[RESPONDED] CPU gets stuck at 0.2 GHz
@Dennis_Miller Now I’m afraid I didn’t test turning them off individually to see which one might be the offending one, but did you turn them all off/down like in my post? Just curious because I want to help, and turning them all off may be the factor in keeping this problem from restarting.
I stumbled across this thread from AskUbtuntu - 22.04 runs too slow and it looks like I’m suffering from the same issue. I originally thought that it was just 22.04 being terrible, but several different tools report the same issues others are reporting.
I have a Batch #3 | 12th gen - i7 1280p machine with 64 GB of RAM running Ubuntu 22.04.
The issues are painfully noticeable on any Electron Apps, and reporting tools won’t show my Frequencies at above 400 MHz. I didn’t catch it sooner because System Monitor shows everything as a percentage, and I guess everything was just as a percentage of 400 MHz instead of 4.8 GHz.
That’s quite harsh of you to say so! What arguments do you have to support this?
If it were really so many people having this issue, don’t you think that they would make it their number #1 priority?
There are a lot of issues currently on the framework laptop. Battery draining (both normal and CMOS) and CPUs overheating/underperforming are just some of them.
I just bought my framework even though I know these issues can and probably will arise because I support the statement framework has, not because I want the latest tech that is 100% reliable.
It sucks to not be able to use a product 100%, but if you really have such big issues and your support ticket is going nowhere I suggest to ask for a refund and try a framework at a later time in your life.
Did you check out the latest bios update to see if it has any changes?
Update–I seem to have fixed the problem by replacing the paste on the CPU. It has been running perfectly for two days now, and I’m starting to think it will be ok. When I removed the heat pipe, it looked like an excessive amount of paste on the CPU–very thick. The paste instructions usually specify a minimum amount of paste. I spread it very thinly and reassembled, and it has been perfect since. I may have reset the CMOS batt also by accident. I didn’t see a good way to remove it but moved it around–may have momentarily disconnected. Later realized most MBs have a switch to reset CMOS but have not bothered to research that for this MB. I also reset the BIOS to Optimal, removing all changes. The computer still gets very hot, and the fan still does not come on. Have ordered a new fan, should be here tomorrow. Temps show very high, near max, but still working fine, but I just do internet and email–no gaming, etc. I don’t think BIOS mods will help this issue long-term.
@Dennis_Miller Fair enough, glad to hear that you found an option that works for you! Hope it continues to work well and that the new fan helps!
Update:
I ended up opening a support ticket and followed all of the steps to no avail. It was the final, last-ditch, recommendation that’s seemingly fixed everything.
A hard CMOS reset by taking the battery out for 15 mins (read, like 2 hours) then putting it back in. The subsequent boot was near instantaneous.
Upon starting back up, Discord (kill me) started up almost instantly and my Chrome (still kill me) tabs are actually responsive. I can hear my fans on, and my cope command: sudo watch cpupower monitor is reporting numbers far above 400 all across the board.
System Monitor is also reporting far lower percentages all across the board, which I find incredibly interesting. I guess something must have been screwed up from the get-go and everything was just as a fraction of either 400 MHz or some equally terrible number.
I just pray that the issue doesn’t decide to rear its ugly head again the moment I close my ticket.
I notice that @Dennis_Miller mentioned that they may have also reset the CMOS battery so I wonder if that’s some sort of commonality.
After seeing Yoshiko’s post, I think that the issue may be somehow resolved with a CMOS reset only. For those still struggling with this issue, give it a try. It is not necessary to wait 15 minutes. This is a myth widely believed on the internet. I won’t go into the tech reasons, but a momentary disconnect is all that is necessary to reset the CMOS circuit. All I did was push the CMOS batt down for a second, breaking the connection with the top contacts. I wasn’t sure that would work, but apparently, it did. Removing the batt for a sec would be better, more certain. I’m still wondering if there is a CMOS reset button or switch on the mobo.
Since the repair, the computer works WAY better than it ever had. My boots are also very fast now. I had upgraded to bios 3.10 and installed win 11 22H2 update. Still, the paste seemed excessive and there was a big crack in the paste down the middle of the processor, which may have caused problems. Thinner is better.
Removing the CMOS Battery fixing it makes sense, because it resets the BIOS to Factory settings and somehow resets the issue, It’s interesting that there’s more paste than needed though…
Update
A week later, still working fine. Resetting BIOS seemed to do the trick. Very fast now.
I guess I am not affected :slight_smile:
You can run this with watch to see how CPUs behave.
grep 'MHz' /proc/cpuinfo
cpu MHz         : 533.456
cpu MHz         : 2100.000
cpu MHz         : 485.018
cpu MHz         : 684.178
cpu MHz         : 859.227
cpu MHz         : 1400.000
cpu MHz         : 2100.000
cpu MHz         : 2100.000
cpu MHz         : 465.049
cpu MHz         : 2100.000
cpu MHz         : 2100.000
cpu MHz         : 2100.000
cpu MHz         : 2100.000
cpu MHz         : 2100.000
cpu MHz         : 2100.000
cpu MHz         : 2100.000
I’ve been battling this for a while now… For some reason it seems to happen more with 3rd party power bricks than with the OEM one…
On Ubuntu 20.04 it was happening pretty constantly for me, after doing a clean install to 22.04 it seemed to not be happening as much, but lately it’s been so bad. I wish there was a solution to this…
I will say, trying ThrottleStop out it actually seems to help a lot, it still slows down occasionally while playing games, when the CPU gets too hot, but letting it sit for a few minutes returns it to normal…
I currently have BD PROCHOT and Speedstep turned off… Hope this helps somebody!
Has anyone found any solution? It’s happening allot it’s hard to play games. For others how fast are fan speeds when this happens? For me there’s no fan spin up.
Solution is: Contact support.
Solution is indeed going to likely be support and asking for new thermal paste.
I’ve had my CPU throttle to 200MHz with no thermal issues whatsoever, BIOS and CPU microcode up to date.
I unplugged the Displayport expansion card and the issue disappeared. It’s a first gen card with an updated 2nd gen firmware.
Welcome to the community @ldesgoui,
You will need to reach out to support for this as we’ll need to troubleshoot this further.
I’ve also run into this. When battery runs low it seems to switch into 0.2 GHz mode, but never switches back. Removing/replacing CMOS battery fixes it.
Framework 13: w/ 11thGen Intel
Here is my situation and solution:
Framework 13 w/11th gen Intel
Cooler Master Mainboard Case
Tried repaste, didn’t fix but made better.
Watched with MSI afterburner, looked at GPU Usage, temperature, and Wattage
-Noticed that the thermals were up to 70 C, dusted out and went down to 50 and problem went away.
Had same issue CPU locked at 0.2GHz seemingly randomly did happen after fairly extended use on a warm day I checked and there was a BIOS update and after running that it fixed it for me. Intel 11th Gen i5 running Win 11 Pro. -\_(--)_/-
