The installation guide is available here: Fedora 39 Installation on the Framework Laptop 16 - Framework Guide
Download
Fedora 39 Released: Fedora 39
WARNING:
The Fedora kernel update Fedora Linux (6.8.4-200.fc39.x86_64) 39 rendered my USB(-A)-Expansion-Card-ports unusable. I had to switch back to 6.7.11-200 (!)
6.8.5 seems to be working ok
Were you able to capture logs and file a bug report by chance? Can you replicate this on F40?
As 6.8.5 seems to be running fine, I didn’t see any sense in filing a bug report for a bug that seems to have gotten fixed already.
I don’t plan to switch to Fedora 40 until I have tested the upgrade process on an external drive, as I’m using it as my main OS.
Works for me, makes sense. ![]()
