This week, my Framework (12th gen, Ubuntu 22.04 LTS) started giving me some additional errors at boot. At the same time, the OS settings no longer acknowledge that the fingerprint sensor exists. I assume these things are related.
I’m a little worried that I may have damaged something when I installed the new hinges, although everything else seems to be working correctly. I carefully examined the fingerprint sensor cable, which appears to be intact and inserted correctly.
Here’s the relevant output from dmesg:
2.098660] usb 3-9: new full-speed USB device number 2 using xhci_hcd
[ 2.226901] usb 3-9: device descriptor read/64, error -71
[ 2.462926] usb 3-9: device descriptor read/64, error -71
[ 2.698707] usb 3-9: new full-speed USB device number 3 using xhci_hcd
[ 2.826959] usb 3-9: device descriptor read/64, error -71
[ 3.062944] usb 3-9: device descriptor read/64, error -71
[ 3.170981] usb usb3-port9: attempt power cycle
[ 3.178664] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input4
[ 3.582724] usb 3-9: new full-speed USB device number 4 using xhci_hcd
[ 3.583118] usb 3-9: Device not responding to setup address.
[ 3.791112] usb 3-9: Device not responding to setup address.
[ 3.998723] usb 3-9: device not accepting address 4, error -71
[ 4.126725] usb 3-9: new full-speed USB device number 5 using xhci_hcd
[ 4.127139] usb 3-9: Device not responding to setup address.
[ 4.335016] usb 3-9: Device not responding to setup address.
[ 4.542674] usb 3-9: device not accepting address 5, error -71
[ 4.543054] usb usb3-port9: unable to enumerate USB device
And here’s what I get from lsusb:
Bus 003 Device 006: ID 8087:0032 Intel Corp. AX210 Bluetooth
Does this look like a hardware problem or a software problem to the eyes of someone who can understand these messages?
