Rubber feet grip
Hi all,
Got my Framework laptop last week and it’s an amazing machine. The only annoyance for me is that the material used for the rubber feet is quite hard, and the grip on them is quite poor.
I use a wooden tray with a cushion attached on the bottom for my lap, and it has been great with previous laptops with softer feet, but Framework laptop tends to slide around on it, due to a combination of the lightness of the laptop, lack of grip on the feet, and the fact that the cushion tray angle changes depending on how I sit.
Does anyone have some ideas to increase the grip of the rubber feet?
Thanks @anon81945988 those are solid suggestions. I did think of sticking some thin rubber layer on the feet, or exchanging the feet altogether, but for some reason I did not think of adding a few softer aftermarket feet alongside the originals. That should work as long as they are a little bit thicker than the originals, and I still keep the original feet, which is a good idea as I think the quality of those 3rd party feet can be hit-or-miss, and they might disintegrate in a week if I’m unlucky. In any case, it’s worth a try to order some and try.
For a less permanent solution (or at least no permanent changes to the laptop), maybe lay a sheet of something like this on the tray?
https://www.homedepot.com/p/Con-Tact-Grip-Premium-12-in-x-4-ft-Almond-Color-Non-Adhesive-Thick-Grip-Drawer-and-Shelf-Liner-6-Rolls-04F-C6L54-06/304467277
Yep, that’s how I understood it - adding another set of (softer) feet alongside the existing ones.
As for adding a non-slip sheet on the tray surface - that should work in this case, but I would really prefer the laptop itself to be more grippy. Even though it’s not much of a problem on a flat tabletop, I still feel that it slides around a bit too easily even on a level surface.
The feet are actually plastic coated in rubber. They’re attached to the bottom frame by the kind of “sonically welded” plastic rivets. There’s no restoring them if you pop them off.
There are these though. Universal laptop rubber feet compatible with all laptops - Gecky Feet
They’re taller than the Framework feet. You could place them right next to them though.
Good thing I didn’t then. They did seem suspiciously well attached when I tried to lift the side of one.
I actually ordered a set of these yesterday.
Hi guys,
I was wondering if anyone swapped out the laptop feet for thicker ones to lift the laptop slightly further off the desk?
I was thinking propping up the laptop when it is under load for better cooling (maybe a slim foldable one), but this might be something to explore first.
Thanks!
Guess I will prop it up with maybe some erasers or something.
What you might want to consider is this:
Instead of swapping out, you just stick a 2-3mm flexible sponge / foam sheet cut out that covers the three current feet with double-sided adhesive tape.
Something like 3mm EPE foam sheets.
I was looking at something more portable (a slightly thicker feet should be okayish I think). Else a foldable stand so I can bring it along wherever I go.
