FW 13 using Ubuntu 22.04LTS on the recommended kernel
When running sudo apt update and then sudo apt upgrade I get this message in the terminal:
The following packages were automatically installed and are no longer required:
linux-headers-6.5.0-18-generic linux-hwe-6.5-headers-6.5.0-18 linux-image-6.5.0-18-generic
linux-modules-6.5.0-18-generic linux-modules-extra-6.5.0-18-generic
Use 'sudo apt autoremove' to remove them.
Being fairly new to linux, is that command something I should indeed be running?
The only downside is that, if you have any problems with the current kernel, you won’t have that older one to fall back on.
That said, I’ve been running Linux as my daily driver for seventeen years now, and problems requiring dropping back to an older kernel have been very rare. Don’t think I’ve had one in the last decade, so you’re probably safe doing so.
The autoremove command will always leave at least one other kernel available for backup/faisafe. In case of real emergency though, you can always boot from a live USB stick and repaire the drives etc.
