Hello community,
I just upgraded my laptop from a ryzen 7040 to ryzen ai mainboard a couple of days ago and all seemed to be working fine. However, I noticed that the audio is crackling after waking up from standby. Rebooting solves the issue. The issue did not exist with the ryzen 7040 mainboard.
Which Linux distro are you using? Fedora 43, all up to date
Which kernel are you using? 6.18.5-200
Which BIOS version are you using? 03.04
Which Framework Laptop 13 model are you using? Ryzen AI 370 HX
Steps:
- use laptop
- close lid for a couple of seconds
- open lid
- start audio, e.g. youtube video, mp3, system sounds
Symptoms:
audio interrupts every 0.5 to 1 second, cracklng/popping
Workaround:
reboot
What I tried:
- Un-/reinstalling pipewire/pipewire-pulseaudio/pipewire-alsa based on this topic, no success.
- Disabling the real time canary based on this topic, no success
Any ideas what might go wrong and how to solve this? Thanks a lot!
