RX 7600 XT as an eGPU on TB3 enclosure for on a Framework 16 Lappie
Ha s anyone been able to get the following commination to work on Laptop 16
RX 7600 XT as an eGPU on RAZOR CORE X TB3 enclosure
What is your Question? Do you already own this Setup and have Trouble or do you want to buy it?
And if you don’t already have the Enclosure please don’t use it. Its just using 22gbps Bandwith and thats a serious Throttle.
The ADT-Link UT3G or UT4G is the best performing one and its USB4 which works perfect with the Laptop 16 as i use it with my RX9070XT.
How much performance do you lost by using it as an eGPU? (I’m quite disappointed with the performance of the RX 7700S), there is this eGPU enclosure: AOOSTAR AG02 EGPU with build-in PSU, it seems a good option too.
I loose about 10-30% Performance depending on the game. Every Game is above 60fps. But you feel the Bottleneck when CPU and GPU just use about 80% Usage and mainly the GPU hovers below 200w. Than its bottlenecking due to the USB Bandwith. The aoostar is still using the old thunderbolt chipset. So it will be more performance loss.
The rx6800xt i used before lost less Overall Performance it was capping at 15% performance loss.
