I just recently turned the keyboard backlight on, spent another 10’ or more watching a movie with zero interaction with it (or the touchpad), and noticed that the backlight stayed on the whole time.
I don’t think this is normal…
Is this how it’s supposed to work?
I’m running opensuse Tumbleweed with kernel 6.6.11 (although I suspect this is rather a BIOS/firmware feature).
Does it really? I would imagine the LEDs draw only a very small amount of power… anyway as pointed out earlier in the thread, it is possible to manually emulate the timeout function in Linux (I’m not sure about Windows though, since I don’t think this would work by sending fn+space keys from software, I suspect the github link implements this through Linux sysfs).
