Hey there,
I bought a UGREEN Revodok Pro 313 USB C.
I’m currently running Ubuntu 22.04 with - as of now - all updates installed.
If i connect the ugreen dock while booting, the system gets slow to a point where it takes like 5 minutes to boot.
Also I’m using the 180W charging brick i bought with the laptop
I already did some reseach, but cannot figure out what to do with these infos.
This is the dmesg output of plugging in the dock WITHOUT power connected to the dock:
[ 1338.449303] usb 5-1: new high-speed USB device number 21 using xhci_hcd
[ 1338.488442] ucsi_acpi USBC000:00: unknown error 0
[ 1338.488452] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
[ 1338.581820] usb 5-1: New USB device found, idVendor=2109, idProduct=2822, bcdDevice= 7.64
[ 1338.581833] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1338.581840] usb 5-1: Product: USB2.0 Hub
[ 1338.581844] usb 5-1: Manufacturer: VIA Labs, Inc.
[ 1338.618000] hub 5-1:1.0: USB hub found
[ 1338.618407] hub 5-1:1.0: 5 ports detected
[ 1339.056751] usb 6-1: new SuperSpeed Plus Gen 2x1 USB device number 18 using xhci_hcd
[ 1339.147230] usb 6-1: New USB device found, idVendor=2109, idProduct=0822, bcdDevice= 7.64
[ 1339.147238] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1339.147240] usb 6-1: Product: USB3.1 Hub
[ 1339.147242] usb 6-1: Manufacturer: VIA Labs, Inc.
[ 1339.178305] hub 6-1:1.0: USB hub found
[ 1339.178459] hub 6-1:1.0: 4 ports detected
[ 1339.678314] usb 5-1.2: new high-speed USB device number 22 using xhci_hcd
[ 1339.777207] usb 5-1.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 1339.777217] usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1339.777221] usb 5-1.2: Product: USB2.1 Hub
[ 1339.777225] usb 5-1.2: Manufacturer: GenesysLogic
[ 1339.832884] hub 5-1.2:1.0: USB hub found
[ 1339.833440] hub 5-1.2:1.0: 4 ports detected
[ 1339.839662] usb 6-1.2: new SuperSpeed USB device number 19 using xhci_hcd
[ 1339.859333] usb 6-1.2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[ 1339.859342] usb 6-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1339.859346] usb 6-1.2: Product: USB3.1 Hub
[ 1339.859349] usb 6-1.2: Manufacturer: GenesysLogic
[ 1339.881579] hub 6-1.2:1.0: USB hub found
[ 1339.882373] hub 6-1.2:1.0: 4 ports detected
[ 1339.919324] usb 5-1.5: new high-speed USB device number 23 using xhci_hcd
[ 1339.999828] usb 5-1.5: New USB device found, idVendor=2109, idProduct=8822, bcdDevice= 0.01
[ 1339.999838] usb 5-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1339.999843] usb 5-1.5: Product: USB Billboard Device
[ 1339.999847] usb 5-1.5: Manufacturer: VIA Labs, Inc.
[ 1339.999850] usb 5-1.5: SerialNumber: 0000000000000001
[ 1340.136351] usb 5-1.2.3: new high-speed USB device number 24 using xhci_hcd
[ 1340.244475] usb 5-1.2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=61.90
[ 1340.244489] usb 5-1.2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1340.244496] usb 5-1.2.3: Product: USB2.0 Hub
[ 1340.281273] hub 5-1.2.3:1.0: USB hub found
[ 1340.281844] hub 5-1.2.3:1.0: 4 ports detected
[ 1340.306836] usb 6-1.2.2: new SuperSpeed USB device number 20 using xhci_hcd
[ 1340.323235] usb 6-1.2.2: New USB device found, idVendor=05e3, idProduct=0749, bcdDevice=15.39
[ 1340.323243] usb 6-1.2.2: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[ 1340.323247] usb 6-1.2.2: Product: USB3.0 Card Reader
[ 1340.323250] usb 6-1.2.2: Manufacturer: Generic
[ 1340.323253] usb 6-1.2.2: SerialNumber: 000000001539
[ 1340.324098] usb-storage 6-1.2.2:1.0: USB Mass Storage device detected
[ 1340.324372] scsi host0: usb-storage 6-1.2.2:1.0
[ 1340.389461] usb 6-1.2.3: new SuperSpeed USB device number 21 using xhci_hcd
[ 1340.401854] usb 6-1.2.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
[ 1340.401863] usb 6-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=7
[ 1340.401867] usb 6-1.2.3: Product: USB 10/100/1000 LAN
[ 1340.401871] usb 6-1.2.3: Manufacturer: Realtek
[ 1340.401874] usb 6-1.2.3: SerialNumber: 001300E04CA51820
[ 1340.536736] r8152-cfgselector 6-1.2.3: reset SuperSpeed USB device number 21 using xhci_hcd
[ 1340.584719] r8152 6-1.2.3:1.0: load rtl8153b-2 v2 04/27/23 successfully
[ 1340.612012] r8152 6-1.2.3:1.0 eth0: v1.12.13
[ 1340.613354] usb 5-1.2.3.1: new high-speed USB device number 25 using xhci_hcd
[ 1340.628345] r8152 6-1.2.3:1.0 enx00e04ca51820: renamed from eth0
[ 1340.706841] usb 5-1.2.3.1: New USB device found, idVendor=0bda, idProduct=4ef0, bcdDevice= 0.04
[ 1340.706847] usb 5-1.2.3.1: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 1340.706848] usb 5-1.2.3.1: Product: USB Audio
[ 1340.706850] usb 5-1.2.3.1: Manufacturer: Generic
[ 1340.767553] input: Generic USB Audio Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.2/5-1.2.3/5-1.2.3.1/5-1.2.3.1:1.0/0003:0BDA:4EF0.0018/input/input41
[ 1340.819608] input: Generic USB Audio as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.2/5-1.2.3/5-1.2.3.1/5-1.2.3.1:1.0/0003:0BDA:4EF0.0018/input/input42
[ 1340.819970] hid-generic 0003:0BDA:4EF0.0018: input,hiddev6,hidraw13: USB HID v1.11 Device [Generic USB Audio] on usb-0000:c3:00.3-1.2.3.1/input0
This is the output if i connect and then disconnect the dock WITH POWER ALREADY PLUGGED INTO THE DOCK
[ 1578.776109] usb 5-1: new high-speed USB device number 26 using xhci_hcd
[ 1578.906141] usb 5-1: New USB device found, idVendor=2109, idProduct=2822, bcdDevice= 7.64
[ 1578.906150] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1578.906154] usb 5-1: Product: USB2.0 Hub
[ 1578.906157] usb 5-1: Manufacturer: VIA Labs, Inc.
[ 1578.944484] hub 5-1:1.0: USB hub found
[ 1578.945031] hub 5-1:1.0: 5 ports detected
[ 1578.953537] ucsi_acpi USBC000:00: unknown error 0
[ 1578.953549] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
[ 1579.020500] usb 6-1: new SuperSpeed Plus Gen 2x1 USB device number 22 using xhci_hcd
[ 1579.028561] workqueue: acpi_ec_event_processor hogged CPU for >10000us 11 times, consider switching to WQ_UNBOUND
[ 1579.106639] usb 6-1: New USB device found, idVendor=2109, idProduct=0822, bcdDevice= 7.64
[ 1579.106814] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1579.106902] usb 6-1: Product: USB3.1 Hub
[ 1579.106979] usb 6-1: Manufacturer: VIA Labs, Inc.
[ 1579.681497] hub 6-1:1.0: USB hub found
[ 1579.687309] hub 6-1:1.0: 4 ports detected
[ 1580.048837] usb 5-1.2: new high-speed USB device number 27 using xhci_hcd
[ 1580.150386] usb 5-1.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 1580.150809] usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1580.150905] usb 5-1.2: Product: USB2.1 Hub
[ 1580.150985] usb 5-1.2: Manufacturer: GenesysLogic
[ 1580.224694] hub 5-1.2:1.0: USB hub found
[ 1580.230927] hub 5-1.2:1.0: 4 ports detected
[ 1580.327851] usb 5-1.5: new high-speed USB device number 28 using xhci_hcd
[ 1580.424137] usb 5-1.5: New USB device found, idVendor=2109, idProduct=8822, bcdDevice= 0.01
[ 1580.424316] usb 5-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1580.424406] usb 5-1.5: Product: USB Billboard Device
[ 1580.424488] usb 5-1.5: Manufacturer: VIA Labs, Inc.
[ 1580.424894] usb 5-1.5: SerialNumber: 0000000000000001
[ 1580.494345] usb 6-1.2: new SuperSpeed USB device number 23 using xhci_hcd
[ 1580.544610] usb 6-1.2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[ 1580.544750] usb 6-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1580.544828] usb 6-1.2: Product: USB3.1 Hub
[ 1580.544896] usb 6-1.2: Manufacturer: GenesysLogic
[ 1580.604817] usb 5-1.2.3: new high-speed USB device number 29 using xhci_hcd
[ 1580.714347] hub 6-1.2:1.0: USB hub found
[ 1580.718728] hub 6-1.2:1.0: 4 ports detected
[ 1580.855315] usb 5-1.2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=61.90
[ 1580.855500] usb 5-1.2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1580.855953] usb 5-1.2.3: Product: USB2.0 Hub
[ 1581.057779] hub 5-1.2.3:1.0: USB hub found
[ 1581.059011] hub 5-1.2.3:1.0: 4 ports detected
[ 1581.153808] usb 6-1.2.2: new SuperSpeed USB device number 24 using xhci_hcd
[ 1581.178076] usb 6-1.2.2: New USB device found, idVendor=05e3, idProduct=0749, bcdDevice=15.39
[ 1581.178224] usb 6-1.2.2: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[ 1581.178320] usb 6-1.2.2: Product: USB3.0 Card Reader
[ 1581.178399] usb 6-1.2.2: Manufacturer: Generic
[ 1581.178482] usb 6-1.2.2: SerialNumber: 000000001539
[ 1581.326896] usb-storage 6-1.2.2:1.0: USB Mass Storage device detected
[ 1581.362802] scsi host0: usb-storage 6-1.2.2:1.0
[ 1581.372464] usb 5-1.2.3.1: new high-speed USB device number 30 using xhci_hcd
[ 1581.470833] usb 5-1.2.3.1: New USB device found, idVendor=0bda, idProduct=4ef0, bcdDevice= 0.04
[ 1581.470999] usb 5-1.2.3.1: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 1581.471067] usb 5-1.2.3.1: Product: USB Audio
[ 1581.471133] usb 5-1.2.3.1: Manufacturer: Generic
[ 1581.633143] usb 6-1.2.3: new SuperSpeed USB device number 25 using xhci_hcd
[ 1581.651198] usb 6-1.2.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
[ 1581.651349] usb 6-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=7
[ 1581.651442] usb 6-1.2.3: Product: USB 10/100/1000 LAN
[ 1581.651519] usb 6-1.2.3: Manufacturer: Realtek
[ 1581.651866] usb 6-1.2.3: SerialNumber: 001300E04CA51820
[ 1581.672026] input: Generic USB Audio Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.2/5-1.2.3/5-1.2.3.1/5-1.2.3.1:1.0/0003:0BDA:4EF0.0019/input/input43
[ 1581.751413] input: Generic USB Audio as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.2/5-1.2.3/5-1.2.3.1/5-1.2.3.1:1.0/0003:0BDA:4EF0.0019/input/input44
[ 1581.761327] hid-generic 0003:0BDA:4EF0.0019: input,hiddev6,hidraw13: USB HID v1.11 Device [Generic USB Audio] on usb-0000:c3:00.3-1.2.3.1/input0
[ 1581.856945] r8152-cfgselector 6-1.2.3: reset SuperSpeed USB device number 25 using xhci_hcd
[ 1581.938075] r8152 6-1.2.3:1.0: load rtl8153b-2 v2 04/27/23 successfully
[ 1582.006221] r8152 6-1.2.3:1.0 eth0: v1.12.13
[ 1582.153781] r8152 6-1.2.3:1.0 enx00e04ca51820: renamed from eth0
[ 1582.438461] scsi 0:0:0:0: Direct-Access Generic MassStorageClass 1539 PQ: 0 ANSI: 6
[ 1582.439904] scsi 0:0:0:1: Direct-Access Generic MassStorageClass 1539 PQ: 0 ANSI: 6
[ 1582.440134] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1582.440295] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 1582.441207] sd 0:0:0:0: [sda] Media removed, stopped polling
[ 1582.441588] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 1582.670645] usb 6-1: USB disconnect, device number 22
[ 1582.670776] usb 6-1.2: USB disconnect, device number 23
[ 1582.670834] usb 6-1.2.2: USB disconnect, device number 24
[ 1582.696389] sd 0:0:0:1: [sdb] Test Unit Ready failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 1582.701007] sd 0:0:0:1: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 1582.701166] sd 0:0:0:1: [sdb] Sense not available.
[ 1582.709234] sd 0:0:0:1: [sdb] 0 512-byte logical blocks: (0 B/0 B)
[ 1582.709380] sd 0:0:0:1: [sdb] 0-byte physical blocks
[ 1582.710016] sd 0:0:0:1: [sdb] Test WP failed, assume Write Enabled
[ 1582.710301] sd 0:0:0:1: [sdb] Asking for cache data failed
[ 1582.710396] sd 0:0:0:1: [sdb] Assuming drive cache: write through
[ 1582.742931] sd 0:0:0:1: [sdb] Attached SCSI removable disk
[ 1582.796360] sd 0:0:0:1: [sdb] Test Unit Ready failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 1583.075143] r8152-cfgselector 6-1.2.3: USB disconnect, device number 25
[ 1583.093555] r8152 6-1.2.3:1.0 enx00e04ca51820: Stop submitting intr, status -108
[ 1584.248153] ucsi_acpi USBC000:00: GET_CURRENT_CAM command failed
[ 1584.935076] usb 6-1: new SuperSpeed Plus Gen 2x1 USB device number 26 using xhci_hcd
[ 1584.980438] usb 6-1: New USB device found, idVendor=2109, idProduct=0822, bcdDevice= 7.64
[ 1584.980607] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1584.981038] usb 6-1: Product: USB3.1 Hub
[ 1584.981115] usb 6-1: Manufacturer: VIA Labs, Inc.
[ 1585.130151] hub 6-1:1.0: USB hub found
[ 1585.134860] hub 6-1:1.0: 4 ports detected
[ 1585.798780] usb 6-1.2: new SuperSpeed USB device number 27 using xhci_hcd
[ 1585.818337] usb 6-1.2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[ 1585.818344] usb 6-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1585.818346] usb 6-1.2: Product: USB3.1 Hub
[ 1585.818348] usb 6-1.2: Manufacturer: GenesysLogic
[ 1585.842241] hub 6-1.2:1.0: USB hub found
[ 1585.845163] hub 6-1.2:1.0: 4 ports detected
[ 1586.174318] usb 6-1.2.2: new SuperSpeed USB device number 28 using xhci_hcd
[ 1586.212264] usb 6-1.2.2: New USB device found, idVendor=05e3, idProduct=0749, bcdDevice=15.39
[ 1586.212387] usb 6-1.2.2: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[ 1586.212476] usb 6-1.2.2: Product: USB3.0 Card Reader
[ 1586.212546] usb 6-1.2.2: Manufacturer: Generic
[ 1586.212606] usb 6-1.2.2: SerialNumber: 000000001539
[ 1586.265767] usb-storage 6-1.2.2:1.0: USB Mass Storage device detected
[ 1586.288453] scsi host0: usb-storage 6-1.2.2:1.0
[ 1586.413373] usb 6-1.2.3: new SuperSpeed USB device number 29 using xhci_hcd
[ 1586.431153] usb 6-1.2.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
[ 1586.431323] usb 6-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=7
[ 1586.431414] usb 6-1.2.3: Product: USB 10/100/1000 LAN
[ 1586.431493] usb 6-1.2.3: Manufacturer: Realtek
[ 1586.431569] usb 6-1.2.3: SerialNumber: 001300E04CA51820
[ 1586.600968] r8152-cfgselector 6-1.2.3: reset SuperSpeed USB device number 29 using xhci_hcd
[ 1586.675498] r8152 6-1.2.3:1.0: load rtl8153b-2 v2 04/27/23 successfully
[ 1586.784061] r8152 6-1.2.3:1.0 eth0: v1.12.13
[ 1587.380589] scsi 0:0:0:0: Direct-Access Generic MassStorageClass 1539 PQ: 0 ANSI: 6
[ 1587.389364] scsi 0:0:0:1: Direct-Access Generic MassStorageClass 1539 PQ: 0 ANSI: 6
[ 1587.403139] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1587.555795] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 1587.746423] sd 0:0:0:1: [sdb] Media removed, stopped polling
[ 1587.755368] sd 0:0:0:0: [sda] Media removed, stopped polling
[ 1587.806515] sd 0:0:0:1: [sdb] Attached SCSI removable disk
[ 1587.811556] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 1587.936729] workqueue: power_supply_changed_work hogged CPU for >10000us 19 times, consider switching to WQ_UNBOUND
[ 1588.925205] r8152 6-1.2.3:1.0 enx00e04ca51820: renamed from eth0
[ 1593.132227] usb 5-1: USB disconnect, device number 26
[ 1593.132364] usb 5-1.2: USB disconnect, device number 27
[ 1593.132437] usb 5-1.2.3: USB disconnect, device number 29
[ 1593.132489] usb 5-1.2.3.1: USB disconnect, device number 30
[ 1593.151917] usb 6-1: USB disconnect, device number 26
[ 1593.152060] usb 6-1.2: USB disconnect, device number 27
[ 1593.152124] usb 6-1.2.2: USB disconnect, device number 28
[ 1593.406354] usb 5-1.5: USB disconnect, device number 28
[ 1593.406766] r8152-cfgselector 6-1.2.3: USB disconnect, device number 29
[ 1593.406989] r8152 6-1.2.3:1.0 enx00e04ca51820: Stop submitting intr, status -108
CPU use goes up to 100% while doing this
Thank you ahead for any advise.
