Just had the dock disconnect (not the monitor, that’s plugged in seperate). This is the output of journalctl:
Mar 10 15:58:11 framevirgin kernel: usb 3-2: USB disconnect, device number 21
Mar 10 15:58:11 framevirgin kernel: usb 3-2.3: USB disconnect, device number 22
Mar 10 15:58:11 framevirgin kernel: usb 3-2.3.3: USB disconnect, device number 24
Mar 10 15:58:11 framevirgin kernel: usb 2-1: USB disconnect, device number 14
Mar 10 15:58:11 framevirgin kernel: usb 2-1.2: USB disconnect, device number 15
Mar 10 15:58:11 framevirgin kernel: cdc_ncm 2-1.2:2.0 enp0s13f0u1u2c2: unregister 'cdc_ncm' usb-0000:00:0d.0-1.2, CDC NCM (NO ZLP)
Mar 10 15:58:11 framevirgin kernel: usb 3-2.4: USB disconnect, device number 23
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Interface enp0s13f0u1u2c2.IPv6 no longer relevant for mDNS.
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Leaving mDNS multicast group on interface enp0s13f0u1u2c2.IPv6 with address 2603:6080:4ef0:6ea0:7dee:b7b2:810e:a602.
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Interface enp0s13f0u1u2c2.IPv4 no longer relevant for mDNS.
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Leaving mDNS multicast group on interface enp0s13f0u1u2c2.IPv4 with address 192.168.1.240.
Mar 10 15:58:11 framevirgin NetworkManager[726]: <info> [1710100691.8485] device (enp0s13f0u1u2c2): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Withdrawing address record for 2603:6080:4ef0:6ea0::1f45 on enp0s13f0u1u2c2.
Mar 10 15:58:11 framevirgin NetworkManager[726]: <info> [1710100691.8487] dhcp4 (enp0s13f0u1u2c2): canceled DHCP transaction
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Withdrawing address record for fd00:5cfa:25df:2993::1f45 on enp0s13f0u1u2c2.
Mar 10 15:58:11 framevirgin NetworkManager[726]: <info> [1710100691.8487] dhcp4 (enp0s13f0u1u2c2): activation: beginning transaction (timeout in 45 seconds)
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Withdrawing address record for fd00:5cfa:25df:2993:7f67:97e1:3c8f:5f38 on enp0s13f0u1u2c2.
Mar 10 15:58:11 framevirgin NetworkManager[726]: <info> [1710100691.8487] dhcp4 (enp0s13f0u1u2c2): state changed no lease
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Withdrawing address record for 2603:6080:4ef0:6ea0:7dee:b7b2:810e:a602 on enp0s13f0u1u2c2.
Mar 10 15:58:11 framevirgin NetworkManager[726]: <info> [1710100691.8489] dhcp6 (enp0s13f0u1u2c2): canceled DHCP transaction
Mar 10 15:58:11 framevirgin avahi-daemon[661]: Withdrawing address record for 192.168.1.240 on enp0s13f0u1u2c2.
Mar 10 15:58:11 framevirgin NetworkManager[726]: <info> [1710100691.8489] dhcp6 (enp0s13f0u1u2c2): activation: beginning transaction (timeout in 45 seconds)
Mar 10 15:58:11 framevirgin NetworkManager[726]: <info> [1710100691.8489] dhcp6 (enp0s13f0u1u2c2): state changed no lease
Mar 10 15:58:11 framevirgin systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 10 15:58:11 framevirgin kernel: usb 2-1.3: USB disconnect, device number 16
Mar 10 15:58:11 framevirgin kernel: usb 2-1.3.2: USB disconnect, device number 17
Mar 10 15:58:11 framevirgin systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 10 15:58:12 framevirgin kernel: usb 2-1.3.3: USB disconnect, device number 18
Mar 10 15:58:12 framevirgin kernel: usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 19 using xhci_hcd
Mar 10 15:58:12 framevirgin kernel: usb 3-2: new high-speed USB device number 25 using xhci_hcd
Mar 10 15:58:12 framevirgin kernel: usb 2-1: New USB device found, idVendor=291a, idProduct=8392, bcdDevice= 7.73
Mar 10 15:58:12 framevirgin kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 10 15:58:12 framevirgin kernel: usb 2-1: Product: Anker USB-C Docking Device
Mar 10 15:58:12 framevirgin kernel: usb 2-1: Manufacturer: Anker
Mar 10 15:58:12 framevirgin kernel: usb 2-1: SerialNumber: 000000001
Mar 10 15:58:12 framevirgin kernel: hub 2-1:1.0: USB hub found
Mar 10 15:58:12 framevirgin kernel: hub 2-1:1.0: 4 ports detected
Mar 10 15:58:13 framevirgin kernel: usb 3-2: New USB device found, idVendor=291a, idProduct=8392, bcdDevice= 7.73
Mar 10 15:58:13 framevirgin kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 10 15:58:13 framevirgin kernel: usb 3-2: Product: Anker USB-C Docking Device
Mar 10 15:58:13 framevirgin kernel: usb 3-2: Manufacturer: Anker
Mar 10 15:58:13 framevirgin kernel: usb 3-2: SerialNumber: 000000001
Mar 10 15:58:13 framevirgin kernel: hub 3-2:1.0: USB hub found
Mar 10 15:58:13 framevirgin kernel: hub 3-2:1.0: 4 ports detected
Mar 10 15:58:13 framevirgin kernel: usb 2-1.3: new SuperSpeed USB device number 20 using xhci_hcd
Mar 10 15:58:13 framevirgin kernel: usb 2-1.3: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23
Mar 10 15:58:13 framevirgin kernel: usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 10 15:58:13 framevirgin kernel: usb 2-1.3: Product: USB3.0 Hub
Mar 10 15:58:13 framevirgin kernel: usb 2-1.3: Manufacturer: VIA Labs, Inc.
Mar 10 15:58:13 framevirgin kernel: usb 2-1.3: SerialNumber: 000000000
Mar 10 15:58:13 framevirgin kernel: hub 2-1.3:1.0: USB hub found
Mar 10 15:58:13 framevirgin kernel: hub 2-1.3:1.0: 4 ports detected
Mar 10 15:58:13 framevirgin kernel: usb 3-2: USB disconnect, device number 25
Mar 10 15:58:13 framevirgin kernel: usb 3-2-port2: attempt power cycle
Mar 10 15:58:14 framevirgin kernel: hub 2-1.3:1.0: hub_ext_port_status failed (err = -71)
Mar 10 15:58:14 framevirgin kernel: usb 2-1.3: Failed to suspend device, error -71
Mar 10 15:58:14 framevirgin kernel: usb 2-1: USB disconnect, device number 19
Mar 10 15:58:14 framevirgin kernel: usb 2-1.3: USB disconnect, device number 20
Mar 10 15:58:14 framevirgin kernel: xhci_hcd 0000:00:0d.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
Mar 10 15:58:14 framevirgin gnome-shell[1424]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Mar 10 15:58:15 framevirgin kernel: usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 21 using xhci_hcd
Mar 10 15:58:15 framevirgin kernel: usb 2-1: New USB device found, idVendor=291a, idProduct=8392, bcdDevice= 7.73
Mar 10 15:58:15 framevirgin kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 10 15:58:15 framevirgin kernel: usb 2-1: Product: Anker USB-C Docking Device
Mar 10 15:58:15 framevirgin kernel: usb 2-1: Manufacturer: Anker
Mar 10 15:58:15 framevirgin kernel: usb 2-1: SerialNumber: 000000001
Mar 10 15:58:15 framevirgin kernel: hub 2-1:1.0: USB hub found
Mar 10 15:58:15 framevirgin kernel: hub 2-1:1.0: 4 ports detected
Mar 10 15:58:15 framevirgin kernel: usb 3-2: new high-speed USB device number 30 using xhci_hcd
Mar 10 15:58:15 framevirgin kernel: usb 3-2: New USB device found, idVendor=291a, idProduct=8392, bcdDevice= 7.73
Mar 10 15:58:15 framevirgin kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 10 15:58:15 framevirgin kernel: usb 3-2: Product: Anker USB-C Docking Device
Mar 10 15:58:15 framevirgin kernel: usb 3-2: Manufacturer: Anker
Mar 10 15:58:15 framevirgin kernel: usb 3-2: SerialNumber: 000000001
Mar 10 15:58:15 framevirgin kernel: hub 3-2:1.0: USB hub found
Mar 10 15:58:15 framevirgin kernel: hub 3-2:1.0: 4 ports detected
Mar 10 15:58:15 framevirgin kernel: usb 2-1.2: new SuperSpeed USB device number 22 using xhci_hcd
Mar 10 15:58:16 framevirgin kernel: usb 2-1.2: New USB device found, idVendor=0b95, idProduct=1790, bcdDevice= 2.00
Mar 10 15:58:16 framevirgin kernel: usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 10 15:58:16 framevirgin kernel: usb 2-1.2: Product: AX88179A
Mar 10 15:58:16 framevirgin kernel: usb 2-1.2: Manufacturer: ASIX
Mar 10 15:58:16 framevirgin kernel: usb 2-1.2: SerialNumber: 00000000000001
for some reason it seems to have disconnected?
