[SOLVED] Debian 12 / F13 11th gen sound not working
After upgrading from Debian 11 bullseys to 12 bookworm, my sound stopped working.
lspci | grep Audio
00:1f.3 Audio device: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller (rev 20)
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC295 Analog [ALC295 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
pavucontrol
Shows no devices detected except Dummy Output.
Hi @Mike_Baysek ,
welcome to the forums, by the way Have you tried booting Debian bookworm live image, to check and compare if behavior persist?
Hi @Loell_Framework .
I took this advice and the sound worked on the LiveCD with XFCE, which is the environment I use.
It’s a relief that it just has to be some configuration issue, but I’m still trying to pin it down. Any tips are appreciated.
This is solved now. Must have been something funky about the upgrade from Bullseye to Bookworm:
Installed pipewire-audio-client-libraries
systemctl --user restart wireplumber pipewire pipewire-pulse
After reboot, the machine had sound again.
@Loell_Framework this should be marked as [SOLVED]
Thanks, Marking now. :slight_smile:
