Hello everyone,
I use a UW monitor via USB-C (rear right connection) on my Frame.Work 16”.
This is used to charge the notebook and transmit video and audio to the monitor. I have installed Fedora 40 silverblue and the sound keeps dropping out for 1-4 seconds.
System:
Kernel: 6.8.8-300.fc40.x86_64 arch: x86_64 bits: 64 compiler: gcc
v: 2.41-34.fc40
Desktop: GNOME v: 46.1 Distro: Fedora Linux 40.20240509.0 (Silverblue)
Machine:
Type: Laptop System: Framework product: Laptop 16 (AMD Ryzen 7040 Series)
v: AG serial: <superuser required>
Mobo: Framework model: FRANMZCP07 v: A7 serial: <superuser required>
UEFI: INSYDE v: 03.03 date: 03/27/2024
Battery:
ID-1: BAT1 charge: 87.3 Wh (100.0%) condition: 87.3/85.1 Wh (102.5%)
volts: 17.7 min: 15.5 model: NVT FRANDBA status: discharging
Device-1: hid-18:7e:b9:67:f4:86-battery model: Tealk-Magic Trackpad 2
charge: N/A status: discharging
CPU:
Info: 8-core model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 rev: 1 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
Speed (MHz): avg: 716 high: 3147
min/max: 400/5137:5293:5449:6080:5764:5924:5608 cores: 1: 400 2: 400 3: 1322
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 1793 12: 400 13: 400
14: 400 15: 400 16: 3147 bogomips: 121373
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: Framework driver: amdgpu v: kernel arch: RDNA-3 bus-ID: 03:00.0
Device-2: AMD Phoenix1 vendor: Framework driver: amdgpu v: kernel
arch: RDNA-3 bus-ID: c4:00.0 temp: 45.0 C
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB bus-ID: 5-1.1.4.1:6
Display: wayland server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: dri: radeonsi gpu: amdgpu resolution:
1: 3440x1440~100Hz 2: 2048x1280~165Hz
API: OpenGL v: 4.6 vendor: amd mesa v: 24.0.6 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi gfx1103_r1 LLVM
18.1.1 DRM 3.57 6.8.8-300.fc40.x86_64)
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Audio:
Device-1: AMD Navi 31 HDMI/DP Audio vendor: Framework driver: snd_hda_intel
v: kernel bus-ID: 03:00.1
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Framework
driver: snd_hda_intel v: kernel bus-ID: c4:00.1
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Framework
driver: snd_pci_ps v: kernel bus-ID: c4:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Framework
driver: snd_hda_intel v: kernel bus-ID: c4:00.6
Device-5: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
Device-6: Beyerdynamic FOX driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 5-1.1.4.3:7
API: ALSA v: k6.8.8-300.fc40.x86_64 status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Network:
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Bluetooth:
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB
bus-ID: 1-5:7
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Drives:
Local Storage: total: 1.82 TiB used: 120.26 GiB (6.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN770 1TB
size: 931.51 GiB temp: 41.9 C
ID-2: /dev/sda vendor: Seagate model: UltraTouch SSD size: 931.51 GiB
type: USB
Partition:
ID-1: /boot size: 973.4 MiB used: 148 MiB (15.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 598.8 MiB used: 12.4 MiB (2.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /var size: 929.91 GiB used: 72.68 GiB (7.8%) fs: btrfs
dev: /dev/dm-0 mapped: luks-91874fa2-dc37-4bd0-aee8-c4a03dee90d0
Swap:
ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: N/A device: amdgpu temp: 38.0 C fan: 0
Info:
Memory: total: 32 GiB note: est. available: 30.65 GiB used: 7.17 GiB (23.4%)
Processes: 522 Uptime: 2m Init: systemd target: graphical (5)
Packages: 67 Compilers: N/A Shell: Bash v: 5.2.26 inxi: 3.3.34
