Is anyone else experiencing very hot temps with minimal/no load under Fedora 36 while plugged in?
I noticed that when I’m plugged in the fans are almost always spinning and the ACPI sensor is reporting pretty high temps: 57C when idle, sometimes briefly jumping to 100C when loading a web page !!!. CPU cores are looking a little better, varying between 44C to 49C when idle and 55-65C when doing any sort of work. I already tried re-pasting with Kryonaut thermal paste twice but it makes no difference… The only way I can get the ACPI sensor to drop below 50C (hovering around 47C) is by running on battery with TLP set to max out at 60% CPU performance “CPU_MAX_PERF_ON_BAT=60”
Not sure about the program you are using here.
But it shows that two users are logged in. So maybe try to just log in a single user and see how the system behaves.
The “Load average: 0.60” means 60% load? Seems a lot to me for an idle system.
Which programs are you using to improve battery life?
E.g. TLP and auto-cpufreq are not playing nicely with each other.
Which Fedora performance profile are you using?
I just installed F36 on my 12th gen yesterday and my cpu is sitting at around 41°C while browsing / configuring the system, while having two external monitors connected and about 26°C ambient. No tlp, cpu-autofreq, powertop installed so far.
I am the only logged in user.
Not sure what an idle process “running hard at idle” means but here’s what top is showing.
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
9114 gmas 20 0 2894640 195060 104452 S 5.6 0.6 1:11.35 Isolated Web Co
2518 gmas 20 0 2099548 207268 160252 S 4.6 0.6 0:52.31 kwin_wayland
6872 gmas 20 0 44.5g 348536 94540 S 2.8 1.1 1:16.03 slack
5569 gmas 20 0 1125.2g 295396 113152 S 2.2 0.9 0:42.99 brave
3840 gmas 20 0 1145524 84960 48676 S 1.8 0.3 0:02.70 alacritty
491 root -51 0 0 0 0 S 1.0 0.0 0:05.06 irq/134-PIXA3854:00
4159 gmas 20 0 4215444 653816 243016 S 0.6 2.0 2:10.24 firefox
5072 gmas 20 0 32.9g 479940 211684 S 0.6 1.5 0:43.09 brave
2644 gmas 20 0 5245884 350036 176280 S 0.4 1.1 0:16.35 plasmashell
2719 gmas 20 0 456036 30352 26248 S 0.4 0.1 0:05.10 ksystemstats
6748 gmas 20 0 36.6g 170952 122532 S 0.4 0.5 0:09.63 slack
7779 gmas 20 0 2864052 184860 104596 S 0.4 0.6 0:07.66 Isolated Web Container
The load average of 0.60 means that 60% of one CPU core (out of 8) is being used, which can absolutely be considered idle. I only use TLP with intel_pstate, never used auto-cpufreq.
Comparison values from EndeavourOS + Plasma + X11:
I am loaded between 0.5 and 0.7 with web browsing (albeit nearly 3 digit numbers of tabs open facepalm), and sensors report CPU temps between 45 and 49C.
Are you on an 11th or 12th gen mainboard?
Although the CPU loading looks low, I wonder if the GPU is more in use due to Wayland issues? Try switching from Wayland to X11?
You can use powertop or powerstat to give you more information on what’s going on with your system at idle. I’d recommend using a LiveUSB distro (doesn’t really matter which, Ubuntu, Mint, Arch, etc) to see if you’re getting the same temps on other distros.
I don’t think your situation can be typical. In my testing, my 12th gen running Arch idles at about +3C over ambient.
