Hey community!
I have a strange problem sin the latest updates (bios, kernel).
I’m using Linux Mint 21.2 with kernel 6.5.0-14. Problem has also occurred in 6.2, can’t say for sure in 5.19…
I had some strange issues with my wifi in the last weeks. I wasn’t able to connect to servers or it took very long to connect. Browsing was nearly impossible. Pinging google spiked to over 20s sometimes, some pings were low (<100ms), some were over 3s… and a lot of packet losses (~40%). But it was not always the case. Sometimes suddenly everything worked again for a while.
Half an hour ago, I was wandering that the connection was pretty good, but as soon as I turned on my mouse (Logi M650 L), I again got those connection issues. I could reproduce the problem by turning the mouse off and on a few times. So I gues wifi and bluetooth are having issues when used both at the same time.
Any idea what I could do to fix this problem without having to change my mouse?
Thanks in advance for any help!
Rafael
hi @Rafael_Kania ,
can we try and check if signals change when M650 is turned on?
watch -n 2 nmcli -f NAME,SSID,BSSID,MODE,CHAN,FREQ,RATE,SIGNAL,BARS,SECURITY,IN-USE device wifi
M650 is active:
NAME SSID BSSID MODE CHAN FREQ RATE SIGNAL BARS SECURITY IN-USE
AP[1] homefritzbox Gastzugang 2E:3A:FD:FC:D6:9B Infra 5 2432 MHz 270 Mbit/s 94 ▂▄▆█ WPA2
AP[2] Vodafone-4F3E D4:3F:CB:8D:CA:D5 Infra 11 2462 MHz 405 Mbit/s 85 ▂▄▆█ WPA2
AP[3] PLink-1959 44:FE:3B:C0:B8:B2 Infra 1 2412 MHz 270 Mbit/s 82 ▂▄▆█ WPA2
AP[4] homefritzbox 2C:3A:FD:FC:D6:9B Infra 5 2432 MHz 270 Mbit/s 76 ▂▄▆_ WPA2 *
AP[5] PLink-1959 44:FE:3B:C0:B8:B1 Infra 36 5180 MHz 540 Mbit/s 55 ▂▄__ WPA2
AP[6] homefritzbox Gastzugang 76:42:7F:66:96:D8 Infra 11 2462 MHz 130 Mbit/s 49 ▂▄__ WPA2
AP[7] homefritzbox 74:42:7F:66:96:D8 Infra 11 2462 MHz 130 Mbit/s 49 ▂▄__ WPA2
AP[8] HZN244562172 D4:7A:E2:88:6B:49 Infra 13 2472 MHz 130 Mbit/s 39 ▂▄__ WPA1 WPA2
AP[9] Vodafone-4F3E F0:B0:14:2C:A2:32 Infra 11 2462 MHz 130 Mbit/s 37 ▂▄__ WPA2
AP[10] PLink-1959 4C:1B:86:A3:8C:38 Infra 1 2412 MHz 540 Mbit/s 34 ▂▄__ WPA2
AP[11] PLink-1959 Gastzugang 4C:1B:86:A3:8C:39 Infra 1 2412 MHz 540 Mbit/s 34 ▂▄__ WPA2
AP[12] homefritzbox 38:10:D5:08:E5:21 Infra 11 2462 MHz 195 Mbit/s 30 ▂___ WPA2
AP[13] PLink-1959 4C:1B:86:A3:8C:34 Infra 36 5180 MHz 540 Mbit/s 29 ▂___ WPA2
AP[14] PLink-1959 Gastzugang 4C:1B:86:A3:8C:35 Infra 36 5180 MHz 540 Mbit/s 27 ▂___ WPA2
AP[15] homefritzbox Gastzugang 3A:10:D5:08:E5:21 Infra 11 2462 MHz 195 Mbit/s 24 ▂___ WPA2
AP[16] FRITZ!Box 6590 Cable KB 2C:91:AB:AE:F0:77 Infra 6 2437 MHz 260 Mbit/s 22 ▂___ WPA2
M650 is inactive:
AP[2] PLink-1959 44:FE:3B:C0:B8:B2 Infra 1 2412 MHz 270 Mbit/s 82 ▂▄▆█ WPA2
AP[3] Vodafone-4F3E D4:3F:CB:8D:CA:D5 Infra 11 2462 MHz 405 Mbit/s 82 ▂▄▆█ WPA2
AP[6] homefritzbox 74:42:7F:66:96:D8 Infra 11 2462 MHz 130 Mbit/s 49 ▂▄__ WPA2
AP[7] homefritzbox Gastzugang 76:42:7F:66:96:D8 Infra 11 2462 MHz 130 Mbit/s 45 ▂▄__ WPA2
AP[8] HZN244562172 D4:7A:E2:88:6B:49 Infra 13 2472 MHz 130 Mbit/s 44 ▂▄__ WPA1 WPA2
AP[10] PLink-1959 4C:1B:86:A3:8C:38 Infra 1 2412 MHz 540 Mbit/s 35 ▂▄__ WPA2
AP[11] PLink-1959 Gastzugang 4C:1B:86:A3:8C:39 Infra 1 2412 MHz 540 Mbit/s 35 ▂▄__ WPA2
AP[12] homefritzbox Gastzugang 3A:10:D5:08:E5:21 Infra 11 2462 MHz 195 Mbit/s 30 ▂___ WPA2
AP[13] PLink-1959 4C:1B:86:A3:8C:34 Infra 36 5180 MHz 540 Mbit/s 27 ▂___ WPA2
AP[15] homefritzbox 38:10:D5:08:E5:21 Infra 11 2462 MHz 195 Mbit/s 22 ▂___ WPA2
The homefritzbox is what I am using. I have 2 repeaters in my house. I also have a guest wifi active and in use. Btw. the fritzbox router is only 4m away from my laptop with no walls in between.
And can we have output for when M650 is not active?
It’s already inside the listing under the active section.
I would try increasing the separation of the channels used by the computer and the mouse.
