_64
CPU: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics (16) @ 5.423GHz
GPU: AMD ATI Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600
Since getting my laptop I have had many problems with my graphics on linux(none of which are present on windows).
I think that my problems lie with my graphics drivers somehow but I know they are included in the kernel/fedora by default.
when I try to run games, blender, or any benchmark I get VERY poor performance even with DRI_PRIME=1 option set.
I tried running glmark2 with DRI_PRIME set and the framework dgpu utility said it was being used but performance was still much less than expected.
Things get even more confusing when I run vulkaninfo | grep "GPU[0123]" -A 10 because it only displays llvmpipe and doesn’t even include my igpu.
this is all I get out of that command:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 1.3.267 (4206859)
driverVersion = 0.0.1 (1)
vendorID = 0x10005
deviceID = 0x0000
deviceType = PHYSICAL_DEVICE_TYPE_CPU
deviceName = llvmpipe (LLVM 17.0.6, 256 bits)
pipelineCacheUUID = 32332e33-2e36-6161-6161-616161616161
Why isn’t this displaying my other gpu devices?
also worth noting that when I run nvtop I get ‘No GPU to monitor.’
Any info would be great! thanks!
