I have the AMD-ai-300 mainboard and a 1TB SSD. The assembly instructions ( Framework Laptop 13 Pro DIY Edition Quick Start Guide - Framework Guides ) say to not remove the thermal pad from the mainboard but there is no thermalpad on the mainboard (or on the SSD). Is this intentional, or an assembly error?
It wouldn’t make much sense to have a thermal pad on the mainboard, since this would heat up the mainboard for no reason.
Mine didn’t come with the Pad either. I think the Pad comes only with Gen 5 PCIe slots (on Intel Core 3 series). I run a Kioxia Gen5 SSD and had no problems so far.
And concerning the sense I think it’s to take the heat from the small SSD to the larger surface of the mainboard more directly because the mainboard would be heated up anyway from the SSD but the heat not taken away efficiently because there’s not that much airflow between.
This is probably a documentation error between the two board types. The AMD boards did not have them in the 13 models because they are not necessary. The 16 boards do have them though. Could add one if someone wanted to though it is not critical with the 13 AMD boards.
