Hi everyone,
Recently I’ve been having trouble with wifi on my fedora partition, I don’t know what caused it. I thought it came from a Bluez update at first but i’m becoming less and less sure about that, here is the output of dmseg --level=err,warn
Framework 13, 12th gen
[ 0.097748] #1 #3 #5 #7
[ 0.104776] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.268381] pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 1.641715] hpet_acpi_add: no address or irqs in _CRS
[ 1.726187] usb: port power management may be unreliable
[ 1.726584] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.728099] i8042: Warning: Keylock active
[ 1.733914] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 3.007998] Module hid_sensor_hub is blacklisted
[ 6.086244] systemd[1]: create-shutdown-flag.service: Failed with result 'exit-code'.
[ 6.104967] systemd[1]: Failed to start create-shutdown-flag.service - Create a shutdown flag.
[ 6.512436] Module hid_sensor_hub is blacklisted
[ 6.563595] resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
[ 6.563602] caller igen6_probe+0x1a0/0x8d0 [igen6_edac] mapping multiple BARs
[ 6.763245] cros-usbpd-charger cros-usbpd-charger.2.auto: Unexpected number of charge port count
[ 6.763247] cros-usbpd-charger: probe of cros-usbpd-charger.2.auto failed with error -71
[ 6.798109] iwlwifi 0000:a6:00.0: api flags index 2 larger than supported by driver
[ 6.813607] ACPI Warning: \_SB.PC00.XHCI.RHUB.HS10._DSM: Argument #4 type mismatch - Found [Integer], ACPI requires [Package] (20230628/nsarguments-61)
[ 6.962446] thermal thermal_zone13: failed to read out thermal zone (-61)
[ 6.969059] iwlwifi 0000:a6:00.0: WRT: Invalid buffer destination
[ 8.081894] iwlwifi 0000:a6:00.0: WRT: Invalid buffer destination
[ 8.391827] iwlwifi 0000:a6:00.0: WRT: Invalid buffer destination
[ 8.447964] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 8.569366] iwlwifi 0000:a6:00.0: Microcode SW error detected. Restarting 0x0.
[ 8.569515] iwlwifi 0000:a6:00.0: Start IWL Error Log Dump:
[ 8.569517] iwlwifi 0000:a6:00.0: Transport status: 0x0000004B, valid: 6
[ 8.569520] iwlwifi 0000:a6:00.0: Loaded firmware version: 83.e8f84e98.0 ty-a0-gf-a0-83.ucode
[ 8.569522] iwlwifi 0000:a6:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 8.569525] iwlwifi 0000:a6:00.0: 0x002082F0 | trm_hw_status0
[ 8.569526] iwlwifi 0000:a6:00.0: 0x00000000 | trm_hw_status1
[ 8.569528] iwlwifi 0000:a6:00.0: 0x004DC410 | branchlink2
[ 8.569529] iwlwifi 0000:a6:00.0: 0x004D233E | interruptlink1
[ 8.569530] iwlwifi 0000:a6:00.0: 0x004D233E | interruptlink2
[ 8.569532] iwlwifi 0000:a6:00.0: 0x0001698A | data1
[ 8.569533] iwlwifi 0000:a6:00.0: 0x00000010 | data2
[ 8.569534] iwlwifi 0000:a6:00.0: 0x00000000 | data3
[ 8.569536] iwlwifi 0000:a6:00.0: 0x00000000 | beacon time
[ 8.569537] iwlwifi 0000:a6:00.0: 0x00016096 | tsf low
[ 8.569538] iwlwifi 0000:a6:00.0: 0x00000000 | tsf hi
[ 8.569540] iwlwifi 0000:a6:00.0: 0x00000000 | time gp1
[ 8.569541] iwlwifi 0000:a6:00.0: 0x0002B246 | time gp2
[ 8.569542] iwlwifi 0000:a6:00.0: 0x00000001 | uCode revision type
[ 8.569544] iwlwifi 0000:a6:00.0: 0x00000053 | uCode version major
[ 8.569545] iwlwifi 0000:a6:00.0: 0xE8F84E98 | uCode version minor
[ 8.569547] iwlwifi 0000:a6:00.0: 0x00000420 | hw version
[ 8.569548] iwlwifi 0000:a6:00.0: 0x00C80002 | board version
[ 8.569549] iwlwifi 0000:a6:00.0: 0x8004FC12 | hcmd
[ 8.569550] iwlwifi 0000:a6:00.0: 0x20028000 | isr0
[ 8.569552] iwlwifi 0000:a6:00.0: 0x60000000 | isr1
[ 8.569553] iwlwifi 0000:a6:00.0: 0x58F80002 | isr2
[ 8.569554] iwlwifi 0000:a6:00.0: 0x00C0001C | isr3
[ 8.569555] iwlwifi 0000:a6:00.0: 0x00000000 | isr4
[ 8.569556] iwlwifi 0000:a6:00.0: 0x00000000 | last cmd Id
[ 8.569558] iwlwifi 0000:a6:00.0: 0x0001698A | wait_event
[ 8.569559] iwlwifi 0000:a6:00.0: 0x00000000 | l2p_control
[ 8.569560] iwlwifi 0000:a6:00.0: 0x00000000 | l2p_duration
[ 8.569562] iwlwifi 0000:a6:00.0: 0x00000000 | l2p_mhvalid
[ 8.569563] iwlwifi 0000:a6:00.0: 0x00000000 | l2p_addr_match
[ 8.569564] iwlwifi 0000:a6:00.0: 0x00000009 | lmpm_pmg_sel
[ 8.569565] iwlwifi 0000:a6:00.0: 0x00000000 | timestamp
[ 8.569566] iwlwifi 0000:a6:00.0: 0x00000020 | flow_handler
[ 8.569653] iwlwifi 0000:a6:00.0: Start IWL Error Log Dump:
[ 8.569654] iwlwifi 0000:a6:00.0: Transport status: 0x0000004B, valid: 7
[ 8.569656] iwlwifi 0000:a6:00.0: 0x2010190E | ADVANCED_SYSASSERT
[ 8.569658] iwlwifi 0000:a6:00.0: 0x00000000 | umac branchlink1
[ 8.569659] iwlwifi 0000:a6:00.0: 0x8046DA58 | umac branchlink2
[ 8.569661] iwlwifi 0000:a6:00.0: 0x0101F43E | umac interruptlink1
[ 8.569662] iwlwifi 0000:a6:00.0: 0x00000000 | umac interruptlink2
[ 8.569664] iwlwifi 0000:a6:00.0: 0x0101F71C | umac data1
[ 8.569665] iwlwifi 0000:a6:00.0: 0xDEADBEEF | umac data2
[ 8.569666] iwlwifi 0000:a6:00.0: 0xDEADBEEF | umac data3
[ 8.569667] iwlwifi 0000:a6:00.0: 0x00000053 | umac major
[ 8.569669] iwlwifi 0000:a6:00.0: 0xE8F84E98 | umac minor
[ 8.569670] iwlwifi 0000:a6:00.0: 0x0002B240 | frame pointer
[ 8.569687] iwlwifi 0000:a6:00.0: 0xC0886BE0 | stack pointer
[ 8.569689] iwlwifi 0000:a6:00.0: 0x00000000 | last host cmd
[ 8.569692] iwlwifi 0000:a6:00.0: 0x00000000 | isr status reg
[ 8.569753] iwlwifi 0000:a6:00.0: IML/ROM dump:
[ 8.569754] iwlwifi 0000:a6:00.0: 0x00000B03 | IML/ROM error/state
[ 8.569774] iwlwifi 0000:a6:00.0: 0x00008726 | IML/ROM data1
[ 8.569786] iwlwifi 0000:a6:00.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 8.569794] iwlwifi 0000:a6:00.0: Fseq Registers:
[ 8.569805] iwlwifi 0000:a6:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 8.569817] iwlwifi 0000:a6:00.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[ 8.569829] iwlwifi 0000:a6:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 8.569841] iwlwifi 0000:a6:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 8.569853] iwlwifi 0000:a6:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 8.569865] iwlwifi 0000:a6:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 8.569877] iwlwifi 0000:a6:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 8.569888] iwlwifi 0000:a6:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 8.569900] iwlwifi 0000:a6:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 8.569914] iwlwifi 0000:a6:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 8.569928] iwlwifi 0000:a6:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 8.569942] iwlwifi 0000:a6:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 8.569954] iwlwifi 0000:a6:00.0: 0x00080009 | FSEQ_PREV_CNVIO_INIT_VERSION
[ 8.569966] iwlwifi 0000:a6:00.0: 0x00440007 | FSEQ_WIFI_FSEQ_VERSION
[ 8.569978] iwlwifi 0000:a6:00.0: 0x00440007 | FSEQ_BT_FSEQ_VERSION
[ 8.569990] iwlwifi 0000:a6:00.0: 0x000000DC | FSEQ_CLASS_TP_VERSION
[ 8.570010] iwlwifi 0000:a6:00.0: UMAC CURRENT PC: 0x8048da0c
[ 8.570022] iwlwifi 0000:a6:00.0: LMAC1 CURRENT PC: 0xd0
[ 8.570034] iwlwifi 0000:a6:00.0: Starting mac, retry will be triggered anyway
[ 8.570100] iwlwifi 0000:a6:00.0: FW error in SYNC CMD INIT_EXTENDED_CFG_CMD
[ 8.570117] CPU: 4 PID: 1462 Comm: NetworkManager Not tainted 6.6.13-200.fc39.x86_64 #1
[ 8.570122] Hardware name: Framework Laptop (12th Gen Intel Core)/FRANMACP06, BIOS 03.05 08/23/2022
[ 8.570124] Call Trace:
[ 8.570127] <TASK>
[ 8.570131] dump_stack_lvl+0x47/0x60
[ 8.570143] iwl_trans_txq_send_hcmd+0x33d/0x450 [iwlwifi]
[ 8.570187] ? __pfx_autoremove_wake_function+0x10/0x10
[ 8.570195] iwl_trans_send_cmd+0x66/0x100 [iwlwifi]
[ 8.570234] iwl_mvm_send_cmd_pdu+0x62/0xb0 [iwlmvm]
[ 8.570291] iwl_run_unified_mvm_ucode+0xf0/0x280 [iwlmvm]
[ 8.570325] ? __pfx_iwl_wait_init_complete+0x10/0x10 [iwlmvm]
[ 8.570356] iwl_mvm_up+0x203/0xca0 [iwlmvm]
[ 8.570391] ? __iwl_mvm_mac_start+0x5f/0x1d0 [iwlmvm]
[ 8.570427] __iwl_mvm_mac_start+0x5f/0x1d0 [iwlmvm]
[ 8.570462] iwl_mvm_mac_start+0x79/0x130 [iwlmvm]
[ 8.570498] drv_start+0x3f/0x100 [mac80211]
[ 8.570582] ieee80211_do_open+0x32e/0x7e0 [mac80211]
[ 8.570676] ieee80211_open+0x6a/0x90 [mac80211]
[ 8.570776] __dev_open+0xf1/0x1a0
[ 8.570781] __dev_change_flags+0x1d6/0x240
[ 8.570785] ? context_struct_compute_av+0x3c9/0x4d0
[ 8.570791] dev_change_flags+0x26/0x70
[ 8.570795] do_setlink+0x39c/0x12d0
[ 8.570799] ? avc_alloc_node+0x24/0x170
[ 8.570803] ? select_task_rq_fair+0x825/0x1dc0
[ 8.570808] ? __nla_validate_parse+0x61/0xd10
[ 8.570815] __rtnl_newlink+0x651/0xa10
[ 8.570819] ? __kmem_cache_alloc_node+0x19d/0x340
[ 8.570824] ? rtnl_newlink+0x2e/0x70
[ 8.570828] rtnl_newlink+0x47/0x70
[ 8.570831] rtnetlink_rcv_msg+0x14f/0x3c0
[ 8.570835] ? avc_has_perm_noaudit+0x6b/0xf0
[ 8.570838] ? __pfx_rtnetlink_rcv_msg+0x10/0x10
[ 8.570841] netlink_rcv_skb+0x58/0x110
[ 8.570848] netlink_unicast+0x1a3/0x290
[ 8.570853] netlink_sendmsg+0x254/0x4d0
[ 8.570858] ____sys_sendmsg+0x396/0x3d0
[ 8.570862] ? copy_msghdr_from_user+0x7d/0xc0
[ 8.570868] ___sys_sendmsg+0x9a/0xe0
[ 8.570873] ? __wake_up_common+0x73/0x180
[ 8.570880] __sys_sendmsg+0x7a/0xd0
[ 8.570886] do_syscall_64+0x5d/0x90
[ 8.570893] ? do_syscall_64+0x6c/0x90
[ 8.570897] ? syscall_exit_to_user_mode+0x2b/0x40
[ 8.570901] ? do_syscall_64+0x6c/0x90
[ 8.570906] ? syscall_exit_to_user_mode+0x2b/0x40
[ 8.570909] ? __fget_light+0x99/0x100
[ 8.570914] ? ksys_write+0xd8/0xf0
[ 8.570918] ? syscall_exit_to_user_mode+0x2b/0x40
[ 8.570921] ? do_syscall_64+0x6c/0x90
[ 8.570926] ? do_syscall_64+0x6c/0x90
[ 8.570931] entry_SYSCALL_64_after_hwframe+0x6e/0xd8
[ 8.570938] RIP: 0033:0x7f0b4aaa7a5b
[ 8.570972] Code: 48 89 e5 48 83 ec 20 89 55 ec 48 89 75 f0 89 7d f8 e8 c9 2f f7 ff 8b 55 ec 48 8b 75 f0 41 89 c0 8b 7d f8 b8 2e 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 2d 44 89 c7 48 89 45 f8 e8 21 30 f7 ff 48 8b
[ 8.570975] RSP: 002b:00007ffef0220cb0 EFLAGS: 00000293 ORIG_RAX: 000000000000002e
[ 8.570979] RAX: ffffffffffffffda RBX: 000055e969566f90 RCX: 00007f0b4aaa7a5b
[ 8.570982] RDX: 0000000000000000 RSI: 00007ffef0220cf0 RDI: 000000000000000d
[ 8.570984] RBP: 00007ffef0220cd0 R08: 0000000000000000 R09: 0000000000000000
[ 8.570986] R10: 0000000000000000 R11: 0000000000000293 R12: 0000000000000012
[ 8.570988] R13: 000055e969566f90 R14: 0000000000000001 R15: 0000000000000000
[ 8.570991] </TASK>
[ 8.571012] iwlwifi 0000:a6:00.0: Failed to run init config command: -5
[ 8.571015] iwlwifi 0000:a6:00.0: Failed to start RT ucode: -5
[ 8.571018] iwlwifi 0000:a6:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 9.442798] iwlwifi 0000:a6:00.0: mac start retry 0
[ 9.450097] iwlwifi 0000:a6:00.0: WRT: Invalid buffer destination
[ 13.446944] qemu-system-x86[1726]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 16.401142] warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
I would be happy to help any troubleshooting, I’m at a loss right now on how to fix it.
Thanks in advance
