[RESPONDED] Video problems with Framework 13 AMD in Linux with X11
TLDR; The AMD GPU looks like it doesn’t get along well with X11, especially with overlays. Do I finally need to give up on X11, or is there a way to run both?
Environment:
  • Framework 13 with AMD 7640U
  • 2x16 GB DDR5 6500 (Crucial brand)
  • Ubuntu 22.04.3 LTS installed per the guide, including kernel and other tuning
  • Fractional scaling (150%), though the problem happens with non-fractional scaling as well
Background:
I prefer X11 over Wayland for the windowing system for some programs like Remmina for RDP and various VMware clients. The way Wayland handles various command key combinations (Alt+Tab, super key combos, etc.) prevents remote desktop/virtualization software that I use from capturing key combinations that I use a lot. X11 behaves better in this particular area and so I prefer it but it has some weird behavior with the graphics on this platform.
Problem:
When something calls for an overlay or a some kind of resolution or geometry change, the screen stutters. It goes black for a moment, then refreshes and redraws. If it happens to much or you just get unlucky, it can completely lock up the system. Specific examples I have experienced are:
  • Play a full-screen video in VLC. When you move the mouse (which brings up the control overlay), the screen will freak out, go black/come back, etc.
  • Run a photo slideshow in gThumb. Depending on input resolution, it could trigger this behavior.
This happens only in X11. In Wayland, it’s smooth sailing and everything works fine.
Specific Questions:
  1. Is there any tuning for X11 that can prevent this, or is the AMD GPU driver just not optimized for X11? I imagine the latter because X11 is now quite non-preferred in the market, but I am not sure.
  2. If there is no way to avoid this in X11, is it possible to log in to both Wayland and X11 sessions simultaneously? Can I log in with an X11 environment on the first virtual console (Ctrl+Alt+F1) and leave it hanging out in the background with my remote desktop and VMware clients running, and use the main console running Wayland (Ctrl+Alt+F2) for everything else?
Thanks!
I’m using Debian with XFCE4 (which does even support Wayland yet as far as I know) and I did not encounter such issues. I installed VLC (which I normally do not use) and while it is 50% transparent for some reason, I did not see any issues in fullscreen either.
So it may not be X11 that’s the issue, but perhaps some underlying bug that X11 just happens to trigger while Wayland does not. I did have one crash while watching Youtube, which also started as stutter, black screens, and then permanent black screen. But after upgrading firmware-amd-graphics to version 20230625-2 from sid, I did not encounter it again (on kernel 6.6.13).
Thank you. For checking that. I am Gnome (standard Ubuntu install), so that is definitely a difference, too.
Do you have a link to a procedure on how I go about updating the firmware, or otherwise learn how to do it?
For Debian I just searched the packages and saw that testing has a 4 months newer version than stable (even though the newer version is also 6 months old). So I added testing to my /etc/apt/sources.list, installed the newer firmware package, and commented the testing sources again.
For Ubuntu, I’m looking at the packages and there does not seem to be one specifically for AMD. Package linux-firmware seems to be using the same version number scheme, so perhaps it’s in there (or maybe not, I’m not really familiar with Ubuntu). But 22.04 LTS shows version 20220329, which seems way too old to even work with such new hardware. OTOH, 22.04 LTS is officially supported by Framework, so an upgrade should not be needed…
You could try installing the 20230919 version from Ubuntu 23.10, but you would be introducing a new package to otherwise tested and officially supported system, so you could potentially make it worse. Depends on how much you are willing to tinker I suppose.
Fair enough :smiley: I am happy enough with Wayland under most circumstances and will see if I can fire up a second desktop in X11 on an alternate console for when I need to use my remote or VM applications. Your outcome is promising and I assume the Ubuntu will get around to shoving the new firmwares out at some point, and I’ll get it then. I have a machine for tinkering, but hopefully this won’t be one of them!
Thanks for your rapid responses.
Great post. Thorough, detailed and helpful.
X11 and applications that rely on it are in a super weird place right now. Personally, and this is just my opinion - I think X11 is on borrowed time. I expect Xwayland to remain the bridging factor for legacy software relying on X11. But any tweaks or improvements I suspect would happen against Xwayland and not X11.
You indicated this affects X11 both with Fractional scaling off and on. Might be useful to see if there are any useful indications in dmesg or Xorg logs.
This is definitely an area where I’d want @Mario_Limonciello’s thoughts as it likely involves the AMDGPU.
I agree. A majority of the testing and development happens on Wayland.
Black screen might be a problem with PSR or VAAPI not working properly. X11 gets very little testing.
I guess this is the issue you’re hitting:
My personal opinion is that if you’re going to fix something I think it’s a better time investment to find and fix that bug than it is to diagnose a different bug on X11.
When I test this with fractional vs. non-fractional vs. no scaling, I will see what if anything pops up in the logs and update the thread just for the sake of completeness. I don’t expect this to get fixed (certainly not by Framework - it’s most decidedly not their problem) but I am now curious and so will dig into it a bit just for my own edification.
This is the issue I am hitting, but I don’t think it’s a Remmina issue at its core because the exact same behavior happens in various VMware clients and, IIRC (though don’t quote me on it) in VirtualBox as well. It could probably worked around in client software, but I suspect the common failure is elsewhere. And I also agree, for what it’s worth - but I am also not a developer or programmer so that isn’t within my wheelhouse. I’ll just swap out the user environment when I’m doing a lot of RDP or VMware work and end up going bonkers when my hotkeys don’t work properly :smiley:
Just an update to my earlier post: I had a second crash today, this time just looking at a static web page with no video. Unlike the first time there was no warning (stutter etc.); it went right to a black screen, after which the session died and dumped me to the login screen.
So the firmware update that I suggested may not help, or at least it does not solve the issue completely on its own. Maybe it did not mitigate the issue at all and I just got lucky the last 15 days (I had a crash sample size of one, after all, so it’s hard to say).
Attaching relevant dmesg dumps in case they are of any use. Since it happens so rarely so far, I suppose I’ll just keep updating the kernel, firmware, and mesa, and hope it eventually goes away as the drivers mature. :slight_smile:
dmesg after second crash (straight black screen and return to login screen)
[1313482.367110] [drm:gfx_v11_0_priv_reg_irq [amdgpu]] *ERROR* Illegal register access in command stream
[1313482.377254] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=162105800, emitted seq=162105801
[1313482.377455] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process xfwm4 pid 1631 thread xfwm4:cs0 pid 1662
[1313482.377614] amdgpu 0000:c1:00.0: amdgpu: GPU reset begin!
[1313482.639824] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313482.639979] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313482.770442] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313482.770588] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313482.900729] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313482.900881] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313483.031316] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313483.031471] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313483.161527] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313483.161681] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313483.292560] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313483.292697] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313483.423550] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313483.423684] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313483.553906] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313483.554074] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313483.687542] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[1313483.687803] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[1313483.918409] [drm:gfx_v11_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
[1313483.919967] amdgpu 0000:c1:00.0: amdgpu: MODE2 reset
[1313483.944241] amdgpu 0000:c1:00.0: amdgpu: GPU reset succeeded, trying to resume
[1313483.944795] [drm] PCIE GART of 512M enabled (table at 0x00000080FFD00000).
[1313483.944948] amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
[1313483.946104] amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
[1313483.947502] [drm] DMUB hardware initialized: version=0x08001B00
[1313484.344669] [drm] kiq ring mec 3 pipe 1 q 0
[1313484.346414] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[1313484.346606] amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
[1313484.347231] amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[1313484.347234] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[1313484.347236] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[1313484.347238] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[1313484.347239] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[1313484.347241] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[1313484.347243] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[1313484.347244] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[1313484.347246] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[1313484.347248] amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[1313484.347250] amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[1313484.347251] amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[1313484.347253] amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[1313484.348748] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow start
[1313484.348751] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow done
[1313484.348782] [drm] Skip scheduling IBs!
[1313484.348810] [drm] Skip scheduling IBs!
[1313484.348817] [drm] Skip scheduling IBs!
... repeats ~80x
[1313484.348929] [drm] Skip scheduling IBs!
[1313484.348931] [drm] Skip scheduling IBs!
[1313484.348933] [drm] Skip scheduling IBs!
[1313484.349714] [drm] ring gfx_32787.1.1 was added
[1313484.350461] [drm] ring compute_32787.2.2 was added
[1313484.351227] [drm] ring sdma_32787.3.3 was added
[1313484.351252] [drm] ring gfx_32787.1.1 ib test pass
[1313484.351276] [drm] ring compute_32787.2.2 ib test pass
[1313484.351429] [drm] ring sdma_32787.3.3 ib test pass
[1313484.352642] amdgpu 0000:c1:00.0: amdgpu: GPU reset(2) succeeded!
[1313485.445108] [drm] Skip scheduling IBs!
[1313485.445121] [drm] Skip scheduling IBs!
[1313485.445125] [drm] Skip scheduling IBs!
... repeats ~200x
[1313485.446705] [drm] Skip scheduling IBs!
[1313485.446709] [drm] Skip scheduling IBs!
[1313485.446718] [drm] Skip scheduling IBs!
[1313486.222038] traps: xfsettingsd[3526186] trap int3 ip:7f28796c77c7 sp:7fffd2e6a2b0 error:0 in libglib-2.0.so.0.7400.6[7f2879687000+8d000]
[1313486.356385] Lockdown: Xorg: raw io port access is restricted; see man kernel_lockdown.7
[1313499.678933] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[1313499.706625] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[1313499.707161] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
dmesg after first crash (stutter into brief black screens into perma black screen)
[ 6822.552580] [drm:gfx_v11_0_priv_reg_irq [amdgpu]] *ERROR* Illegal register access in command stream
[ 6822.562833] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=924088, emitted seq=924090
[ 6822.562990] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process firefox-bin pid 3289 thread firefox:cs0 pid 3768
[ 6822.563082] amdgpu 0000:c1:00.0: amdgpu: GPU reset begin!
[ 6822.569905] amdgpu_cs_ioctl: 18 callbacks suppressed
[ 6822.569908] [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
[ 6822.819497] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6822.819664] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6822.948409] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6822.948516] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6823.077224] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6823.077351] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6823.206148] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6823.206264] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6823.334968] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6823.335083] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6823.463890] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6823.464010] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6823.592763] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6823.592896] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6823.721666] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6823.721785] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6823.850546] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6823.850663] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6824.057790] [drm:gfx_v11_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
[ 6824.059299] amdgpu 0000:c1:00.0: amdgpu: MODE2 reset
[ 6824.068324] amdgpu 0000:c1:00.0: amdgpu: GPU reset succeeded, trying to resume
[ 6824.068774] [drm] PCIE GART of 512M enabled (table at 0x00000080FFD00000).
[ 6824.069000] amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
[ 6824.070786] amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
[ 6824.072379] [drm] DMUB hardware initialized: version=0x08000500
[ 6824.489396] [drm] kiq ring mec 3 pipe 1 q 0
[ 6824.492726] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 6824.492995] amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
[ 6824.494106] amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 6824.494109] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 6824.494110] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 6824.494111] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 6824.494112] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 6824.494114] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 6824.494115] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 6824.494116] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 6824.494117] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 6824.494118] amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 6824.494119] amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 6824.494120] amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[ 6824.494121] amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[ 6824.496972] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow start
[ 6824.496973] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow done
[ 6824.497014] [drm] Skip scheduling IBs!
[ 6824.497173] [drm] Skip scheduling IBs!
[ 6824.497181] [drm] Skip scheduling IBs!
[ 6824.497187] [drm] Skip scheduling IBs!
[ 6824.497191] [drm] Skip scheduling IBs!
[ 6824.500699] [drm] Skip scheduling IBs!
[ 6824.502666] [drm] ring gfx_32781.1.1 was added
[ 6824.505418] [drm] ring compute_32781.2.2 was added
[ 6824.507997] [drm] ring sdma_32781.3.3 was added
[ 6824.508731] [drm] Skip scheduling IBs!
[ 6824.510465] [drm] Skip scheduling IBs!
[ 6824.523719] [drm] Skip scheduling IBs!
[ 6824.523735] [drm] Skip scheduling IBs!
[ 6824.523748] [drm] Skip scheduling IBs!
[ 6824.523760] [drm] Skip scheduling IBs!
[ 6824.523770] [drm] Skip scheduling IBs!
[ 6824.523778] [drm] Skip scheduling IBs!
[ 6824.523785] [drm] Skip scheduling IBs!
[ 6824.523793] [drm] Skip scheduling IBs!
[ 6824.526411] [drm] Skip scheduling IBs!
[ 6824.526417] [drm] Skip scheduling IBs!
[ 6824.526420] [drm] Skip scheduling IBs!
[ 6824.736834] amdgpu 0000:c1:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx_32781.1.1 test failed (-110)
[ 6824.864021] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6824.864136] [drm:amdgpu_mes_remove_hw_queue [amdgpu]] *ERROR* failed to remove hardware queue, queue id = 1
[ 6824.991055] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6824.991169] [drm:amdgpu_mes_remove_hw_queue [amdgpu]] *ERROR* failed to remove hardware queue, queue id = 2
[ 6825.118460] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6825.118590] [drm:amdgpu_mes_remove_hw_queue [amdgpu]] *ERROR* failed to remove hardware queue, queue id = 3
[ 6825.118994] amdgpu 0000:c1:00.0: amdgpu: GPU reset(2) succeeded!
[ 6825.282914] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[ 6825.283033] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[ 6825.409965] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[ 6825.410092] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[ 6826.741017] amdgpu 0000:c1:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:157 vmid:0 pasid:0, for process  pid 0 thread  pid 0)
[ 6826.741024] amdgpu 0000:c1:00.0: amdgpu:   in page starting at address 0x0000000000000000 from client 10
[ 6826.741026] amdgpu 0000:c1:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000B3B
[ 6826.741028] amdgpu 0000:c1:00.0: amdgpu: 	 Faulty UTCL2 client ID: CPC (0x5)
[ 6826.741030] amdgpu 0000:c1:00.0: amdgpu: 	 MORE_FAULTS: 0x1
[ 6826.741031] amdgpu 0000:c1:00.0: amdgpu: 	 WALKER_ERROR: 0x5
[ 6826.741032] amdgpu 0000:c1:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x3
[ 6826.741033] amdgpu 0000:c1:00.0: amdgpu: 	 MAPPING_ERROR: 0x1
[ 6826.741034] amdgpu 0000:c1:00.0: amdgpu: 	 RW: 0x0
[ 6826.741038] amdgpu 0000:c1:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:173 vmid:0 pasid:0, for process  pid 0 thread  pid 0)
[ 6826.741040] amdgpu 0000:c1:00.0: amdgpu:   in page starting at address 0x0000000000000000 from client 10
[ 6826.741042] amdgpu 0000:c1:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
[ 6826.741043] amdgpu 0000:c1:00.0: amdgpu: 	 Faulty UTCL2 client ID: CB/DB (0x0)
[ 6826.741044] amdgpu 0000:c1:00.0: amdgpu: 	 MORE_FAULTS: 0x0
[ 6826.741045] amdgpu 0000:c1:00.0: amdgpu: 	 WALKER_ERROR: 0x0
[ 6826.741046] amdgpu 0000:c1:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x0
[ 6826.741047] amdgpu 0000:c1:00.0: amdgpu: 	 MAPPING_ERROR: 0x0
[ 6826.741048] amdgpu 0000:c1:00.0: amdgpu: 	 RW: 0x0
[ 6826.741051] amdgpu 0000:c1:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:157 vmid:0 pasid:0, for process  pid 0 thread  pid 0)
[ 6826.741052] amdgpu 0000:c1:00.0: amdgpu:   in page starting at address 0x0000000000000000 from client 10
[ 6826.741054] amdgpu 0000:c1:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
[ 6826.741055] amdgpu 0000:c1:00.0: amdgpu: 	 Faulty UTCL2 client ID: CB/DB (0x0)
[ 6826.741056] amdgpu 0000:c1:00.0: amdgpu: 	 MORE_FAULTS: 0x0
[ 6826.741057] amdgpu 0000:c1:00.0: amdgpu: 	 WALKER_ERROR: 0x0
[ 6826.741058] amdgpu 0000:c1:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x0
[ 6826.741059] amdgpu 0000:c1:00.0: amdgpu: 	 MAPPING_ERROR: 0x0
[ 6826.741060] amdgpu 0000:c1:00.0: amdgpu: 	 RW: 0x0
[ 6834.651357] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=924112, emitted seq=924114
[ 6834.651481] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 1004 thread Xorg:cs0 pid 1014
[ 6834.651570] amdgpu 0000:c1:00.0: amdgpu: GPU reset begin!
[ 6834.904633] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6834.904767] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.033447] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.033602] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.162310] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.162413] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.291086] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.291194] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.419848] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.419951] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.548552] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.548676] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.677375] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.677490] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.806246] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.806454] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6835.935287] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6835.935417] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6836.142734] [drm:gfx_v11_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
[ 6836.144261] amdgpu 0000:c1:00.0: amdgpu: MODE2 reset
[ 6836.152752] amdgpu 0000:c1:00.0: amdgpu: GPU reset succeeded, trying to resume
[ 6836.153413] [drm] PCIE GART of 512M enabled (table at 0x00000080FFD00000).
[ 6836.153562] amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
[ 6836.155203] amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
[ 6836.157192] [drm] DMUB hardware initialized: version=0x08000500
[ 6836.555161] [drm] kiq ring mec 3 pipe 1 q 0
[ 6836.558770] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 6836.559400] amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
[ 6836.561002] amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 6836.561004] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 6836.561006] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 6836.561007] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 6836.561008] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 6836.561009] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 6836.561011] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 6836.561012] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 6836.561013] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 6836.561014] amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 6836.561015] amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 6836.561016] amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[ 6836.561016] amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[ 6836.564124] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow start
[ 6836.564125] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow done
[ 6836.564148] [drm] Skip scheduling IBs!
[ 6836.564150] [drm] Skip scheduling IBs!
[ 6836.564151] [drm] Skip scheduling IBs!
[ 6836.564153] [drm] Skip scheduling IBs!
[ 6836.564154] [drm] Skip scheduling IBs!
[ 6836.564639] [drm] Skip scheduling IBs!
[ 6836.564644] [drm] Skip scheduling IBs!
[ 6836.564648] [drm] Skip scheduling IBs!
[ 6836.564652] [drm] Skip scheduling IBs!
[ 6836.564656] [drm] Skip scheduling IBs!
[ 6836.564659] [drm] Skip scheduling IBs!
[ 6836.564673] [drm] Skip scheduling IBs!
[ 6836.564675] [drm] Skip scheduling IBs!
[ 6836.566148] [drm] Skip scheduling IBs!
[ 6836.566150] [drm] Skip scheduling IBs!
[ 6836.566151] [drm] Skip scheduling IBs!
[ 6836.566153] [drm] Skip scheduling IBs!
[ 6836.566236] [drm] Skip scheduling IBs!
[ 6836.566237] [drm] Skip scheduling IBs!
[ 6836.570498] [drm] Skip scheduling IBs!
[ 6836.570501] [drm] Skip scheduling IBs!
[ 6836.581339] [drm] ring gfx_32785.1.1 was added
[ 6836.584166] [drm] ring compute_32785.2.2 was added
[ 6836.587094] [drm] ring sdma_32785.3.3 was added
[ 6836.606411] [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
[ 6836.803565] amdgpu 0000:c1:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx_32785.1.1 test failed (-110)
[ 6836.930881] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6836.930998] [drm:amdgpu_mes_remove_hw_queue [amdgpu]] *ERROR* failed to remove hardware queue, queue id = 1
[ 6837.057795] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6837.057917] [drm:amdgpu_mes_remove_hw_queue [amdgpu]] *ERROR* failed to remove hardware queue, queue id = 2
[ 6837.184953] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6837.185077] [drm:amdgpu_mes_remove_hw_queue [amdgpu]] *ERROR* failed to remove hardware queue, queue id = 3
[ 6837.185369] amdgpu 0000:c1:00.0: amdgpu: GPU reset(4) succeeded!
[ 6837.378515] Lockdown: Xorg: raw io port access is restricted; see man kernel_lockdown.7
[ 6837.582581] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[ 6837.582700] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[ 6837.709867] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[ 6837.709971] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[ 6838.808073] amdgpu 0000:c1:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:157 vmid:0 pasid:0, for process  pid 0 thread  pid 0)
[ 6838.808081] amdgpu 0000:c1:00.0: amdgpu:   in page starting at address 0x0000000000000000 from client 10
[ 6838.808083] amdgpu 0000:c1:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000B3B
[ 6838.808085] amdgpu 0000:c1:00.0: amdgpu: 	 Faulty UTCL2 client ID: CPC (0x5)
[ 6838.808087] amdgpu 0000:c1:00.0: amdgpu: 	 MORE_FAULTS: 0x1
[ 6838.808088] amdgpu 0000:c1:00.0: amdgpu: 	 WALKER_ERROR: 0x5
[ 6838.808089] amdgpu 0000:c1:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x3
[ 6838.808090] amdgpu 0000:c1:00.0: amdgpu: 	 MAPPING_ERROR: 0x1
[ 6838.808091] amdgpu 0000:c1:00.0: amdgpu: 	 RW: 0x0
[ 6838.808095] amdgpu 0000:c1:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:173 vmid:0 pasid:0, for process  pid 0 thread  pid 0)
[ 6838.808097] amdgpu 0000:c1:00.0: amdgpu:   in page starting at address 0x0000000000000000 from client 10
[ 6838.808099] amdgpu 0000:c1:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
[ 6838.808100] amdgpu 0000:c1:00.0: amdgpu: 	 Faulty UTCL2 client ID: CB/DB (0x0)
[ 6838.808101] amdgpu 0000:c1:00.0: amdgpu: 	 MORE_FAULTS: 0x0
[ 6838.808102] amdgpu 0000:c1:00.0: amdgpu: 	 WALKER_ERROR: 0x0
[ 6838.808103] amdgpu 0000:c1:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x0
[ 6838.808104] amdgpu 0000:c1:00.0: amdgpu: 	 MAPPING_ERROR: 0x0
[ 6838.808105] amdgpu 0000:c1:00.0: amdgpu: 	 RW: 0x0
[ 6838.808108] amdgpu 0000:c1:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:157 vmid:0 pasid:0, for process  pid 0 thread  pid 0)
[ 6838.808110] amdgpu 0000:c1:00.0: amdgpu:   in page starting at address 0x0000000000000000 from client 10
[ 6838.808111] amdgpu 0000:c1:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
[ 6838.808112] amdgpu 0000:c1:00.0: amdgpu: 	 Faulty UTCL2 client ID: CB/DB (0x0)
[ 6838.808113] amdgpu 0000:c1:00.0: amdgpu: 	 MORE_FAULTS: 0x0
[ 6838.808114] amdgpu 0000:c1:00.0: amdgpu: 	 WALKER_ERROR: 0x0
[ 6838.808115] amdgpu 0000:c1:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x0
[ 6838.808116] amdgpu 0000:c1:00.0: amdgpu: 	 MAPPING_ERROR: 0x0
[ 6838.808117] amdgpu 0000:c1:00.0: amdgpu: 	 RW: 0x0
[ 6846.683477] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=924179, emitted seq=924182
[ 6846.683601] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process  pid 0 thread  pid 0
[ 6846.683690] amdgpu 0000:c1:00.0: amdgpu: GPU reset begin!
[ 6846.817093] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6846.817215] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6846.946120] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6846.946217] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6847.075152] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6847.075247] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6847.204194] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6847.204287] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6847.333267] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6847.333378] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6847.462354] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6847.462447] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6847.591427] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6847.591531] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6847.720514] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6847.720623] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6847.849605] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=3
[ 6847.849712] [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
[ 6848.056887] [drm:gfx_v11_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
[ 6848.058379] amdgpu 0000:c1:00.0: amdgpu: MODE2 reset
[ 6848.068167] amdgpu 0000:c1:00.0: amdgpu: GPU reset succeeded, trying to resume
[ 6848.068852] [drm] PCIE GART of 512M enabled (table at 0x00000080FFD00000).
[ 6848.068891] amdgpu 0000:c1:00.0: amdgpu: SMU is resuming...
[ 6848.070465] amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
[ 6848.072455] [drm] DMUB hardware initialized: version=0x08000500
[ 6848.082862] [drm] kiq ring mec 3 pipe 1 q 0
[ 6848.084491] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 6848.084595] amdgpu 0000:c1:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
[ 6848.085040] amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 6848.085042] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 6848.085043] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 6848.085044] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 6848.085045] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 6848.085046] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 6848.085047] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 6848.085048] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 6848.085049] amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 6848.085050] amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 6848.085051] amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 6848.085052] amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[ 6848.085053] amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[ 6848.087108] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow start
[ 6848.087109] amdgpu 0000:c1:00.0: amdgpu: recover vram bo from shadow done
[ 6848.090732] [drm] ring gfx_32770.1.1 was added
[ 6848.091552] [drm] ring compute_32770.2.2 was added
[ 6848.092442] [drm] ring sdma_32770.3.3 was added
[ 6848.092463] [drm] ring gfx_32770.1.1 ib test pass
[ 6848.092482] [drm] ring compute_32770.2.2 ib test pass
[ 6848.092717] [drm] ring sdma_32770.3.3 ib test pass
[ 6848.093771] amdgpu 0000:c1:00.0: amdgpu: GPU reset(6) succeeded!
[ 6858.450096] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6868.689756] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6878.929987] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6889.169988] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6899.409649] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6909.649396] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6919.889277] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6930.129331] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
[ 6940.369606] [drm:amdgpu_dm_process_dmub_aux_transfer_sync [amdgpu]] *ERROR* wait_for_completion_timeout timeout!
FWIW, I only run Xorg, I’ve been using it with my Framework 13 AMD since late November (Bios 3.03, distro is Gentoo, WM is fluxbox) without issue. I also use Firefox, which is one of the two apparently-initiating processes that crashed for you above, and I have most certainly been using VAAPI accelerated video rendering from Firefox (that was one of the prime things I wanted out of this hardware refresh vs. my old system!) Both those logs appear to be kicked off with “illegal register access” errors. It definitely seems like other people are having similar problems to yours, though: gfx_v10_0_priv_reg_irq [amdgpu] *ERROR* Illegal register access in command stream (#2451) · Issues · drm / amd · GitLab
My kernel and all my drivers are built from recent source (that’s the nature of Gentoo), and might be significantly newer than your LTS build. It probably won’t be helpful unless you’re planning to go out of your way to (re)build and see if that fixes the problem, but my current versions for reference are:
  • 6.6.13 for the kernel
  • 23.3.5 for Mesa
  • 21.1.11 for xorg-server
  • 23.0.0 for the amdgpu xorg driver
  • 20240220 for linux-firmware
  • 20240115 for linux-firmware (I have not, in fact, rebuilt my initramfs and rebooted since the 20th)
[Edit to add: I also use Remmina heavily and daily during the workweek on this system.]
