[RESPONDED] AMD battery empty overnight
Like several other people, the battery of my framework sometimes runs empty overnight, presumably because it does not remain suspended. This doesn’t always happen, so it’s hard to pinpoint, but it did happen the last couple of nights.
I’m on OpenSUSE Tumbleweed, so I know I can’t get official support, but it would be great if someone were able to point me in the right direction how to troubleshoot this.
My journalctl contains entries around 20:36 (when I last closed my laptop), 22:25 and 9:10. The next entry after this is me booting the framework at 9:45 at which point the battery was empty.
What may or may not be interesting is that I think 22:25 and 9:10 corresponds to two times when I handled my framework (put it into its sleeve, put it into my bag), without opening it. Is there a chance that this could have woken it from suspend (by e.g. registering as a touchpad press?).
These are the entries around 20:36:
20:36:01 systemd-logind[1369]: Lid closed.
20:36:01 kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
20:36:01 systemd-logind[1369]: The system will suspend now!
20:36:01 NetworkManager[1577]: <info>  [1707852961.9434] manager: sleep: sleep requested (sleeping: no  enabled: yes)
20:36:01 ModemManager[1517]: <info>  [sleep-monitor-systemd] system is about to suspend
20:36:01 NetworkManager[1577]: <info>  [1707852961.9435] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
20:36:01 NetworkManager[1577]: <info>  [1707852961.9439] manager: NetworkManager state is now ASLEEP
20:36:01 NetworkManager[1577]: <info>  [1707852961.9440] device (wlp1s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
20:36:01 plasmashell[8201]: [8196:8220:0213/203601.944600:ERROR:connection_factory_impl.cc(471)] ConnectionHandler failed with net error: -2
20:36:01 kded5[2060]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
20:36:01 kernel: wlp1s0: deauthenticating from f8:0d:a9:10:40:8b by local choice (Reason: 3=DEAUTH_LEAVING)
20:36:02 NetworkManager[1577]: <info>  [1707852962.2546] device (wlp1s0): supplicant interface state: completed -> disconnected
20:36:02 NetworkManager[1577]: <info>  [1707852962.2549] device (wlp1s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
20:36:02 avahi-daemon[1347]: Withdrawing address record for fe80::a985:953:6396:fefb on wlp1s0.
20:36:02 avahi-daemon[1347]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::a985:953:6396:fefb.
20:36:02 avahi-daemon[1347]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
20:36:02 plasmashell[2116]: plasma-pk-updates: Is net mobile: false
20:36:02 plasmashell[2116]: plasma-pk-updates: Is net online: false
20:36:02 plasmashell[2116]: plasma-pk-updates: Daemon changed
20:36:02 plasmashell[2116]: packagekitqt.offline: Cannot process "org.freedesktop.PackageKit" as "org.freedesktop.PackageKit.Offline"
20:36:02 NetworkManager[1577]: <info>  [1707852962.3302] dhcp4 (wlp1s0): canceled DHCP transaction
20:36:02 NetworkManager[1577]: <info>  [1707852962.3302] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
20:36:02 NetworkManager[1577]: <info>  [1707852962.3303] dhcp4 (wlp1s0): state changed no lease
20:36:02 avahi-daemon[1347]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
20:36:02 avahi-daemon[1347]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.39.
20:36:02 avahi-daemon[1347]: Withdrawing address record for 192.168.1.39 on wlp1s0.
20:36:02 NetworkManager[1577]: <info>  [1707852962.3901] device (wlp1s0): set-hw-addr: set MAC address to D2:1E:89:F8:E8:D3 (scanning)
20:36:02 avahi-daemon[1347]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.39.
20:36:02 avahi-daemon[1347]: New relevant interface wlp1s0.IPv4 for mDNS.
20:36:02 avahi-daemon[1347]: Registering new address record for 192.168.1.39 on wlp1s0.IPv4.
20:36:02 avahi-daemon[1347]: Files changed, reloading.
20:36:02 avahi-daemon[1347]: No service file found in /etc/avahi/services.
20:36:02 NetworkManager[1577]: <info>  [1707852962.5417] device (wlp1s0): supplicant interface state: disconnected -> interface_disabled
20:36:02 NetworkManager[1577]: <info>  [1707852962.5418] device (wlp1s0): supplicant interface state: interface_disabled -> disconnected
20:36:02 NetworkManager[1577]: <info>  [1707852962.5421] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
20:36:02 chronyd[1678]: Source 81.172.225.142 offline
20:36:02 chronyd[1678]: Source 213.239.154.12 offline
20:36:02 chronyd[1678]: Source 5.39.184.5 offline
20:36:02 chronyd[1678]: Can't synchronise: no selectable sources
20:36:02 chronyd[1678]: Source 162.159.200.123 offline
20:36:02 dns-dnsmasq.sh[10935]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
20:36:02 NetworkManager[1577]: <info>  [1707852962.6651] device (wlp1s0): set-hw-addr: reset MAC address to 14:AC:60:29:8C:31 (unmanage)
20:36:02 systemd[1]: Reached target Sleep.
20:36:02 systemd[1]: Starting System Suspend...
20:36:02 systemd-sleep[10957]: INFO: Skip running /usr/lib/systemd/system-sleep/grub2.sleep for suspend
20:36:02 dns-dnsmasq.sh[10959]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
20:36:02 systemd-sleep[10944]: Entering sleep state 'suspend'...
20:36:02 kernel: PM: suspend entry (s2idle)
20:36:02 kernel: Filesystems sync: 0.030 seconds
20:36:02 dns-dnsmasq.sh[10980]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit```
These are the entries around 22:25:
22:25:33 kernel: Freezing user space processes
22:25:33 kernel: Freezing user space processes completed (elapsed 0.001 seconds)
22:25:33 kernel: OOM killer disabled.
22:25:33 kernel: Freezing remaining freezable tasks
22:25:33 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
22:25:33 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
22:25:33 kernel: queueing ieee80211 work while going to suspend
22:25:33 kernel: ACPI: EC: interrupt blocked
22:25:33 kernel: ACPI: EC: interrupt unblocked
22:25:33 kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x6b on isa0060/serio0).
22:25:33 kernel: atkbd serio0: Use 'setkeycodes 6b <keycode>' to make it known.
22:25:33 kernel: atkbd serio0: Unknown key released (translated set 2, code 0x6b on isa0060/serio0).
22:25:33 kernel: [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
22:25:33 kernel: [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
22:25:33 kernel: [drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
22:25:33 kernel: amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=4
22:25:33 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
22:25:33 kernel: amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
22:25:33 kernel: amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
22:25:33 kernel: [drm] ring gfx_32790.1.1 was added
22:25:33 kernel: [drm] ring compute_32790.2.2 was added
22:25:33 kernel: [drm] ring sdma_32790.3.3 was added
22:25:33 kernel: [drm] ring gfx_32790.1.1 ib test pass
22:25:33 kernel: [drm] ring compute_32790.2.2 ib test pass
22:25:33 kernel: [drm] ring sdma_32790.3.3 ib test pass
22:25:33 kernel: OOM killer enabled.
22:25:33 kernel: Restarting tasks ... done.
22:25:33 kernel: random: crng reseeded on system resumption
22:25:33 plasmashell[8201]: [8196:8220:0213/222533.077277:ERROR:connection_factory_impl.cc(428)] Failed to connect to MCS endpoint with error -106
22:25:33 kernel: PM: suspend exit
22:25:33 systemd-sleep[10995]: INFO: Skip running /usr/lib/systemd/system-sleep/grub2.sleep for suspend
22:25:33 bluetoothd[1504]: Controller resume with wake event 0x0
22:25:33 systemd-sleep[10944]: System returned from sleep state.
22:25:33 systemd[1]: Started Timeline of Snapper Snapshots.
22:25:33 systemd[1]: Daily man-db regeneration was skipped because of an unmet condition check (ConditionACPower=true).
22:25:33 systemd[1]: systemd-suspend.service: Deactivated successfully.
22:25:33 systemd[1]: Finished System Suspend.
22:25:33 systemd[1]: snapper-timeline.service: Deactivated successfully.
22:25:33 systemd[1]: Stopped target Sleep.
22:25:33 systemd[1]: Reached target Suspend.
22:25:33 systemd[1]: Stopped target Suspend.
22:25:33 systemd-logind[1369]: Operation 'sleep' finished.
22:25:33 ModemManager[1517]: <info>  [sleep-monitor-systemd] system is resuming
22:25:33 NetworkManager[1577]: <info>  [1707859533.2237] manager: sleep: wake requested (sleeping: yes  enabled: yes)
22:25:33 NetworkManager[1577]: <info>  [1707859533.2240] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
22:25:33 kdeconnectd[2309]: Error sending UDP packet: QAbstractSocket::NetworkError
22:25:33 NetworkManager[1577]: <info>  [1707859533.2882] device (wlp1s0): set-hw-addr: set MAC address to 3E:E4:24:24:37:04 (scanning)
22:25:33 NetworkManager[1577]: <info>  [1707859533.3446] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
22:25:33 NetworkManager[1577]: <info>  [1707859533.3448] manager: NetworkManager state is now DISCONNECTED
22:25:33 NetworkManager[1577]: <info>  [1707859533.3771] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
22:25:33 NetworkManager[1577]: <info>  [1707859533.3772] device (p2p-dev-wlp1s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
22:25:33 NetworkManager[1577]: <info>  [1707859533.3776] Wi-Fi P2P device controlled by interface wlp1s0 created
22:25:33 NetworkManager[1577]: <info>  [1707859533.3779] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/7)
22:25:33 NetworkManager[1577]: <info>  [1707859533.3780] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
22:25:33 NetworkManager[1577]: <info>  [1707859533.3784] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
22:25:33 NetworkManager[1577]: <info>  [1707859533.3789] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
22:25:34 kernel: nvme nvme0: 16/0/0 default/read/poll queues
22:25:35 ModemManager[1517]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:01:00.0': not supported by any plugin
22:25:36 NetworkManager[1577]: <info>  [1707859536.0309] policy: auto-activating connection 'TMNL-10408A' (58625e14-a62f-4696-9861-8bdd615069e5)
22:25:36 NetworkManager[1577]: <info>  [1707859536.0313] device (wlp1s0): Activation: starting connection 'TMNL-10408A' (58625e14-a62f-4696-9861-8bdd615069e5)
22:25:36 NetworkManager[1577]: <info>  [1707859536.0314] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
22:25:36 NetworkManager[1577]: <info>  [1707859536.0316] manager: NetworkManager state is now CONNECTING
22:25:36 NetworkManager[1577]: <info>  [1707859536.0902] device (wlp1s0): set-hw-addr: reset MAC address to 14:AC:60:29:8C:31 (preserve)
22:25:36 NetworkManager[1577]: <info>  [1707859536.1581] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
22:25:36 NetworkManager[1577]: <info>  [1707859536.1584] device (wlp1s0): Activation: (wifi) access point 'TMNL-10408A' has security, but secrets are required.
22:25:36 NetworkManager[1577]: <info>  [1707859536.1584] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
22:25:36 NetworkManager[1577]: <info>  [1707859536.1586] sup-iface[ace9c018dd7bacb3,4,wlp1s0]: wps: type pbc start...
22:25:36 NetworkManager[1577]: <info>  [1707859536.1592] device (wlp1s0): supplicant interface state: disconnected -> interface_disabled
22:25:36 NetworkManager[1577]: <info>  [1707859536.1592] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> interface_disabled
22:25:36 plasmashell[2116]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
22:25:36 NetworkManager[1577]: <info>  [1707859536.1703] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
22:25:36 kded5[2060]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
22:25:36 NetworkManager[1577]: <info>  [1707859536.1705] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
22:25:36 NetworkManager[1577]: <info>  [1707859536.1710] device (wlp1s0): Activation: (wifi) connection 'TMNL-10408A' has security, and secrets exist.  No new secrets needed.
22:25:36 NetworkManager[1577]: <info>  [1707859536.1711] Config: added 'ssid' value 'TMNL-10408A'
22:25:36 NetworkManager[1577]: <info>  [1707859536.1711] Config: added 'scan_ssid' value '1'
22:25:36 NetworkManager[1577]: <info>  [1707859536.1712] Config: added 'bgscan' value 'simple:30:-65:300'
22:25:36 NetworkManager[1577]: <info>  [1707859536.1712] Config: added 'key_mgmt' value 'SAE FT-SAE'
22:25:36 NetworkManager[1577]: <info>  [1707859536.1713] Config: added 'auth_alg' value 'OPEN'
22:25:36 NetworkManager[1577]: <info>  [1707859536.1713] Config: added 'psk' value '<hidden>'
22:25:36 NetworkManager[1577]: <info>  [1707859536.1714] Config: added 'ieee80211w' value '2'
22:25:36 plasmashell[2116]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/3”"
22:25:36 NetworkManager[1577]: <info>  [1707859536.1809] device (wlp1s0): supplicant interface state: interface_disabled -> inactive
22:25:36 NetworkManager[1577]: <info>  [1707859536.1810] device (p2p-dev-wlp1s0): supplicant management interface state: interface_disabled -> inactive
22:25:36 kernel: wlp1s0: authenticate with f8:0d:a9:10:40:8a (local address=14:ac:60:29:8c:31)
22:25:36 NetworkManager[1577]: <info>  [1707859536.2510] device (wlp1s0): supplicant interface state: inactive -> authenticating
22:25:36 NetworkManager[1577]: <info>  [1707859536.2511] device (p2p-dev-wlp1s0): supplicant management interface state: inactive -> authenticating
22:25:36 kernel: wlp1s0: send auth to f8:0d:a9:10:40:8a (try 1/3)
22:25:36 NetworkManager[1577]: <info>  [1707859536.3221] device (wlp1s0): supplicant interface state: authenticating -> associating
22:25:36 NetworkManager[1577]: <info>  [1707859536.3222] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
22:25:36 kernel: wlp1s0: authenticated
22:25:36 kernel: wlp1s0: associate with f8:0d:a9:10:40:8a (try 1/3)
22:25:36 kernel: wlp1s0: RX AssocResp from f8:0d:a9:10:40:8a (capab=0x1c11 status=0 aid=19)
22:25:36 kernel: wlp1s0: associated
22:25:36 kernel: wlp1s0: Limiting TX power to 30 (30 - 0) dBm as advertised by f8:0d:a9:10:40:8a
22:25:36 NetworkManager[1577]: <info>  [1707859536.4211] device (wlp1s0): supplicant interface state: associating -> associated
22:25:36 NetworkManager[1577]: <info>  [1707859536.4212] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
22:25:36 NetworkManager[1577]: <info>  [1707859536.5109] device (wlp1s0): supplicant interface state: associated -> 4way_handshake
22:25:36 NetworkManager[1577]: <info>  [1707859536.5110] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> 4way_handshake
22:25:36 NetworkManager[1577]: <info>  [1707859536.6124] device (wlp1s0): supplicant interface state: 4way_handshake -> completed
22:25:36 NetworkManager[1577]: <info>  [1707859536.6125] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "TMNL-10408A"
22:25:36 NetworkManager[1577]: <info>  [1707859536.6125] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake -> completed
22:25:36 NetworkManager[1577]: <info>  [1707859536.6303] device (wlp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
22:25:36 NetworkManager[1577]: <info>  [1707859536.6310] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
22:25:36 avahi-daemon[1347]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::a985:953:6396:fefb.
22:25:36 avahi-daemon[1347]: New relevant interface wlp1s0.IPv6 for mDNS.
22:25:36 avahi-daemon[1347]: Registering new address record for fe80::a985:953:6396:fefb on wlp1s0.*.
22:25:36 NetworkManager[1577]: <info>  [1707859536.6665] dhcp4 (wlp1s0): state changed new lease, address=192.168.1.39
22:25:36 NetworkManager[1577]: <info>  [1707859536.6671] policy: set 'TMNL-10408A' (wlp1s0) as default for IPv4 routing and DNS
22:25:36 avahi-daemon[1347]: Files changed, reloading.
22:25:36 avahi-daemon[1347]: No service file found in /etc/avahi/services.
22:25:36 avahi-daemon[1347]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.39.
22:25:36 avahi-daemon[1347]: New relevant interface wlp1s0.IPv4 for mDNS.
22:25:36 avahi-daemon[1347]: Registering new address record for 192.168.1.39 on wlp1s0.IPv4.
22:25:36 NetworkManager[1577]: <info>  [1707859536.6824] device (wlp1s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
22:25:36 chronyd[1678]: Forward time jump detected!
22:25:36 chronyd[1678]: Source 81.172.225.142 online
22:25:36 chronyd[1678]: Source 213.239.154.12 online
22:25:36 chronyd[1678]: Source 162.159.200.123 online
22:25:36 chronyd[1678]: Source 5.39.184.5 online
22:25:36 dns-dnsmasq.sh[11019]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
22:25:36 NetworkManager[1577]: <info>  [1707859536.7761] device (wlp1s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
22:25:36 NetworkManager[1577]: <info>  [1707859536.7763] device (wlp1s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
22:25:36 NetworkManager[1577]: <info>  [1707859536.7768] manager: NetworkManager state is now CONNECTED_SITE
22:25:36 NetworkManager[1577]: <info>  [1707859536.7773] device (wlp1s0): Activation: successful, device activated.
22:25:36 dns-dnsmasq.sh[11055]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
22:25:36 dns-dnsmasq.sh[11075]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
22:25:37 NetworkManager[1577]: <info>  [1707859537.1058] manager: NetworkManager state is now CONNECTED_GLOBAL
22:25:37 plasmashell[2116]: plasma-pk-updates: Is net mobile: false
22:25:37 plasmashell[2116]: plasma-pk-updates: Is net online: true
22:25:37 plasmashell[2116]: plasma-pk-updates: Daemon changed
22:25:37 plasmashell[2116]: packagekitqt.offline: Cannot process "org.freedesktop.PackageKit" as "org.freedesktop.PackageKit.Offline"
22:25:37 dns-dnsmasq.sh[11094]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
22:25:37 kernel: ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
22:25:41 chronyd[1678]: Selected source 5.39.184.5 (0.opensuse.pool.ntp.org)
22:25:41 chronyd[1678]: System clock wrong by 1.260788 seconds
22:25:42 chronyd[1678]: Selected source 81.172.225.142 (0.opensuse.pool.ntp.org)
22:25:45 irqbalance[1351]: Cannot change IRQ 73 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 73 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 63 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 63 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 71 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 71 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 114 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 114 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 68 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 68 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 66 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 66 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 74 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 74 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 64 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 64 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 72 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 72 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 62 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 62 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 70 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 70 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 113 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 113 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 69 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 69 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 67 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 67 affinity is now unmanaged
22:25:45 irqbalance[1351]: Cannot change IRQ 65 affinity: Input/output error
22:25:45 irqbalance[1351]: IRQ 65 affinity is now unmanaged
22:25:47 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
22:25:47 systemd[1]: NetworkManager-dispatcher.service: Consumed 1.565s CPU time.
22:25:50 PackageKit[10448]: daemon quit
22:25:50 systemd[1]: packagekit.service: Deactivated successfully.
22:26:08 kdeconnectd[2309]: new capabilities for  "XQ-BT52"
22:26:08 plasmashell[2116]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
22:26:08 plasmashell[2116]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/FullRepresentation.qml:37:23: QML DeviceDelegate: Binding loop detected for property "h>
22:26:33 systemd[1]: snapperd.service: Deactivated successfully.
22:26:47 chronyd[1678]: Selected source 213.239.154.12 (0.opensuse.pool.ntp.org)
22:27:33 dbus-daemon[1348]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=2171 comm="/usr/libexec/org_kde_powerdevil") (us>
22:27:33 dbus-daemon[1348]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
22:28:57 chronyd[1678]: Selected source 81.172.225.142 (0.opensuse.pool.ntp.org)
22:30:42 kernel: wlp1s0: disconnect from AP f8:0d:a9:10:40:8a for new auth to f8:0d:a9:10:40:8b
22:30:42 kernel: wlp1s0: authenticate with f8:0d:a9:10:40:8b (local address=14:ac:60:29:8c:31)
22:30:43 kernel: wlp1s0: send auth to f8:0d:a9:10:40:8b (try 1/3)
22:30:43 NetworkManager[1577]: <info>  [1707859843.0078] device (wlp1s0): supplicant interface state: completed -> authenticating
22:30:43 NetworkManager[1577]: <info>  [1707859843.0078] device (p2p-dev-wlp1s0): supplicant management interface state: completed -> authenticating
22:30:43 kernel: wlp1s0: authenticate with f8:0d:a9:10:40:8b (local address=14:ac:60:29:8c:31)
22:30:43 kernel: wlp1s0: authenticated
22:30:43 kernel: wlp1s0: associate with f8:0d:a9:10:40:8b (try 1/3)
22:30:43 NetworkManager[1577]: <info>  [1707859843.0728] device (wlp1s0): supplicant interface state: authenticating -> associating
22:30:43 NetworkManager[1577]: <info>  [1707859843.0729] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
22:30:43 kernel: wlp1s0: RX ReassocResp from f8:0d:a9:10:40:8b (capab=0x1911 status=0 aid=19)
22:30:43 kernel: wlp1s0: associated
22:30:43 NetworkManager[1577]: <info>  [1707859843.1725] device (wlp1s0): supplicant interface state: associating -> associated
22:30:43 NetworkManager[1577]: <info>  [1707859843.1725] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
22:30:43 kernel: wlp1s0: Limiting TX power to 30 (30 - 0) dBm as advertised by f8:0d:a9:10:40:8b
22:30:43 NetworkManager[1577]: <info>  [1707859843.2378] device (wlp1s0): supplicant interface state: associated -> completed
22:30:43 NetworkManager[1577]: <info>  [1707859843.2381] device (wlp1s0): ip:dhcp4: restarting
22:30:43 NetworkManager[1577]: <info>  [1707859843.2382] dhcp4 (wlp1s0): canceled DHCP transaction
22:30:43 NetworkManager[1577]: <info>  [1707859843.2382] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
22:30:43 NetworkManager[1577]: <info>  [1707859843.2382] dhcp4 (wlp1s0): state changed no lease
22:30:43 NetworkManager[1577]: <info>  [1707859843.2383] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
22:30:43 NetworkManager[1577]: <info>  [1707859843.2384] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> completed
22:30:43 NetworkManager[1577]: <info>  [1707859843.2794] dhcp4 (wlp1s0): state changed new lease, address=192.168.1.39
22:30:43 dbus-daemon[1348]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid>
22:30:43 systemd[1]: Starting Network Manager Script Dispatcher Service...
22:30:43 dbus-daemon[1348]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
22:30:43 systemd[1]: Started Network Manager Script Dispatcher Service.
22:30:43 dns-dnsmasq.sh[11169]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
22:30:53 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
22:34:57 kernel: i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
22:35:33 kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
22:35:33 systemd-logind[1369]: The system will suspend now!
22:35:33 ModemManager[1517]: <info>  [sleep-monitor-systemd] system is about to suspend
22:35:33 NetworkManager[1577]: <info>  [1707860133.2470] manager: sleep: sleep requested (sleeping: no  enabled: yes)
22:35:33 NetworkManager[1577]: <info>  [1707860133.2471] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
22:35:33 NetworkManager[1577]: <info>  [1707860133.2474] manager: NetworkManager state is now ASLEEP
22:35:33 NetworkManager[1577]: <info>  [1707860133.2475] device (wlp1s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
22:35:33 plasmashell[8201]: [8196:8220:0213/223533.248297:ERROR:connection_factory_impl.cc(471)] ConnectionHandler failed with net error: -2
22:35:33 kded5[2060]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
22:35:33 dbus-daemon[1348]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid>
22:35:33 systemd[1]: Starting Network Manager Script Dispatcher Service...
22:35:33 dbus-daemon[1348]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.31' (uid=1000 pid=2116 comm="/usr/b>
22:35:33 systemd[1]: Starting PackageKit Daemon...
22:35:33 PackageKit[11202]: daemon start
22:35:33 dbus-daemon[1348]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
22:35:33 systemd[1]: Started Network Manager Script Dispatcher Service.
22:35:33 kernel: wlp1s0: deauthenticating from f8:0d:a9:10:40:8b by local choice (Reason: 3=DEAUTH_LEAVING)
22:35:33 dbus-daemon[1348]: [system] Successfully activated service 'org.freedesktop.PackageKit'
22:35:33 systemd[1]: Started PackageKit Daemon.
22:35:33 plasmashell[2116]: plasma-pk-updates: Is net mobile: false
22:35:33 plasmashell[2116]: plasma-pk-updates: Is net online: false
22:35:33 plasmashell[2116]: plasma-pk-updates: Daemon changed
22:35:33 NetworkManager[1577]: <info>  [1707860133.6332] device (wlp1s0): supplicant interface state: completed -> disconnected
22:35:33 NetworkManager[1577]: <info>  [1707860133.6334] device (wlp1s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
22:35:33 avahi-daemon[1347]: Withdrawing address record for fe80::a985:953:6396:fefb on wlp1s0.
22:35:33 NetworkManager[1577]: <info>  [1707860133.6338] dhcp4 (wlp1s0): canceled DHCP transaction
22:35:33 avahi-daemon[1347]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::a985:953:6396:fefb.
22:35:33 NetworkManager[1577]: <info>  [1707860133.6338] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
22:35:33 avahi-daemon[1347]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
22:35:33 NetworkManager[1577]: <info>  [1707860133.6338] dhcp4 (wlp1s0): state changed no lease
22:35:33 avahi-daemon[1347]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
22:35:33 avahi-daemon[1347]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.39.
22:35:33 avahi-daemon[1347]: Withdrawing address record for 192.168.1.39 on wlp1s0.
22:35:33 NetworkManager[1577]: <info>  [1707860133.7088] device (wlp1s0): set-hw-addr: set MAC address to 1A:65:FF:85:00:65 (scanning)
22:35:33 avahi-daemon[1347]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.39.
22:35:33 avahi-daemon[1347]: New relevant interface wlp1s0.IPv4 for mDNS.
22:35:33 avahi-daemon[1347]: Registering new address record for 192.168.1.39 on wlp1s0.IPv4.
22:35:33 avahi-daemon[1347]: Files changed, reloading.
22:35:33 avahi-daemon[1347]: No service file found in /etc/avahi/services.
22:35:33 NetworkManager[1577]: <info>  [1707860133.8782] device (wlp1s0): supplicant interface state: disconnected -> interface_disabled
22:35:33 NetworkManager[1577]: <info>  [1707860133.8783] device (wlp1s0): supplicant interface state: interface_disabled -> disconnected
22:35:33 NetworkManager[1577]: <info>  [1707860133.8786] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
22:35:33 chronyd[1678]: Source 213.239.154.12 offline
22:35:33 chronyd[1678]: Source 162.159.200.123 offline
22:35:33 chronyd[1678]: Source 5.39.184.5 offline
22:35:33 chronyd[1678]: Can't synchronise: no selectable sources
22:35:33 chronyd[1678]: Source 81.172.225.142 offline
22:35:33 dns-dnsmasq.sh[11228]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
22:35:33 NetworkManager[1577]: <info>  [1707860133.9577] device (wlp1s0): set-hw-addr: reset MAC address to 14:AC:60:29:8C:31 (unmanage)
22:35:34 systemd[1]: Reached target Sleep.
22:35:34 systemd[1]: Starting System Suspend...
22:35:34 systemd-sleep[11249]: INFO: Skip running /usr/lib/systemd/system-sleep/grub2.sleep for suspend
22:35:34 systemd-sleep[11237]: Entering sleep state 'suspend'...
22:35:34 kernel: PM: suspend entry (s2idle)
22:35:34 dns-dnsmasq.sh[11253]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
22:35:34 kernel: Filesystems sync: 0.026 seconds
22:35:34 dns-dnsmasq.sh[11280]: <debug> NETWORKMANAGER_DNS_FORWARDER is not set to "dnsmasq" in /etc/sysconfig/network/config -> exit
And these are the entries around 9:10:
09:10:13 kernel: Freezing user space processes
09:10:13 kernel: Freezing user space processes completed (elapsed 0.002 seconds)
09:10:13 kernel: OOM killer disabled.
09:10:13 kernel: Freezing remaining freezable tasks
09:10:13 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
09:10:13 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
09:10:13 kernel: queueing ieee80211 work while going to suspend
09:10:13 kernel: ACPI: EC: interrupt blocked
09:10:13 kernel: amd_pmc AMDI0009:00: Last suspend didn't reach deepest state
09:10:13 kernel: ACPI: EC: interrupt unblocked
09:10:13 kernel: [drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
09:10:13 kernel: amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=4
09:10:13 kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x6b on isa0060/serio0).
09:10:13 kernel: atkbd serio0: Use 'setkeycodes 6b <keycode>' to make it known.
09:10:13 kernel: atkbd serio0: Unknown key released (translated set 2, code 0x6b on isa0060/serio0).
09:10:13 kernel: nvme nvme0: 16/0/0 default/read/poll queues
09:10:13 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
09:10:13 kernel: amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
09:10:13 kernel: amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
09:10:13 kernel: [drm] ring gfx_32790.1.1 was added
09:10:13 kernel: [drm] ring compute_32790.2.2 was added
09:10:13 kernel: [drm] ring sdma_32790.3.3 was added
09:10:13 kernel: [drm] ring gfx_32790.1.1 ib test pass
09:10:13 kernel: [drm] ring compute_32790.2.2 ib test pass
09:10:13 kernel: [drm] ring sdma_32790.3.3 ib test pass
09:10:13 kernel: OOM killer enabled.
09:10:13 kernel: Restarting tasks ... done.
09:10:13 kernel: random: crng reseeded on system resumption
09:10:13 systemd-sleep[11237]: System returned from sleep state.
09:10:13 bluetoothd[1504]: Controller resume with wake event 0x0
09:10:13 kernel: PM: suspend exit
09:10:13 systemd-sleep[11328]: INFO: Skip running /usr/lib/systemd/system-sleep/grub2.sleep for suspend
09:10:13 systemd[1]: Backup RPM database was skipped because of an unmet condition check (ConditionACPower=true).
09:10:13 systemd[1]: Backup /etc/sysconfig directory was skipped because of an unmet condition check (ConditionACPower=true).
09:10:13 systemd[1]: Starting Check if mainboard battery is Ok...
09:10:13 systemd[1]: Started Timeline of Snapper Snapshots.
09:10:13 dbus-daemon[1348]: [system] Activating via systemd: service name='org.opensuse.Snapper' unit='snapperd.service' requested by ':1.107' (uid=0 pid=11334 comm="/usr/lib/snappe>
09:10:13 systemd[1]: Rotate log files was skipped because of an unmet condition check (ConditionACPower=true).
09:10:13 systemd[1]: systemd-suspend.service: Deactivated successfully.
09:10:13 systemd[1]: Finished System Suspend.
09:10:13 systemd[1]: check-battery.service: Deactivated successfully.
09:10:13 systemd[1]: Finished Check if mainboard battery is Ok.
09:10:13 systemd[1]: Stopped target Sleep.
09:10:13 systemd[1]: Reached target Suspend.
09:10:13 systemd-logind[1369]: Operation 'sleep' finished.
09:10:13 ModemManager[1517]: <info>  [sleep-monitor-systemd] system is resuming
09:10:13 NetworkManager[1577]: <info>  [1707898213.8546] manager: sleep: wake requested (sleeping: yes  enabled: yes)
09:10:13 NetworkManager[1577]: <info>  [1707898213.8549] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
09:10:13 kdeconnectd[2309]: Error sending UDP packet: QAbstractSocket::NetworkError
09:10:13 systemd[1]: Starting DBus interface for snapper...
09:10:13 systemd[1]: Stopped target Suspend.
09:10:13 NetworkManager[1577]: <info>  [1707898213.9199] device (wlp1s0): set-hw-addr: set MAC address to D6:4E:D9:CA:1B:00 (scanning)
09:10:13 dbus-daemon[1348]: [system] Successfully activated service 'org.opensuse.Snapper'
09:10:13 systemd[1]: Started DBus interface for snapper.
09:10:13 systemd[1]: snapper-timeline.service: Deactivated successfully.
09:10:13 NetworkManager[1577]: <info>  [1707898213.9761] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
09:10:13 NetworkManager[1577]: <info>  [1707898213.9763] manager: NetworkManager state is now DISCONNECTED
09:10:14 NetworkManager[1577]: <info>  [1707898214.0215] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
09:10:14 NetworkManager[1577]: <info>  [1707898214.0216] device (p2p-dev-wlp1s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
09:10:14 NetworkManager[1577]: <info>  [1707898214.0220] Wi-Fi P2P device controlled by interface wlp1s0 created
09:10:14 NetworkManager[1577]: <info>  [1707898214.0221] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/8)
09:10:14 NetworkManager[1577]: <info>  [1707898214.0223] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
09:10:14 NetworkManager[1577]: <info>  [1707898214.0226] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
09:10:14 NetworkManager[1577]: <info>  [1707898214.0231] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
09:10:14 plasmashell[8201]: [8196:8220:0214/091014.025050:ERROR:connection_factory_impl.cc(428)] Failed to connect to MCS endpoint with error -106
09:10:14 dbus-daemon[1348]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.26' (uid=1000 pid=2171 comm="/usr/libexec/org_kde_powerdevil") (us>
09:10:14 dbus-daemon[1348]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
09:10:14 kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
09:10:14 systemd-logind[1369]: The system will suspend now!
09:10:14 NetworkManager[1577]: <info>  [1707898214.7468] manager: sleep: sleep requested (sleeping: no  enabled: yes)
09:10:14 ModemManager[1517]: <info>  [sleep-monitor-systemd] system is about to suspend
09:10:14 NetworkManager[1577]: <info>  [1707898214.7470] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
09:10:14 NetworkManager[1577]: <info>  [1707898214.8551] device (wlp1s0): set-hw-addr: reset MAC address to 14:AC:60:29:8C:31 (unmanage)
09:10:14 NetworkManager[1577]: <info>  [1707898214.9268] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
09:10:14 NetworkManager[1577]: <info>  [1707898214.9276] manager: NetworkManager state is now ASLEEP
09:10:14 systemd[1]: Reached target Sleep.
09:10:14 plasmashell[2116]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x556744d174d0) QQmlContext(0x556743dc0980) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.>
09:10:14 systemd[1]: Starting System Suspend...
09:10:14 systemd-sleep[11361]: INFO: Skip running /usr/lib/systemd/system-sleep/grub2.sleep for suspend
09:10:14 systemd-sleep[11359]: Entering sleep state 'suspend'...
09:10:14 kernel: PM: suspend entry (s2idle)
Run https://gitlab.freedesktop.org/drm/amd/-/blob/master/scripts/amd_s2idle.py?ref_type=heads
I get this:
Location of log file (default s2idle_report-2024-02-14.txt)?
Debugging script for s2idle on AMD systems
💻 Framework Laptop 13 (AMD Ryzen 7040Series) (Laptop) running BIOS 3.3 (03.03) released 10/17/2023 and EC unknown
🐧 Kernel 6.7.4-1-default
🔋 Battery BAT1 ( ) is operating at 98.26% of design
Checking prerequisites for s2idle
🚦Logs are provided via dmesg, timestamps may not be accurate over multiple cycles
✅ AMD Ryzen 7 7840U w/ Radeon  780M Graphics (family 19 model 74)
✅ LPS0 _DSM enabled
✅ ACPI FADT supports Low-power S0 idle
✅ HSMP driver `amd_hsmp` not detected (blocked: False)
✅ PMC driver `amd_pmc` loaded (Program 0 Firmware 76.70.0)
✅ USB4 driver `thunderbolt` loaded
✅ GPU driver `amdgpu` available
✅ System is configured for s2idle
✅ NVME Shenzhen Longsys Electronics Co., Ltd. is configured for s2idle in BIOS
✅ GPIO driver `pinctrl_amd` available
How long should suspend cycles last in seconds (default 10)? 60
How long to wait in between suspend cycles in seconds (default 4)?
How many suspend cycles to run (default 1)?
Started at 2024-02-14 13:31:48.997344 (cycle finish expected @ 2024-02-14 13:32:52.997364)
Results from last s2idle cycle
○ Suspend count: 2
○ Hardware sleep cycle count: 2
○ GPIOs active: ['5', '5', '5', '5', '5']
○ Wakeups triggered from IRQs: [9]
○ Woke up from IRQ 9 (IR-IO-APIC 9-fasteoi acpi)
○ gpe0B increased from 245 to 253
✅ Userspace suspended for 0:01:02.686064
Unable to gather hardware sleep data with lockdown engaged
I wanted to post the entire log file, but there’s something in there that trips up the forum software such that I get a 403 error.
Log (first part):
(What tripped up the forum software were the addresses starting with “backslash proc”, I’ve removed the backslash below.)
13:31:33,269 DEBUG:	Since support: 1
13:31:33,286 INFO:	Debugging script for s2idle on AMD systems
13:31:33,287 INFO:	💻 Framework Laptop 13 (AMD Ryzen 7040Series) (Laptop) running BIOS 3.3 (03.03) released 10/17/2023 and EC unknown
13:31:33,287 INFO:	🐧 Kernel 6.7.4-1-default
13:31:33,289 DEBUG:	BAT1 charge level is 3061000 µAh
13:31:33,289 INFO:	🔋 Battery BAT1 ( ) is operating at 98.26% of design
13:31:33,290 INFO:	Checking prerequisites for s2idle
13:31:33,290 WARNING:	🚦Logs are provided via dmesg, timestamps may not be accurate over multiple cycles
13:31:33,290 INFO:	✅ AMD Ryzen 7 7840U w/ Radeon  780M Graphics (family 19 model 74)
13:31:33,291 INFO:	✅ LPS0 _DSM enabled
13:31:33,291 INFO:	✅ ACPI FADT supports Low-power S0 idle
13:31:33,291 DEBUG:	/sys/module/gpiolib_acpi/parameters/ignore_wake is not configured
13:31:33,291 DEBUG:	/sys/module/gpiolib_acpi/parameters/ignore_interrupt is not configured
13:31:33,291 DEBUG:	proc/cmdline:
13:31:33,292 INFO:	✅ HSMP driver `amd_hsmp` not detected (blocked: False)
13:31:33,296 INFO:	✅ PMC driver `amd_pmc` loaded (Program 0 Firmware 76.70.0)
13:31:33,306 INFO:	✅ USB4 driver `thunderbolt` loaded
13:31:33,310 INFO:	✅ GPU driver `amdgpu` available
13:31:33,311 INFO:	✅ System is configured for s2idle
13:31:33,317 INFO:	✅ NVME Shenzhen Longsys Electronics Co., Ltd. is configured for s2idle in BIOS
13:31:33,320 INFO:	✅ GPIO driver `pinctrl_amd` available
13:31:33,323 DEBUG:	Winblue GPIO 0 debounce: disabled
13:31:33,323 DEBUG:	gpio	  int|active|trigger|S0i3| S3|S4/S5| Z|wake|pull|  orient|       debounce|reg
13:31:33,323 DEBUG:	#0	   😛|     ↑|   edge|  ⏰| ⏰|     |⏰|    |  ↑ |input  ↑|b (🕑 046875us)|0x81578e3
13:31:33,323 DEBUG:	#2	   😛|     ↓|   edge|  ⏰| ⏰|     |  |    |    |input  ↑|               |0x57a00
13:31:33,323 DEBUG:	#5	   😛|     ↓|  level|    |   |     |  |    |  ↑ |input  ↑|               |0x151b00
13:31:33,323 DEBUG:	#6	   😛|     ↓|   edge|  ⏰| ⏰|     |  |    |  ↑ |input  ↑|               |0x157a00
13:31:33,323 DEBUG:	#8	   😛|     ↓|  level|    |   |     |⏰|    |  ↑ |input  ↑|               |0x8151b00
13:31:33,323 DEBUG:	#44	   😷|     ↑|   edge|    |   |     |  |    |    |input  ↓|               |0x800
13:31:33,323 DEBUG:	#52	   😷|     ↑|  level|    |   |     |  |    |    |input  ↓|               |0x900
13:31:33,323 DEBUG:	#54	   😛|     ↑|   edge|  ⏰| ⏰|     |  |    |    |input  ↓|               |0x7800
13:31:33,323 DEBUG:	#58	   😛|     ↑|  level|  ⏰| ⏰|     |⏰|    |    |input  ↓|               |0x8007900
13:31:33,323 DEBUG:	#59	   😛|     ↑|  level|  ⏰| ⏰|     |⏰|    |    |input  ↓|               |0x8007900
13:31:33,323 DEBUG:	#61	   😛|     ↑|  level|  ⏰| ⏰|     |  |    |    |input  ↓|               |0x7900
13:31:33,323 DEBUG:	#62	   😛|     ↑|  level|  ⏰| ⏰|     |  |    |    |input  ↓|               |0x7900
13:31:33,323 DEBUG:	#84	   😛|     ↓|  level|    |   |     |  |    |  ↑ |input  ↑|               |0x151b00
13:31:33,323 DEBUG:	#172	   😷|     ↑|  level|    |   |     |  |    |    |input  ↓|               |0x900
13:31:33,324 DEBUG:	Lockdown: none [integrity] confidentiality
13:31:33,325 DEBUG:	VCE feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	UVD feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	MC feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	ME feature version: 35, firmware version: 0x00000027
13:31:33,325 DEBUG:	PFP feature version: 35, firmware version: 0x0000002f
13:31:33,325 DEBUG:	CE feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	RLC feature version: 1, firmware version: 0x0000007f
13:31:33,325 DEBUG:	RLC SRLC feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	RLC SRLG feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	RLC SRLS feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	RLCP feature version: 1, firmware version: 0x0000000f
13:31:33,325 DEBUG:	RLCV feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	MEC feature version: 35, firmware version: 0x00000023
13:31:33,325 DEBUG:	IMU feature version: 0, firmware version: 0x0b012c00
13:31:33,325 DEBUG:	SOS feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	ASD feature version: 553648327, firmware version: 0x210000c7
13:31:33,325 DEBUG:	TA XGMI feature version: 0x00000000, firmware version: 0x00000000
13:31:33,325 DEBUG:	TA RAS feature version: 0x00000000, firmware version: 0x00000000
13:31:33,325 DEBUG:	TA HDCP feature version: 0x00000000, firmware version: 0x1700003c
13:31:33,325 DEBUG:	TA DTM feature version: 0x00000000, firmware version: 0x12000016
13:31:33,325 DEBUG:	TA RAP feature version: 0x00000000, firmware version: 0x00000000
13:31:33,325 DEBUG:	TA SECUREDISPLAY feature version: 0x00000000, firmware version: 0x00000000
13:31:33,325 DEBUG:	SMC feature version: 0, program: 0, firmware version: 0x004c4600 (76.70.0)
13:31:33,325 DEBUG:	SDMA0 feature version: 60, firmware version: 0x00000010
13:31:33,325 DEBUG:	VCN feature version: 0, firmware version: 0x0510c000
13:31:33,325 DEBUG:	DMCU feature version: 0, firmware version: 0x00000000
13:31:33,325 DEBUG:	DMCUB feature version: 0, firmware version: 0x08003000
13:31:33,325 DEBUG:	TOC feature version: 0, firmware version: 0x0000000b
13:31:33,326 DEBUG:	MES_KIQ feature version: 6, firmware version: 0x00000073
13:31:33,326 DEBUG:	MES feature version: 1, firmware version: 0x00000052
13:31:33,326 DEBUG:	VPE feature version: 0, firmware version: 0x00000000
13:31:33,326 DEBUG:	VBIOS version: 113-PHXGENERIC-001
13:31:33,333 DEBUG:	PCI devices
13:31:33,334 DEBUG:	| 0000:00:00.0 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14e8]
13:31:33,334 DEBUG:	| 0000:00:00.2 : Advanced Micro Devices, Inc. [AMD] IOMMU [1022:14e9]
13:31:33,334 DEBUG:	| 0000:00:01.0 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14ea]
13:31:33,334 DEBUG:	| 0000:00:02.0 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14ea]
13:31:33,335 DEBUG:	| 0000:00:02.2 : Advanced Micro Devices, Inc. [AMD] PCI bridge [1022:14ee] : \_SB_.PCI0.GPP6
13:31:33,335 DEBUG:	├─ 0000:01:00.0 : MEDIATEK Corp. Network controller [14c3:0616] : \_SB_.PCI0.GPP6.WLAN
13:31:33,335 DEBUG:	| 0000:00:02.4 : Advanced Micro Devices, Inc. [AMD] PCI bridge [1022:14ee] : \_SB_.PCI0.GPP8
13:31:33,335 DEBUG:	├─ 0000:02:00.0 : Shenzhen Longsys Electronics Co., Ltd. Non-Volatile memory controller [1d97:1602] : \_SB_.PCI0.GPP8.NVME
13:31:33,336 DEBUG:	| 0000:00:03.0 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14ea]
13:31:33,336 DEBUG:	| 0000:00:03.1 : Advanced Micro Devices, Inc. [AMD] PCI bridge [1022:14ef] : \_SB_.PCI0.GP11
13:31:33,336 DEBUG:	| 0000:00:04.0 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14ea]
13:31:33,336 DEBUG:	| 0000:00:04.1 : Advanced Micro Devices, Inc. [AMD] PCI bridge [1022:14ef] : \_SB_.PCI0.GP12
13:31:33,336 DEBUG:	| 0000:00:08.0 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14ea]
13:31:33,337 DEBUG:	| 0000:00:08.1 : Advanced Micro Devices, Inc. [AMD] PCI bridge [1022:14eb] : \_SB_.PCI0.GP17
13:31:33,337 DEBUG:	├─ 0000:c1:00.0 : Advanced Micro Devices, Inc. [AMD/ATI] VGA compatible controller [1002:15bf] : \_SB_.PCI0.GP17.VGA_
13:31:33,337 DEBUG:	├─ 0000:c1:00.1 : Advanced Micro Devices, Inc. [AMD/ATI] Audio device [1002:1640] : \_SB_.PCI0.GP17.HDAU
13:31:33,337 DEBUG:	├─ 0000:c1:00.2 : Advanced Micro Devices, Inc. [AMD] Encryption controller [1022:15c7] : \_SB_.PCI0.GP17.PSP_
13:31:33,338 DEBUG:	├─ 0000:c1:00.3 : Advanced Micro Devices, Inc. [AMD] USB controller [1022:15b9] : \_SB_.PCI0.GP17.XHC0
13:31:33,338 DEBUG:	├─ 0000:c1:00.4 : Advanced Micro Devices, Inc. [AMD] USB controller [1022:15ba] : \_SB_.PCI0.GP17.XHC1
13:31:33,338 DEBUG:	├─ 0000:c1:00.5 : Advanced Micro Devices, Inc. [AMD] Multimedia controller [1022:15e2] : \_SB_.PCI0.GP17.ACP_
13:31:33,338 DEBUG:	├─ 0000:c1:00.6 : Advanced Micro Devices, Inc. [AMD] Audio device [1022:15e3] : \_SB_.PCI0.GP17.AZAL
13:31:33,338 DEBUG:	| 0000:00:08.2 : Advanced Micro Devices, Inc. [AMD] PCI bridge [1022:14eb] : \_SB_.PCI0.GP18
13:31:33,339 DEBUG:	├─ 0000:c2:00.0 : Advanced Micro Devices, Inc. [AMD]  [1022:14ec]
13:31:33,339 DEBUG:	├─ 0000:c2:00.1 : Advanced Micro Devices, Inc. [AMD] Signal processing controller [1022:1502] : \_SB_.PCI0.GP18.IPU_
13:31:33,339 DEBUG:	| 0000:00:08.3 : Advanced Micro Devices, Inc. [AMD] PCI bridge [1022:14eb] : \_SB_.PCI0.GP19
13:31:33,339 DEBUG:	├─ 0000:c3:00.0 : Advanced Micro Devices, Inc. [AMD]  [1022:14ec] : \_SB_.PCI0.GP19.XHC2
13:31:33,339 DEBUG:	├─ 0000:c3:00.3 : Advanced Micro Devices, Inc. [AMD] USB controller [1022:15c0] : \_SB_.PCI0.GP19.XHC3
13:31:33,340 DEBUG:	├─ 0000:c3:00.4 : Advanced Micro Devices, Inc. [AMD] USB controller [1022:15c1] : \_SB_.PCI0.GP19.XHC4
13:31:33,340 DEBUG:	├─ 0000:c3:00.5 : Advanced Micro Devices, Inc. [AMD] USB controller [1022:1668] : \_SB_.PCI0.GP19.NHI0
13:31:33,340 DEBUG:	├─ 0000:c3:00.6 : Advanced Micro Devices, Inc. [AMD] USB controller [1022:1669] : \_SB_.PCI0.GP19.NHI1
13:31:33,340 DEBUG:	| 0000:00:14.0 : Advanced Micro Devices, Inc. [AMD] SMBus [1022:790b] : \_SB_.PCI0.SMBS
13:31:33,341 DEBUG:	| 0000:00:14.3 : Advanced Micro Devices, Inc. [AMD] ISA bridge [1022:790e] : \_SB_.PCI0.LPC0
13:31:33,341 DEBUG:	| 0000:00:18.0 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f0]
13:31:33,341 DEBUG:	| 0000:00:18.1 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f1]
13:31:33,341 DEBUG:	| 0000:00:18.2 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f2]
13:31:33,341 DEBUG:	| 0000:00:18.3 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f3]
13:31:33,341 DEBUG:	| 0000:00:18.4 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f4]
13:31:33,342 DEBUG:	| 0000:00:18.5 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f5]
13:31:33,342 DEBUG:	| 0000:00:18.6 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f6]
13:31:33,342 DEBUG:	└─0000:00:18.7 : Advanced Micro Devices, Inc. [AMD] Host bridge [1022:14f7]
13:31:33,355 DEBUG:	I2C HID devices
13:31:33,355 DEBUG:	| "FRMW0004:00 32AC:0006 Wireless Radio Control" [FRMW0004] : \_SB_.I2CA.ECSH
13:31:33,355 DEBUG:	| "FRMW0004:00 32AC:0006 Consumer Control" [FRMW0004] : \_SB_.I2CA.ECSH
13:31:33,356 DEBUG:	| "PIXA3854:00 093A:0274 Mouse" [PIXA3854] : \_SB_.I2CD.TPAD
13:31:33,356 DEBUG:	└─"PIXA3854:00 093A:0274 Touchpad" [PIXA3854] : \_SB_.I2CD.TPAD
13:31:33,390 DEBUG:	Wakeup sources:
13:31:33,390 DEBUG:	|  [/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:001/wakeup44]: enabled
13:31:33,390 DEBUG:	|  [/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:002/wakeup45]: enabled
13:31:33,390 DEBUG:	|  [/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:003/wakeup46]: enabled
13:31:33,390 DEBUG:	|  [/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:004/wakeup47]: enabled
13:31:33,390 DEBUG:	| ACPI Battery [PNP0C0A:00]: enabled
13:31:33,390 DEBUG:	| ACPI Lid Switch [PNP0C0D:00]: enabled
13:31:33,391 DEBUG:	| ACPI Power Button [PNP0C0C:00]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] ISA bridge [0000:00:14.3]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] Multimedia controller [0000:c1:00.5]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] PCI bridge [0000:00:02.2]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] PCI bridge [0000:00:03.1]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] PCI bridge [0000:00:04.1]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] USB controller [0000:c1:00.3]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] USB controller [0000:c1:00.4]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] USB controller [0000:c3:00.3]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] USB controller [0000:c3:00.4]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] USB controller [0000:c3:00.5]: enabled
13:31:33,391 DEBUG:	| Advanced Micro Devices, Inc. [AMD] USB controller [0000:c3:00.6]: enabled
13:31:33,391 DEBUG:	| PIXA3854:00 093A:0274 Mouse [i2c-PIXA3854:00]: enabled
13:31:33,391 DEBUG:	| Plug-n-play Real Time Clock [00:01]: enabled
13:31:33,391 DEBUG:	| Real Time Clock alarm timer [rtc0]: enabled
13:31:33,391 DEBUG:	| Thunderbolt domain [domain0]: enabled
13:31:33,391 DEBUG:	| Thunderbolt domain [domain1]: enabled
13:31:33,391 DEBUG:	| USB4 host controller [0-0]: enabled
13:31:33,391 DEBUG:	└─USB4 host controller [1-0]: enabled
13:31:33,398 DEBUG:	/*
13:31:33,398 DEBUG:	 * Intel ACPI Component Architecture
13:31:33,398 DEBUG:	 * AML/ASL+ Disassembler version 20230331 (64-bit version)
13:31:33,398 DEBUG:	 * Copyright (c) 2000 - 2023 Intel Corporation
13:31:33,398 DEBUG:	 * Disassembling to symbolic ASL+ operators
13:31:33,398 DEBUG:	 * Disassembly of /sys/firmware/acpi/tables/SSDT23, Wed Feb 14 13:31:33 2024
13:31:33,398 DEBUG:	 * Original Table Header:
13:31:33,398 DEBUG:	 *     Signature        "SSDT"
13:31:33,398 DEBUG:	 *     Length           0x00000C7F (3199)
13:31:33,398 DEBUG:	 *     Revision         0x02
13:31:33,398 DEBUG:	 *     Checksum         0x3F
13:31:33,398 DEBUG:	 *     OEM ID           "INSYDE"
13:31:33,398 DEBUG:	 *     OEM Table ID     "EDK2    "
13:31:33,398 DEBUG:	 *     OEM Revision     0x00000001 (1)
13:31:33,398 DEBUG:	 *     Compiler ID      "ACPI"
13:31:33,398 DEBUG:	 *     Compiler Version 0x00040000 (262144)
13:31:33,399 DEBUG:	 */
13:31:33,399 DEBUG:	DefinitionBlock ("", "SSDT", 2, "INSYDE", "EDK2    ", 0x00000001)
13:31:33,399 DEBUG:	{
13:31:33,399 DEBUG:	    External (_SB_.GPIO, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GP17.ACP_, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GP17.AZAL, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GP17.MP2C, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GP17.XHC0, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GP17.XHC1, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GPP0, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GPP1, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GPP2, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GPP5, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GPP6, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GPP7, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.GPP7.DEV0, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.LPC0.EC0_, DeviceObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.LPC0.EC0_.OKEC, IntObj)
13:31:33,399 DEBUG:	    External (_SB_.PCI0.LPC0.EC0_.Z009, MutexObj)
13:31:33,399 DEBUG:	    External (_SB_.PWRB, DeviceObj)
13:31:33,399 DEBUG:	    External (M000, MethodObj)    // 1 Arguments
13:31:33,399 DEBUG:	    External (M037, DeviceObj)
13:31:33,399 DEBUG:	    External (M046, IntObj)
13:31:33,399 DEBUG:	    External (M047, IntObj)
13:31:33,399 DEBUG:	    External (M050, DeviceObj)
13:31:33,399 DEBUG:	    External (M051, DeviceObj)
13:31:33,399 DEBUG:	    External (M052, DeviceObj)
13:31:33,399 DEBUG:	    External (M053, DeviceObj)
13:31:33,399 DEBUG:	    External (M054, DeviceObj)
13:31:33,399 DEBUG:	    External (M055, DeviceObj)
13:31:33,399 DEBUG:	    External (M056, DeviceObj)
13:31:33,399 DEBUG:	    External (M057, DeviceObj)
13:31:33,399 DEBUG:	    External (M058, DeviceObj)
13:31:33,399 DEBUG:	    External (M059, DeviceObj)
13:31:33,399 DEBUG:	    External (M062, DeviceObj)
13:31:33,399 DEBUG:	    External (M068, DeviceObj)
13:31:33,399 DEBUG:	    External (M069, DeviceObj)
13:31:33,399 DEBUG:	    External (M070, DeviceObj)
13:31:33,400 DEBUG:	    External (M071, DeviceObj)
13:31:33,400 DEBUG:	    External (M072, DeviceObj)
13:31:33,400 DEBUG:	    External (M074, DeviceObj)
13:31:33,400 DEBUG:	    External (M075, DeviceObj)
13:31:33,400 DEBUG:	    External (M076, DeviceObj)
13:31:33,400 DEBUG:	    External (M077, DeviceObj)
13:31:33,400 DEBUG:	    External (M078, DeviceObj)
13:31:33,400 DEBUG:	    External (M079, DeviceObj)
13:31:33,400 DEBUG:	    External (M080, DeviceObj)
13:31:33,400 DEBUG:	    External (M081, DeviceObj)
13:31:33,400 DEBUG:	    External (M082, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M083, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M084, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M085, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M086, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M087, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M088, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M089, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M090, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M091, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M092, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M093, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M094, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M095, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M096, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M097, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M098, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M099, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M100, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M101, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M102, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M103, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M104, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M105, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M106, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M107, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M108, FieldUnitObj)
13:31:33,400 DEBUG:	    External (M109, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M110, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M115, BuffObj)
13:31:33,401 DEBUG:	    External (M116, BuffFieldObj)
13:31:33,401 DEBUG:	    External (M117, BuffFieldObj)
13:31:33,401 DEBUG:	    External (M118, BuffFieldObj)
13:31:33,401 DEBUG:	    External (M119, BuffFieldObj)
13:31:33,401 DEBUG:	    External (M120, BuffFieldObj)
13:31:33,401 DEBUG:	    External (M122, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M127, DeviceObj)
13:31:33,401 DEBUG:	    External (M128, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M131, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M132, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M133, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M134, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M135, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M136, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M220, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M221, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M226, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M227, DeviceObj)
13:31:33,401 DEBUG:	    External (M229, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M231, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M233, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M235, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M23A, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M251, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M280, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M290, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M29A, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M310, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M31C, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M320, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M321, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M322, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M323, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M324, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M325, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M326, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M327, FieldUnitObj)
13:31:33,401 DEBUG:	    External (M328, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M329, DeviceObj)
13:31:33,402 DEBUG:	    External (M32A, DeviceObj)
13:31:33,402 DEBUG:	    External (M32B, DeviceObj)
13:31:33,402 DEBUG:	    External (M330, DeviceObj)
13:31:33,402 DEBUG:	    External (M331, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M378, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M379, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M380, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M381, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M382, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M383, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M384, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M385, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M386, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M387, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M388, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M389, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M390, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M391, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M392, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M404, BuffObj)
13:31:33,402 DEBUG:	    External (M408, MutexObj)
13:31:33,402 DEBUG:	    External (M414, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M444, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M449, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M453, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M454, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M455, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M456, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M457, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M460, MethodObj)    // 7 Arguments
13:31:33,402 DEBUG:	    External (M4C0, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M4F0, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M610, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M620, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M631, FieldUnitObj)
13:31:33,402 DEBUG:	    External (M652, FieldUnitObj)
13:31:33,402 DEBUG:
13:31:33,403 DEBUG:	    Scope (\_SB.PCI0.LPC0.EC0)
13:31:33,403 DEBUG:	    {
13:31:33,403 DEBUG:	        OperationRegion (ECRM, EmbeddedControl, Zero, 0xFF)
13:31:33,403 DEBUG:	        Field (ECRM, ByteAcc, NoLock, Preserve)
13:31:33,403 DEBUG:	            Offset (0xCC),
13:31:33,403 DEBUG:	            PBCN,   8
13:31:33,403 DEBUG:	        }
13:31:33,403 DEBUG:
13:31:33,403 DEBUG:	    Scope (\_SB.GPIO)
13:31:33,403 DEBUG:	        Method (_AEI, 0, NotSerialized)  // _AEI: ACPI Event Interrupts
13:31:33,403 DEBUG:	            Name (BUF0, ResourceTemplate ()
13:31:33,403 DEBUG:	                GpioInt (Edge, ActiveHigh, ExclusiveAndWake, PullDefault, 0x1388,
13:31:33,403 DEBUG:	                    "\\_SB.GPIO", 0x00, ResourceConsumer, ,
13:31:33,403 DEBUG:	                    )
13:31:33,403 DEBUG:	                    {   // Pin list
13:31:33,403 DEBUG:	                        0x0000
13:31:33,403 DEBUG:	                GpioInt (Level, ActiveHigh, ExclusiveAndWake, PullNone, 0x0000,
13:31:33,403 DEBUG:	                        0x003D
13:31:33,403 DEBUG:	                        0x003E
13:31:33,403 DEBUG:	                        0x003A
13:31:33,404 DEBUG:	                    }
13:31:33,404 DEBUG:	                GpioInt (Level, ActiveHigh, ExclusiveAndWake, PullNone, 0x0000,
13:31:33,404 DEBUG:	                    "\\_SB.GPIO", 0x00, ResourceConsumer, ,
13:31:33,404 DEBUG:	                    )
13:31:33,404 DEBUG:	                    {   // Pin list
13:31:33,404 DEBUG:	                        0x003B
13:31:33,404 DEBUG:	                GpioInt (Edge, ActiveLow, ExclusiveAndWake, PullNone, 0x0000,
13:31:33,404 DEBUG:	                        0x0002
13:31:33,404 DEBUG:	                        0x0006
13:31:33,404 DEBUG:	                GpioInt (Edge, ActiveHigh, ExclusiveAndWake, PullNone, 0x0000,
13:31:33,404 DEBUG:	                        0x0036
13:31:33,404 DEBUG:	            })
13:31:33,404 DEBUG:	            M460 ("  OEM-ASL-\\_SB.GPIO._AEI\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,404 DEBUG:	            Return (BUF0) /* \_SB_.GPIO._AEI.BUF0 */
13:31:33,404 DEBUG:
13:31:33,404 DEBUG:	        Method (_EVT, 1, Serialized)  // _EVT: Event
13:31:33,404 DEBUG:	            Name (HPDW, 0x55)
13:31:33,404 DEBUG:	            M460 ("  OEM-ASL-\\_SB.GPIO._EVT-Start Case %d\n", ToInteger (Arg0), Zero, Zero, Zero, Zero, Zero)
13:31:33,404 DEBUG:	            Switch (ToInteger (Arg0))
13:31:33,404 DEBUG:	                Case (Zero)
13:31:33,405 DEBUG:	                }
13:31:33,405 DEBUG:	                Case (0x02)
13:31:33,405 DEBUG:	                {
13:31:33,405 DEBUG:	                    M000 (0x3902)
13:31:33,405 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GPP0, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,405 DEBUG:	                    Notify (\_SB.PCI0.GPP0, 0x02) // Device Wake
13:31:33,405 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GPP1, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,405 DEBUG:	                    Notify (\_SB.PCI0.GPP1, 0x02) // Device Wake
13:31:33,405 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GPP2, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,405 DEBUG:	                    Notify (\_SB.PCI0.GPP2, 0x02) // Device Wake
13:31:33,405 DEBUG:	                Case (0x03)
13:31:33,405 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GPP7, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,405 DEBUG:	                    Notify (\_SB.PCI0.GPP7, 0x02) // Device Wake
13:31:33,405 DEBUG:	                Case (0x0B)
13:31:33,405 DEBUG:	                    M000 (0x390B)
13:31:33,405 DEBUG:	                Case (0x11)
13:31:33,405 DEBUG:	                    M000 (0x3911)
13:31:33,405 DEBUG:	                Case (0x06)
13:31:33,405 DEBUG:	                    M000 (0x3912)
13:31:33,405 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GPP6, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,405 DEBUG:	                    Notify (\_SB.PCI0.GPP6, 0x02) // Device Wake
13:31:33,405 DEBUG:	                Case (0x18)
13:31:33,405 DEBUG:	                    M000 (0x3918)
13:31:33,405 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GPP5, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,405 DEBUG:	                    Notify (\_SB.PCI0.GPP5, 0x02) // Device Wake
13:31:33,406 DEBUG:	                Case (0x36)
13:31:33,406 DEBUG:	                {
13:31:33,406 DEBUG:	                    M000 (0x3936)
13:31:33,406 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GP17.MP2C, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,406 DEBUG:	                    Notify (\_SB.PCI0.GP17.MP2C, 0x02) // Device Wake
13:31:33,406 DEBUG:	                    If ((HPDW == One))
13:31:33,406 DEBUG:	                        M460 ("    Notify (\\_SB.PCI0.GP17.MP2C(HPDW):PWRB 0x80)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,406 DEBUG:	                        Notify (\_SB.PWRB, 0x80) // Status Change
13:31:33,406 DEBUG:	                    }
13:31:33,406 DEBUG:	                Case (0x3A)
13:31:33,406 DEBUG:	                    M000 (0x393A)
13:31:33,406 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GP17.XHC0, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,406 DEBUG:	                    Notify (\_SB.PCI0.GP17.XHC0, 0x02) // Device Wake
13:31:33,406 DEBUG:	                Case (0x3B)
13:31:33,406 DEBUG:	                    M000 (0x393B)
13:31:33,406 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GP17.XHC1, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,406 DEBUG:	                    Notify (\_SB.PCI0.GP17.XHC1, 0x02) // Device Wake
13:31:33,406 DEBUG:	                Case (0x2A)
13:31:33,406 DEBUG:	                    M000 (0x392A)
13:31:33,406 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GPP7.DEV0, 0x01)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,406 DEBUG:	                    Notify (\_SB.PCI0.GPP7.DEV0, One) // Device Check
13:31:33,406 DEBUG:	                Case (0x3D)
13:31:33,406 DEBUG:	                    M000 (0x393D)
13:31:33,406 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GP17.AZAL, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,406 DEBUG:	                    Notify (\_SB.PCI0.GP17.AZAL, 0x02) // Device Wake
13:31:33,406 DEBUG:	                Case (0x3E)
13:31:33,406 DEBUG:	                    M460 ("    Notify (\\_SB.PCI0.GP17.ACP, 0x02)\n", Zero, Zero, Zero, Zero, Zero, Zero)
13:31:33,407 DEBUG:	                    Notify (\_SB.PCI0.GP17.ACP, 0x02) // Device Wake
13:31:33,407 DEBUG:	                }
13:31:33,407 DEBUG:
13:31:33,407 DEBUG:
13:31:33,407 DEBUG:	            M460 ("  OEM-ASL-\\_SB.GPIO._EVT-End Case %d\n", ToInteger (Arg0), Zero, Zero, Zero, Zero, Zero)
Log (second part):
13:31:46,993 DEBUG:	Suspend timer programmed for 0:01:00
13:31:46,996 DEBUG:	ACPI Lid (proc/acpi/button/lid/LID0/state): open
13:31:48,997 INFO:	Started at 2024-02-14 13:31:48.997344 (cycle finish expected @ 2024-02-14 13:32:52.997364)
13:32:51,664 INFO:	Results from last s2idle cycle
13:32:51,673 DEBUG:	2024-02-14T14:01:53,455346+01:00 ACPI: EC: interrupt unblocked
13:32:51,674 DEBUG:	2024-02-14T14:01:53,692674+01:00 nvme nvme0: 16/0/0 default/read/poll queues
13:32:51,674 DEBUG:	2024-02-14T14:01:53,719848+01:00 atkbd serio0: Unknown key pressed (translated set 2, code 0x6b on isa0060/serio0).
13:32:51,674 DEBUG:	2024-02-14T14:01:53,719857+01:00 atkbd serio0: Use 'setkeycodes 6b <keycode>' to make it known.
13:32:51,674 DEBUG:	2024-02-14T14:01:53,720624+01:00 atkbd serio0: Unknown key released (translated set 2, code 0x6b on isa0060/serio0).
13:32:51,674 DEBUG:	2024-02-14T14:01:53,720633+01:00 atkbd serio0: Use 'setkeycodes 6b <keycode>' to make it known.
13:32:51,674 DEBUG:	2024-02-14T14:01:53,773160+01:00 [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
13:32:51,674 DEBUG:	2024-02-14T14:01:53,773417+01:00 [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
13:32:51,674 DEBUG:	2024-02-14T14:01:53,775504+01:00 [drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
13:32:51,674 DEBUG:	2024-02-14T14:01:53,775638+01:00 amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
13:32:51,674 DEBUG:	2024-02-14T14:01:53,778982+01:00 amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
13:32:51,674 DEBUG:	2024-02-14T14:01:53,779061+01:00 amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=4
13:32:51,674 DEBUG:	2024-02-14T14:01:53,972818+01:00 [drm] VCN decode and encode initialized successfully(under DPG Mode).
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973064+01:00 amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973348+01:00 amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973351+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973353+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973354+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973355+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973356+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973357+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973358+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973360+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973361+01:00 amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973363+01:00 amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973364+01:00 amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
13:32:51,674 DEBUG:	2024-02-14T14:01:53,973365+01:00 amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
13:32:51,674 DEBUG:	2024-02-14T14:01:53,978221+01:00 [drm] ring gfx_32792.1.1 was added
13:32:51,674 DEBUG:	2024-02-14T14:01:53,978780+01:00 [drm] ring compute_32792.2.2 was added
13:32:51,674 DEBUG:	2024-02-14T14:01:53,979283+01:00 [drm] ring sdma_32792.3.3 was added
13:32:51,674 DEBUG:	2024-02-14T14:01:53,979309+01:00 [drm] ring gfx_32792.1.1 ib test pass
13:32:51,674 DEBUG:	2024-02-14T14:01:53,979335+01:00 [drm] ring compute_32792.2.2 ib test pass
13:32:51,674 DEBUG:	2024-02-14T14:01:53,979448+01:00 [drm] ring sdma_32792.3.3 ib test pass
13:32:51,674 DEBUG:	2024-02-14T14:01:54,093101+01:00 OOM killer enabled.
13:32:51,674 DEBUG:	2024-02-14T14:01:54,093104+01:00 Restarting tasks ... done.
13:32:51,674 DEBUG:	2024-02-14T14:01:54,094685+01:00 random: crng reseeded on system resumption
13:32:51,674 DEBUG:	2024-02-14T14:01:54,099885+01:00 PM: suspend exit
13:32:51,675 DEBUG:	2024-02-14T14:01:57,184305+01:00 wlp1s0: authenticate with 54:8a:ba:ca:ac:6e (local address=14:ac:60:29:8c:31)
13:32:51,675 DEBUG:	2024-02-14T14:01:57,200466+01:00 wlp1s0: send auth to 54:8a:ba:ca:ac:6e (try 1/3)
13:32:51,675 DEBUG:	2024-02-14T14:01:57,204246+01:00 wlp1s0: authenticated
13:32:51,675 DEBUG:	2024-02-14T14:01:57,207615+01:00 wlp1s0: associate with 54:8a:ba:ca:ac:6e (try 1/3)
13:32:51,675 DEBUG:	2024-02-14T14:01:57,221830+01:00 wlp1s0: RX AssocResp from 54:8a:ba:ca:ac:6e (capab=0x1111 status=0 aid=13)
13:32:51,675 DEBUG:	2024-02-14T14:01:57,252285+01:00 wlp1s0: associated
13:32:51,675 DEBUG:	2024-02-14T14:01:57,287587+01:00 wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 54:8a:ba:ca:ac:6e
13:32:51,675 DEBUG:	2024-02-14T14:01:58,964157+01:00 ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
13:32:51,675 DEBUG:	2024-02-14T14:02:04,170577+01:00 ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
13:32:51,675 DEBUG:	2024-02-14T14:13:03,375255+01:00 i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
13:32:51,675 DEBUG:	2024-02-14T14:16:09,701612+01:00 i2c_designware AMDI0010:00: i2c_dw_handle_tx_abort: lost arbitration
13:32:51,675 DEBUG:	2024-02-14T14:16:19,980535+01:00 i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
13:32:51,675 DEBUG:	2024-02-14T14:16:42,065353+01:00 i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
13:32:51,675 DEBUG:	2024-02-14T14:23:01,427528+01:00 i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
13:32:51,675 DEBUG:	2024-02-14T14:27:50,825554+01:00 ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
13:32:51,675 DEBUG:	2024-02-14T14:28:06,957317+01:00 i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
13:32:51,675 DEBUG:	2024-02-14T14:28:10,088097+01:00 i2c_designware AMDI0010:00: i2c_dw_handle_tx_abort: lost arbitration
13:32:51,675 DEBUG:	2024-02-14T14:28:23,238130+01:00 i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
13:32:51,675 DEBUG:	2024-02-14T14:29:25,680895+01:00 PM: suspend entry (s2idle)
13:32:51,675 DEBUG:	2024-02-14T14:29:25,713714+01:00 Filesystems sync: 0.032 seconds
13:32:51,675 DEBUG:	2024-02-14T14:29:25,857241+01:00 Freezing user space processes
13:32:51,675 DEBUG:	2024-02-14T14:29:25,859383+01:00 Freezing user space processes completed (elapsed 0.002 seconds)
13:32:51,675 DEBUG:	2024-02-14T14:29:25,859390+01:00 OOM killer disabled.
13:32:51,675 DEBUG:	2024-02-14T14:29:25,859392+01:00 Freezing remaining freezable tasks
13:32:51,675 DEBUG:	2024-02-14T14:29:25,860924+01:00 Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
13:32:51,675 DEBUG:	2024-02-14T14:29:25,860931+01:00 printk: Suspending console(s) (use no_console_suspend to debug)
13:32:51,675 DEBUG:	2024-02-14T14:29:25,872693+01:00 GPIO 5 is active: 0x10141b00
13:32:51,675 DEBUG:	2024-02-14T14:29:25,921821+01:00 wlp1s0: deauthenticating from 54:8a:ba:ca:ac:6e by local choice (Reason: 3=DEAUTH_LEAVING)
13:32:51,675 DEBUG:	2024-02-14T14:29:26,918423+01:00 PM: suspend of devices complete after 996.686 msecs
13:32:51,675 DEBUG:	2024-02-14T14:29:26,918435+01:00 PM: start suspend of devices complete after 1057.424 msecs
13:32:51,675 DEBUG:	2024-02-14T14:29:26,919226+01:00 Disabling GPIO #5 interrupt for suspend.
13:32:51,675 DEBUG:	2024-02-14T14:29:26,919252+01:00 Disabling GPIO #84 interrupt for suspend.
13:32:51,675 DEBUG:	2024-02-14T14:29:26,920366+01:00 PM: late suspend of devices complete after 1.926 msecs
13:32:51,675 DEBUG:	2024-02-14T14:29:26,920968+01:00 ACPI: EC: interrupt blocked
13:32:51,675 DEBUG:	2024-02-14T14:29:27,006458+01:00 PM: noirq suspend of devices complete after 85.919 msecs
13:32:51,675 DEBUG:	2024-02-14T14:29:27,006474+01:00 ACPI: \_SB_.PCI0.GPP0: LPI: Device not power manageable
13:32:51,675 DEBUG:	2024-02-14T14:29:27,006480+01:00 ACPI: \_SB_.PCI0.GPP2: LPI: Device not power manageable
13:32:51,675 DEBUG:	2024-02-14T14:29:27,006484+01:00 ACPI: \_SB_.PCI0.GPP6: LPI: Device not power manageable
13:32:51,675 DEBUG:	2024-02-14T14:29:27,006487+01:00 ACPI: \_SB_.PCI0.GPP5: LPI: Device not power manageable
13:32:51,675 DEBUG:	2024-02-14T14:29:27,006490+01:00 ACPI: \_SB_.PCI0.GPP7: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006494+01:00 ACPI: \_SB_.PCI0.GP11.SWUS: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006499+01:00 ACPI: \_SB_.PCI0.GP12.SWUS: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006503+01:00 ACPI: \_SB_.PCI0.GPP7.DEV0: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006507+01:00 ACPI: \_SB_.PCI0.GPP2.WWAN: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006510+01:00 ACPI: \_SB_.PCI0.GPP5.RTL8: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006513+01:00 ACPI: \_SB_.PCI0.GPP5.RUSB: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006517+01:00 ACPI: \_SB_.PCI0.GPP6.WLAN: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006525+01:00 ACPI: \_SB_.PCI0.GP18.IPU_: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006528+01:00 ACPI: \_SB_.PCI0.GP19.XHC2: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006534+01:00 ACPI: \_SB_.PLTF.C000: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006537+01:00 ACPI: \_SB_.PLTF.C001: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006540+01:00 ACPI: \_SB_.PLTF.C002: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006544+01:00 ACPI: \_SB_.PLTF.C003: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006547+01:00 ACPI: \_SB_.PLTF.C004: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006550+01:00 ACPI: \_SB_.PLTF.C005: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006553+01:00 ACPI: \_SB_.PLTF.C006: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006556+01:00 ACPI: \_SB_.PLTF.C007: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006559+01:00 ACPI: \_SB_.PLTF.C008: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006562+01:00 ACPI: \_SB_.PLTF.C009: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006565+01:00 ACPI: \_SB_.PLTF.C00A: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006569+01:00 ACPI: \_SB_.PLTF.C00B: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006572+01:00 ACPI: \_SB_.PLTF.C00C: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006575+01:00 ACPI: \_SB_.PLTF.C00D: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006578+01:00 ACPI: \_SB_.PLTF.C00E: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,006581+01:00 ACPI: \_SB_.PLTF.C00F: LPI: Device not power manageable
13:32:51,676 DEBUG:	2024-02-14T14:29:27,007522+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state screen off
13:32:51,676 DEBUG:	2024-02-14T14:29:27,226324+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 ms entry
13:32:51,676 DEBUG:	2024-02-14T14:29:27,227383+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 entry
13:32:51,676 DEBUG:	2024-02-14T14:29:27,228293+01:00 PM: suspend-to-idle
13:32:51,676 DEBUG:	2024-02-14T14:29:27,228296+01:00 amd_pmc: SMU idlemask s0i3: 0x3ffbbeb5
13:32:51,676 DEBUG:	2024-02-14T14:29:35,838009+01:00 Timekeeping suspended for 8.231 seconds
13:32:51,676 DEBUG:	2024-02-14T14:29:35,838055+01:00 PM: Triggering wakeup from IRQ 9
13:32:51,676 DEBUG:	2024-02-14T14:29:35,838147+01:00 ACPI: PM: ACPI fixed event wakeup
13:32:51,676 DEBUG:	2024-02-14T14:29:35,838154+01:00 PM: resume from suspend-to-idle
13:32:51,676 DEBUG:	2024-02-14T14:29:35,840052+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 exit
13:32:51,676 DEBUG:	2024-02-14T14:29:36,252796+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 ms exit
13:32:51,676 DEBUG:	2024-02-14T14:29:36,253404+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state screen on
13:32:51,677 DEBUG:	2024-02-14T14:29:36,253454+01:00 ACPI: EC: interrupt unblocked
13:32:51,677 DEBUG:	2024-02-14T14:29:36,435957+01:00 PM: noirq resume of devices complete after 182.546 msecs
13:32:51,677 DEBUG:	2024-02-14T14:29:36,439004+01:00 PM: early resume of devices complete after 2.825 msecs
13:32:51,677 DEBUG:	2024-02-14T14:29:36,500850+01:00 nvme nvme0: 16/0/0 default/read/poll queues
13:32:51,677 DEBUG:	2024-02-14T14:29:36,585398+01:00 [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
13:32:51,677 DEBUG:	2024-02-14T14:29:36,585708+01:00 [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
13:32:51,677 DEBUG:	2024-02-14T14:29:36,588139+01:00 [drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
13:32:51,677 DEBUG:	2024-02-14T14:29:36,588276+01:00 amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
13:32:51,677 DEBUG:	2024-02-14T14:29:36,592085+01:00 amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
13:32:51,677 DEBUG:	2024-02-14T14:29:36,592144+01:00 amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=4
13:32:51,677 DEBUG:	2024-02-14T14:29:36,620228+01:00 GPIO 5 is active: 0x10141b00
13:32:51,678 DEBUG:	2024-02-14T14:29:36,720603+01:00 GPIO 5 is active: 0x10141b00
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787469+01:00 [drm] VCN decode and encode initialized successfully(under DPG Mode).
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787581+01:00 amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787905+01:00 amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787909+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787911+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787913+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787915+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787916+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787918+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787920+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787922+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787923+01:00 amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787925+01:00 amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
13:32:51,678 DEBUG:	2024-02-14T14:29:36,787927+01:00 amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
13:32:51,679 DEBUG:	2024-02-14T14:29:36,787929+01:00 amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
13:32:51,679 DEBUG:	2024-02-14T14:29:36,793015+01:00 [drm] ring gfx_32791.1.1 was added
13:32:51,679 DEBUG:	2024-02-14T14:29:36,793623+01:00 [drm] ring compute_32791.2.2 was added
13:32:51,679 DEBUG:	2024-02-14T14:29:36,794146+01:00 [drm] ring sdma_32791.3.3 was added
13:32:51,679 DEBUG:	2024-02-14T14:29:36,794194+01:00 [drm] ring gfx_32791.1.1 ib test pass
13:32:51,679 DEBUG:	2024-02-14T14:29:36,794225+01:00 [drm] ring compute_32791.2.2 ib test pass
13:32:51,679 DEBUG:	2024-02-14T14:29:36,794338+01:00 [drm] ring sdma_32791.3.3 ib test pass
13:32:51,679 DEBUG:	2024-02-14T14:29:36,821008+01:00 GPIO 5 is active: 0x10141b00
13:32:51,679 DEBUG:	2024-02-14T14:29:36,906201+01:00 PM: resume of devices complete after 467.185 msecs
13:32:51,679 DEBUG:	2024-02-14T14:29:36,910434+01:00 OOM killer enabled.
13:32:51,679 DEBUG:	2024-02-14T14:29:36,910437+01:00 Restarting tasks ... done.
13:32:51,679 DEBUG:	2024-02-14T14:29:36,912305+01:00 random: crng reseeded on system resumption
13:32:51,679 DEBUG:	2024-02-14T14:29:36,925251+01:00 PM: suspend exit
13:32:51,679 DEBUG:	2024-02-14T14:29:37,467984+01:00 wlp1s0: authenticate with 54:8a:ba:ca:ac:61 (local address=14:ac:60:29:8c:31)
13:32:51,679 DEBUG:	2024-02-14T14:29:37,483136+01:00 wlp1s0: send auth to 54:8a:ba:ca:ac:61 (try 1/3)
13:32:51,679 DEBUG:	2024-02-14T14:29:37,486627+01:00 wlp1s0: authenticated
13:32:51,679 DEBUG:	2024-02-14T14:29:37,488811+01:00 wlp1s0: associate with 54:8a:ba:ca:ac:61 (try 1/3)
13:32:51,679 DEBUG:	2024-02-14T14:29:37,503489+01:00 wlp1s0: RX AssocResp from 54:8a:ba:ca:ac:61 (capab=0x1411 status=0 aid=1)
13:32:51,679 DEBUG:	2024-02-14T14:29:37,540205+01:00 wlp1s0: associated
13:32:51,679 DEBUG:	2024-02-14T14:29:37,685702+01:00 wlp1s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 54:8a:ba:ca:ac:61
13:32:51,679 DEBUG:	2024-02-14T14:29:41,622578+01:00 ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
13:32:51,679 DEBUG:	2024-02-14T14:29:51,156209+01:00 i2c_designware AMDI0010:00: i2c_dw_handle_tx_abort: lost arbitration
13:32:51,679 DEBUG:	2024-02-14T14:30:28,836688+01:00 PM: suspend entry (s2idle)
13:32:51,679 DEBUG:	2024-02-14T14:30:28,875970+01:00 Filesystems sync: 0.039 seconds
13:32:51,679 DEBUG:	2024-02-14T14:30:29,020027+01:00 Freezing user space processes
13:32:51,679 DEBUG:	2024-02-14T14:30:29,022558+01:00 Freezing user space processes completed (elapsed 0.002 seconds)
13:32:51,679 DEBUG:	2024-02-14T14:30:29,022565+01:00 OOM killer disabled.
13:32:51,679 DEBUG:	2024-02-14T14:30:29,022567+01:00 Freezing remaining freezable tasks
13:32:51,679 DEBUG:	2024-02-14T14:30:29,024113+01:00 Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
13:32:51,679 DEBUG:	2024-02-14T14:30:29,024119+01:00 printk: Suspending console(s) (use no_console_suspend to debug)
13:32:51,679 DEBUG:	2024-02-14T14:30:29,042386+01:00 wlp1s0: deauthenticating from 54:8a:ba:ca:ac:61 by local choice (Reason: 3=DEAUTH_LEAVING)
13:32:51,679 DEBUG:	2024-02-14T14:30:29,189944+01:00 PM: suspend of devices complete after 147.623 msecs
13:32:51,679 DEBUG:	2024-02-14T14:30:29,189955+01:00 PM: start suspend of devices complete after 165.763 msecs
13:32:51,679 DEBUG:	2024-02-14T14:30:29,190614+01:00 Disabling GPIO #5 interrupt for suspend.
13:32:51,679 DEBUG:	2024-02-14T14:30:29,190639+01:00 Disabling GPIO #84 interrupt for suspend.
13:32:51,679 DEBUG:	2024-02-14T14:30:29,191727+01:00 PM: late suspend of devices complete after 1.769 msecs
13:32:51,679 DEBUG:	2024-02-14T14:30:29,192275+01:00 ACPI: EC: interrupt blocked
13:32:51,679 DEBUG:	2024-02-14T14:30:29,269681+01:00 PM: noirq suspend of devices complete after 77.775 msecs
13:32:51,679 DEBUG:	2024-02-14T14:30:29,269706+01:00 ACPI: \_SB_.PCI0.GP11.SWUS: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,679 DEBUG:	2024-02-14T14:30:29,269714+01:00 ACPI: \_SB_.PCI0.GP12.SWUS: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,679 DEBUG:	2024-02-14T14:30:29,269720+01:00 ACPI: \_SB_.PCI0.GPP7.DEV0: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,679 DEBUG:	2024-02-14T14:30:29,269731+01:00 ACPI: \_SB_.PCI0.GP19.XHC2: LPI: Constraint not met; min power state:D3hot current power state:D0
13:32:51,679 DEBUG:	2024-02-14T14:30:29,270805+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state screen off
13:32:51,679 DEBUG:	2024-02-14T14:30:29,489603+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 ms entry
13:32:51,679 DEBUG:	2024-02-14T14:30:29,490293+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 entry
13:32:51,680 DEBUG:	2024-02-14T14:30:29,490747+01:00 PM: suspend-to-idle
13:32:51,680 DEBUG:	2024-02-14T14:30:29,490750+01:00 amd_pmc: SMU idlemask s0i3: 0x3ffbbeb5
13:32:51,680 DEBUG:	2024-02-14T14:31:28,652090+01:00 Timekeeping suspended for 59.347 seconds
13:32:51,680 DEBUG:	2024-02-14T14:31:28,652128+01:00 PM: Triggering wakeup from IRQ 9
13:32:51,680 DEBUG:	2024-02-14T14:31:28,652189+01:00 ACPI: PM: ACPI fixed event wakeup
13:32:51,680 DEBUG:	2024-02-14T14:31:28,652192+01:00 PM: resume from suspend-to-idle
13:32:51,680 DEBUG:	2024-02-14T14:31:28,652909+01:00 amd_pmc AMDI0009:00: Last suspend didn't reach deepest state
13:32:51,680 DEBUG:	2024-02-14T14:31:28,653944+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 exit
13:32:51,680 DEBUG:	2024-02-14T14:31:28,834400+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 ms exit
13:32:51,680 DEBUG:	2024-02-14T14:31:28,835009+01:00 ACPI: \_SB_.PEP_: Successfully transitioned to state screen on
13:32:51,680 DEBUG:	2024-02-14T14:31:28,835065+01:00 ACPI: EC: interrupt unblocked
13:32:51,680 DEBUG:	2024-02-14T14:31:29,024264+01:00 PM: noirq resume of devices complete after 189.248 msecs
13:32:51,680 DEBUG:	2024-02-14T14:31:29,027116+01:00 PM: early resume of devices complete after 2.645 msecs
13:32:51,680 DEBUG:	2024-02-14T14:31:29,030442+01:00 [drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
13:32:51,680 DEBUG:	2024-02-14T14:31:29,031526+01:00 amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
13:32:51,680 DEBUG:	2024-02-14T14:31:29,033453+01:00 amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
13:32:51,680 DEBUG:	2024-02-14T14:31:29,033521+01:00 amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=4
13:32:51,680 DEBUG:	2024-02-14T14:31:29,094335+01:00 nvme nvme0: 16/0/0 default/read/poll queues
13:32:51,680 DEBUG:	2024-02-14T14:31:29,181791+01:00 [drm] VCN decode and encode initialized successfully(under DPG Mode).
13:32:51,680 DEBUG:	2024-02-14T14:31:29,181937+01:00 amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182284+01:00 amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182288+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182291+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182293+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182295+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182296+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182298+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182300+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182302+01:00 amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182304+01:00 amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182306+01:00 amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182308+01:00 amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
13:32:51,680 DEBUG:	2024-02-14T14:31:29,182310+01:00 amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
13:32:51,680 DEBUG:	2024-02-14T14:31:29,187436+01:00 [drm] ring gfx_32791.1.1 was added
13:32:51,680 DEBUG:	2024-02-14T14:31:29,188029+01:00 [drm] ring compute_32791.2.2 was added
13:32:51,680 DEBUG:	2024-02-14T14:31:29,188556+01:00 [drm] ring sdma_32791.3.3 was added
13:32:51,680 DEBUG:	2024-02-14T14:31:29,188605+01:00 [drm] ring gfx_32791.1.1 ib test pass
13:32:51,680 DEBUG:	2024-02-14T14:31:29,188642+01:00 [drm] ring compute_32791.2.2 ib test pass
13:32:51,680 DEBUG:	2024-02-14T14:31:29,188719+01:00 [drm] ring sdma_32791.3.3 ib test pass
13:32:51,680 DEBUG:	2024-02-14T14:31:29,207508+01:00 GPIO 5 is active: 0x10141b00
13:32:51,680 DEBUG:	2024-02-14T14:31:29,299193+01:00 PM: resume of devices complete after 272.065 msecs
13:32:51,680 DEBUG:	2024-02-14T14:31:29,303425+01:00 OOM killer enabled.
13:32:51,680 DEBUG:	2024-02-14T14:31:29,303429+01:00 Restarting tasks ... done.
13:32:51,680 DEBUG:	2024-02-14T14:31:29,305323+01:00 random: crng reseeded on system resumption
13:32:51,680 DEBUG:	2024-02-14T14:31:29,315563+01:00 PM: suspend exit
13:32:51,680 DEBUG:	2024-02-14T14:31:29,849775+01:00 wlp1s0: authenticate with 54:8a:ba:ca:ac:6e (local address=14:ac:60:29:8c:31)
13:32:51,681 DEBUG:	2024-02-14T14:31:29,865997+01:00 wlp1s0: send auth to 54:8a:ba:ca:ac:6e (try 1/3)
13:32:51,681 DEBUG:	2024-02-14T14:31:29,869377+01:00 wlp1s0: authenticated
13:32:51,681 DEBUG:	2024-02-14T14:31:29,870408+01:00 wlp1s0: associate with 54:8a:ba:ca:ac:6e (try 1/3)
13:32:51,681 DEBUG:	2024-02-14T14:31:29,890842+01:00 wlp1s0: RX AssocResp from 54:8a:ba:ca:ac:6e (capab=0x1111 status=0 aid=4)
13:32:51,681 DEBUG:	2024-02-14T14:31:29,932371+01:00 wlp1s0: associated
13:32:51,681 DEBUG:	2024-02-14T14:31:29,952673+01:00 wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 54:8a:ba:ca:ac:6e
13:32:51,681 DEBUG:
13:32:51,681 INFO:	○ Suspend count: 2
13:32:51,681 INFO:	○ Hardware sleep cycle count: 2
13:32:51,681 INFO:	○ GPIOs active: ['5', '5', '5', '5', '5']
13:32:51,681 INFO:	○ Wakeups triggered from IRQs: [9]
13:32:51,681 DEBUG:	Used Microsoft uPEP GUID in LPS0 _DSM
13:32:51,681 INFO:	○ Woke up from IRQ 9 (IR-IO-APIC 9-fasteoi acpi)
13:32:51,682 INFO:	○ gpe0B increased from 245 to 253
13:32:51,683 DEBUG:	ACPI Lid (proc/acpi/button/lid/LID0/state): open
13:32:51,683 INFO:	✅ Userspace suspended for 0:01:02.686064
13:32:51,683 DEBUG:	Kernel suspended for total of 0:01:07.578000 (107.80%)
13:32:51,683 WARNING:	Unable to gather hardware sleep data with lockdown engaged
13:32:51,686 DEBUG:	BAT1 charge level is 3055000 µAh
13:32:51,686 INFO:	🔋 Battery BAT1 ( ) is operating at 98.26% of design
If I recall, that’s a known issue with the forum software. Backslash proc not being allowed.
I’m not sure why you can’t get the hardware sleep numbers. Do you not have a /sys/power/suspend_stats/last_hw_sleep? Can you manually read that?
I’m not sure why that didn’t work. I actually ran your script twice, and the first time it did work:
✅ LPS0 _DSM enabled
Started at 2024-02-14 13:30:46.219680 (cycle finish expected @ 2024-02-14 13:31:00.219700)
○ Suspend count: 1
○ Hardware sleep cycle count: 1
○ GPIOs active: ['5', '5', '5', '5']
○ gpe0B increased from 237 to 245
✅ Userspace suspended for 0:00:12.886118
✅ In a hardware sleep state for 0:00:08.107391 (62.92%)
But when I try to run your script again now, I keep getting:
cat /sys/power/suspend_stats/last_hw_sleep gives me 0
All the files in /sys/power/suspend_stats/ were last modified just now (when I ran your script again), except last_hw_sleep, which was last modified 13:30 today (the first time I ran your script).
I wonder if your not using systemd is throwing the script off. There have been other different weirdness without systemd reported.
Can you please before bed try a fresh boot and then program the script for longer than you’re going to sleep and report back the specific result from that?
Will do tonight.
Why would you say that I am not using systemd? As far I can tell, OpenSUSE uses systemd, and ps --no-headers -o comm 1 returns systemd. (And also, the very first line from journalctl that I included in my initial post is from systemd.)
The script output above says it’s capturing from dmesg instead of systemd.
I suspect you’re missing the python library that lets you access the journal. Can you look for that? If you find it can you please tell me the package name used by your distro? I should modify the script to try to install it if missing.
I see what you mean now, sorry! I ran your script from a micromamba (=conda) environment, because I prefer to manage my Python environments that way. So I had to pip install systemd-python (it’s not (yet) in conda-forge).
Now I get the following output:
Location of log file (default s2idle_report-2024-02-15.txt)?
🔋 Battery BAT1 ( ) is operating at 98.08% of design
✅ Logs are provided via systemd
✅ LPS0 _DSM enabled
Started at 2024-02-15 14:18:40.970888 (cycle finish expected @ 2024-02-15 14:18:54.970905)
○ Suspend count: 1
○ GPIOs active: ['5', '5', '5']
○ gpe0B increased from 169 to 177
✅ Userspace suspended for 0:00:12.132567
✅ In a hardware sleep state for 0:00:08.187805 (67.49%)
Also, I rebooted this morning, and I’m not now able to reproduce the not entering hardware sleep part from yesterday.
Okay, glad we got to the bottom of that. If you reproduce the issue under the context of the script share the report. In that case need to see whole report not just the summary.
Following.
As Mario indicated, if you are able to repro this please share the report.
