I don’t think a BIOS update will fix your problem. This looks like a hardware problem to me, especially as a previous version of the BIOS didn’t fix it.
Have been doing a bit more experimenting. It seems to be something screwed up with the EC or its firmware. It doesn’t reset across reboots for some reason and doesnt respond to commands, but manually resetting it fixes the rear usb port. Reflashing the BIOS also resets the EC so that may have been why that worked lol
So I set up a task in Windows to restart the EC on shutdown or restart and now the port has no issues across shutdowns and restarts. My best guess is that it’s the AMD PD issue I’ve seen people complaining about OR faulty EC chip firmware. I have been wrong before though so take it with a grain of salt. I’ll have to see if anything changes over the next couple of days.
Per my discussion with Framework support, these are related to PD/EC issues with AMD that should be fixed with an upcoming BIOS update. And it seems to be global across all AMD boards, even Framework Desktop.
So, downgrading the BIOS to a previous version won’t fix it, but there may seem like a placebo effect at first.
The temporary fix, as I discovered, is fully shutting down the laptop, leave it off for a few minutes, and then power it back on while it is NOT plugged in to the power adapter. This seems to temporarily fix whatever issue disables the USB-C port in the first place.
As another update, I recently experienced this same issue with Port 4 (which I typically use to power my laptop). Turned it on one day, and then noticed a few hours later that the battery was drained to under 20%! I plugged the power adapter into Port 1 instead, and it started charging again. While in this state, nothing plugged into Port 4 was detected. Powering it off, waiting a few minutes, and powered back on while unplugged from power, and Port 4 worked again.
A firmware update is planned for December for both the Ryzen 7040 series and AI 300 series to fix/workaround the PD issues that have been affecting port 5 on the 7040 series and ports 4 & 5 on the AI 300 series.
I’ve asked for clarification if this will also address the Graphics Module USB-C port, since it seems to be a similar (if not identical) problem.
A beta for firmware 4.02 for the AI 300 series has been released, which includes a fix for the PD issues on both the side USB-C ports and the Graphics Module USB-C port.
With this, this problem may finally be fixed… I hope!
