RZ717 Wifi card
I just upgraded from Intel 11th gen to AMD 7840u. I kept the AX210 Wi-Fi card from the Intel build and Wi-Fi works fine but bluetooth is broken.
Is this expected? Should I switch to an AMD Wi-Fi model to get bluetooth back? Will the RZ717 work with the 7840u?
I’m running Ubuntu 24.04
Bluetooth works on ax210 and AMD cpu just fine. Often what is required is to un-pair and re-pair the devices as the radio device address is hardcoded to the physical radio.
