Samsung drops new drive the 990 Pro
I didn’t see that anyone posted about the new Samsung drive that dropped a few days ago. My new Framework is currently shipping to me and wanted to run the 980 Pro, When I went to buy from Samsung direct I saw the new 990 was out for preorder. I I ordered it. Sadly it won’t be here until late in the month, so I won’t be able to use my brand new 1280P until later, unless I get my hands on another drive before 990 arrives. Which may happen, I may borrow a older nvme in the meantime. I didn’t get it for the faster speed, It’s also supposed to have less power usage. We will see.
Specs page
Order page
https://www.samsung.com/us/computing/memory-storage/solid-state-drives/990-pro-pcie-4-0-nvme-ssd-2tb-mz-v9p2t0b-am/
If you care about battery runtime on the go…this isn’t the upgrade. (P41 is still better)
For desktop replacement use cases, this is awesome.
Thanks @Second_Coming. I’m not a heavy tech user and a lot of this is new to me. I don’t really care a lot about battery usage as I’m sure I’ll be on power most of the time or at the very least very close to a power. But I did think it would help. I do like Samsung products and that is why I wanted to go with them, and I get a military discount. That helps. :smile:
So I guess I’ll just get the newest Samsung drive to have the newest drive. Seem for me it’s always the other way around. As soon as I buy the latest and greatest, it’s replace a few days later. LOL
Has anybody gotten the drive yet?
It claims to be up to 50% more energy efficient than the 980, which sounds really good.
I have this drive. I’ve had it running for about a month now. But I honestly don’t know how to measure it’s efficiency. I was running another drive for a few weeks while waiting on this one. My daily use is usually plugged in and I haven’t done any testing to know if there is a difference. I also don’t know even how to test this.
So just to clarify: You are not using any acpi, aspm or nvme-kernel-bootargs in order to use the drive? This drive does not automatically disconnect every once in a while and remount as read-only?
Welp, I don’t know what most of that means. :laughing: so no, I’m not. I’m running Win11 and drivers. I installed the drive, installed windows and it just works. I’ve had no issues so far. Samsung Magician works fine and reports everything is ok.
Any comment @Gunner?
Hmm, thanks for the heads up, I’ll keep an eye on it. The screen shot above was taken just before I posted. I looked all through magician and couldn’t find a % usage anywhere. if I’m missing where it’s at let me know. I downloaded the Crystal Disc info and here is what I got. It’s a fresh download so I don’t know if that skews anything but I looks like it tracks pretty well to my usage. I’m not a hard user and rarely shut down my PC. When I’m done for the day I put my computer into hibernate so I don’t have to reload everything the next day. Not sure if any of this info help.
@Gunner how is it going?
I’ve ordered a 990 Pro myself, because the WD SN770 1TB one still disconnects every once in a while and I believe my NVME drive to be faulty.
There is a yet to be fixed firmware issue with the 990 Pro where the drive health is going down fast.
I’m not sure if there is real damage going on or misreporting of drive health but I would avoid using one till a fix is released and validated.
@Usernames did you actually check the comment 3 posts above yours?
It seems like while it affects many drives, not all are and especially the 2TB variants are more affected than the 1TB (I got the 1TB one).
Since I’m running one myself right now and smartctl returns:
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.9_1] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       Samsung SSD 990 PRO 1TB
Firmware Version:                   0B2QJXD7
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Total NVM Capacity:                 1.000.204.886.016 [1,00 TB]
Unallocated NVM Capacity:           0
Controller ID:                      1
NVMe Version:                       2.0
Number of Namespaces:               1
Namespace 1 Size/Capacity:          1.000.204.886.016 [1,00 TB]
Namespace 1 Utilization:            946.511.945.728 [946 GB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            002538 4a2140e122
Local Time is:                      Tue Feb  7 12:25:26 2023 CET
Firmware Updates (0x16):            3 Slots, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x0055):     Comp DS_Mngmt Sav/Sel_Feat Timestmp
Log Page Attributes (0x2f):         S/H_per_NS Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg *Other*
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     82 Celsius
Critical Comp. Temp. Threshold:     85 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     9.39W       -        -    0  0  0  0        0       0
 1 +     9.39W       -        -    1  1  1  1        0     200
 2 +     9.39W       -        -    2  2  2  2        0    1000
 3 -   0.0400W       -        -    3  3  3  3     2000    1200
 4 -   0.0050W       -        -    4  4  4  4      500    9500
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        42 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    0%
Data Units Read:                    24.341 [12,4 GB]
Data Units Written:                 2.160.528 [1,10 TB]
Host Read Commands:                 2.309.825
Host Write Commands:                8.593.815
Controller Busy Time:               11
Power Cycles:                       29
Power On Hours:                     5
Unsafe Shutdowns:                   12
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               42 Celsius
Temperature Sensor 2:               50 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
@Usernames While I would agree that I would hold off on buying one until they get it figured out, it would be the right move. If you don’t own one yet why are you so worried. Just wait until they figure it out or go buy another drive.
I preordered mine and of course none of this was going on. I’m stuck with what I have and I’m not gong to throw it away and get a new drive because of internet reports. If it fails early it fails, I’ll get another drive. It’s damn near the cheapest part of your whole computer, thought still top price for a NVME. But as I mentioned above, I have the 2TB model and I’m not see anything bad with my drive. It just works and the drive is still at 100% health per Crystal disk.
Samsung Magician just updated, I haven’t looked at the notes to see what the update was but I just did it yesterday. Magician shows my drive health is good. Magician does not give a %, at least not that I have found.
Here are my up to date test results.
Yeah I overlooked that.
Not worried, just trying to spread useful info.
I have the 2TB 990 Pro, only been running it a couple of weeks so YMMV
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-58-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Model Number: Samsung SSD 990 PRO 2TB
Serial Number: ****************************
Total NVM Capacity: 2,000,398,934,016 [2.00 TB]
Controller ID: 1
NVMe Version: 2.0
Namespace 1 Size/Capacity: 2,000,398,934,016 [2.00 TB]
Namespace 1 Utilization: 120,555,687,936 [120 GB]
Namespace 1 IEEE EUI-64: 002538 4c21406bd4
Local Time is: Wed Feb 8 13:31:40 2023 EST
Log Page Attributes (0x2f): S/H_per_NS Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg Other
0 + 512 0 0
Temperature: 34 Celsius
Percentage Used: 0%
Data Units Read: 180,327 [92.3 GB]
Data Units Written: 572,972 [293 GB]
Host Read Commands: 1,798,994
Host Write Commands: 5,953,179
Controller Busy Time: 66
Power Cycles: 16
Power On Hours: 8
Unsafe Shutdowns: 1
Temperature Sensor 1: 34 Celsius
Temperature Sensor 2: 34 Celsius
No Errors Logged
People suggested this SSD isn’t great on battery life. Now that it’s been a few months - How is it?
I don’t think I can Farley answer this, I run almost exclusive wired.
I have no baseline to compare the energy consumption to, no help there.
All I can offer is an update/snapshot of my usage from smartmontools, if anyone is still gun-shy about picking up the 990P
Temperature: 39 Celsius
Percentage Used: 0%
Data Units Read: 9,437,853 [4.83 TB]
Data Units Written: 10,887,623 [5.57 TB]
Host Read Commands: 70,576,872
Host Write Commands: 43,921,657
Controller Busy Time: 541
Power Cycles: 93
Power On Hours: 58
Unsafe Shutdowns: 11
Temperature Sensor 1: 39 Celsius
Temperature Sensor 2: 43 Celsius
No Errors Logged
Moderate virtual machine use
smartctl Information about WD SN770 1 TB
while comparing with data mentioned from aboe for Samsung 990 pro
