Update: looks resolved in kernel 6.7
Seeing this thread reminded me of a strange (but definitely very low severity) regression I’ve noticed on this new AMD system: The (3rd gen) HDMI extension card that came with this machine has its vendor and product IDs reported as [unknown]
in lsusb
’s output. This does not happen with the gen 11 laptop and gen1 HDMI extension card. Correction: This also happens on the gen11 machine under Fedora 39. Seems to be an OS regression.
$ lsusb |egrep -i 'framework|32ac'
Bus 001 Device 002: ID 32ac:0002 [unknown] [unknown]
This has been the case under Fedora 39 since I first installed it, currently on kernel 6.6.9.
(edit to clarify, the extension card is working fine, this is just a reporting/almost cosmetic issue)
Would be interesting to know if older kernels like 6.5.x exhibits the same behavior
First of all I actually reproduced this on the gen11 machine too, also under Fedora 39. I must have missed it there earlier.
I booted into a 6.5 series kernel by just booting that gen11 machine with the F39 Workstation live image. In that configuration, the IDs are reported correctly.
Searching online indicates that these IDs come from the /usr/share/hwdata/usb.ids
database, which is maintained by the hwdata
package. I have the latest version installed (0.378-1.fc39
, pending from testing to stable repo as I write this). There is no sign of Framework devices in that file.
However, there’s also no sign of Framework devices in that file even on the Workstation Live filesystem, so these IDs must (also?) come from somewhere else. Maybe baked into the kernel?
By the way, Framework’s device(s) are not the only ones whose IDs are “unknown”. The Bluetooth part of the AMD/MediaTek wireless card also shows up as:
Bus 001 Device 004: ID 0e8d:e616 MediaTek Inc. [unknown]
e616
is also not present in usb.ids
but again, this doesn’t seem to be the (only?) source of these ID to name lookups.
Finally, I tried just hacking a Framework entry into the database:
$ diff -u usb.ids.orig usb.ids
--- usb.ids.orig 2024-01-02 16:00:00.000000000 -0800
+++ usb.ids 2024-01-12 12:23:43.266571934 -0800
@@ -23817,6 +23817,8 @@
ff00 Power Delivery
ffee FNK Tech
0100 Card Reader Controller RTS5101/RTS5111/RTS5116
+32ac Frame.work
+ 0002 HDMI Expansion card (test)
# List of known device classes, subclasses and protocols
but that didn’t fix the issue. Is that database only loaded at boot time?
Looks fixed with kernel 6.7.3
Bus 001 Device 002: ID 32ac:0002 Framework HDMI Expansion Card
