[SOLVED] Any audio crackles on Fedora 42 (kernel 6.14.3)
I am experiencing strong inconsistent sound crackling from any audio source, independently of the sound reproduction hardware—I tested both with wired headphones, Bluetooth headphones, and the laptop’s speakers.
Any ideas? Is anyone experiencing the same issue?
Hardware Information:
  • Hardware Model: Framework Laptop 13 AMD Ryzen 7040Series
  • Memory: 32.0 GiB
  • Processor: AMD Ryzen™ 7 7840U w/ Radeon™ 780M Graphics × 16
  • Graphics: AMD Radeon™ 780M
  • Disk Capacity: 1.0 TB
Software Information:
  • Firmware Version: 03.07
  • OS Name: Fedora Linux 42 (Workstation Edition)
  • OS Build: (null)
  • OS Type: 64-bit
  • GNOME Version: 48
  • Windowing System: Wayland
  • Kernel Version: Linux 6.14.3-300.fc42.x86_64
Nevermind, the suggestions that automatically pop up after filling in a support request seem to have done the job:
sudo dnf reinstall pipewire
sudo dnf reinstall alsa-lib alsa-utils
systemctl --user restart wireplumber pipewire pipewire-pulse
