snek
November 5, 2023, 5:00am
1
After upgrading to the AMD mainboard, the headphone jack only works as a headphone jack and no longer shows up as an input to my OS (arch linux). The chassis microphone still works though.
For tested distros such as Fedora 39 or Ubuntu 22.04.3 LTS on the OEM C kernel, the linked thread below is what we recommend.
I use a headset for recording audio and I couldn’t select any mic other than the onboard mic. To correct this, you might consider using the following depending on your setup:
sudo tee /etc/modprobe.d/alsa.conf <<< "options snd-hda-intel index=1,0 model=auto,dell-headset-multi"
Then reboot.
This seems to be similar to what others use for other models of framework laptops that likely use 3.5mm jack headsets.
It’s a bit misleading because the snd-hda-intel module is generically used for all a…
