[RESPONDED] Sound card replacement?
Hi,
When I put my headphones on there’s this really really annoying popping / clicking sound that happens every few minutes. I’ve heard that this is because Framework went with a bad sound chip or sound card and I was curious if they sold these anywhere.
Nobody seems to know what’s causing it though. I set up a command to alter power save mode (as was recommended by the community) but it doesn’t really work.
Ubuntu Mate Jammy Jellyfish
Apparently it’s because of a fan?..
Whenever I click on a Youtube video it makes the sound, for example
I did the power save command talked about here. I thought it worked but when I would start up the computer again it would come back.
Best recommendation is to use the audio expansion card as best overall solution.
