Screen Flicker below control bar
Hi!
First post here, so I hope I choose the right category.
I have a FW 13 with Fedora, running KDE Plasma. Overall, the experience is great. However, I have one visually annoying bug: below the control bar, on the bottom of the screen, there is some screen flickering going on. The screen flickering stays at the bottom of the screen if I remove the control bar.
As I have no idea if this is a KDE bug, a hardware issue or has something to do with display configuration, I’d be happy if you could point me in the right direction.
It’s barley visible in the photo, but I hope you get the idea. (it is visible in a video, but apparently, you can’t upload these)
Which Linux distro are you using? Fedora KDE Plasma
Which release version? 42
Which kernel are you using? 6.15.6-200.fc42.x86_64 (64-bit)
Which BIOS version are you using? 3.9
Which Framework Laptop 13 model are you using? AMD Ryzen™ 7040 Series
