Hi! I’m using OpenSUSE with Gnome on an AMD Framework and I want to enable airplane mode on lid close (and disable on open). I only found some search results on how to prevent that behaviour, but none to enable it.
My settings in the Gnome power settings are very basic, do they clash with /etc/systemd/logind.conf settings? That file doesn’t exist for me, is it even considered?
Thanks!
I love this idea, however we are not actively testing against OpenSUSE at this time.
That said, you could do a:
sudo find /etc/systemd -name "*logind*"
To see where it is as the path may differ.
As far as going into airplane mode, scripting this would be easiest I suspect. Using rfkill block all and unblock all is the least painful approach. Perhaps even create a custom systemd service; something sort of like:
[Unit]
Description=Script to run when laptop lid is closed/opened
[Service]
Type=oneshot
ExecStart=/path/lid-trigger-script.sh
[Install]
WantedBy=multi-user.target
I don’t have the cycles to build this out now for testing, but it “could” be doable on supported distros like Fedora or Ubuntu LTS.
I got it to work by installing acpid and creating
# /etc/acpi/events/lidconf
# run a script on lid open/close events
event=button/lid
action=/etc/acpi/actions/lid.sh "%e"
and
# /etc/acpi/actions/lid.sh
state=$(echo "$1" | cut -d " " -f 3)
case "$state" in
open)
# do what needs to be done when the lid is opened
# I almost never use bluetooth, so I'll enable it manually.
rfkill unblock wifi
close)
# do what needs to be done when the lid is closed
rfkill block all
# panic: not a state I know about!
echo "PANIC STATE" >> /var/logs/lidaction.log
esac
EDIT: I had a bug, the branches were switched. It’s fixed now.
Nicely done and thanks for sharing this with the community.
