Hi,
Laptop 13 11th Gen Intel Mainboard in Cooler Master Case
running Debian 13/Trixie with Gnome
connected to a Samsung Smart TV via HDMI
Any ideas why sound output via HDMI is silent?
Sound briefly worked a few days ago, but unfortunately I don’t know what changed or how to reproduce that.
TV and HDMI cable are probably ok, as playback via my Ryzen Laptop 13 works.
I do not see any relevant error messages in journal.
Thank you!
$ inxi --basic --audio --graphics
System:
Host: … Kernel: 6.12.10-amd64 arch: x86_64 bits: 64
Console: pty pts/2 Distro: Debian GNU/Linux trixie/sid
Machine:
Type: Laptop System: Framework product: Laptop v: AA serial: <superuser required>
Mobo: Framework model: FRANBMCP0A v: AA serial: <superuser required> UEFI: INSYDE v: 03.20
date: …/2024
CPU:
Info: quad core 11th Gen Intel Core i5-1135G7 [MT MCP] speed (MHz): avg: 1283 min/max: 400/4200
Graphics:
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Display: unspecified server: Xwayland v: 24.1.4 driver: gpu: i915 tty: 141x47
resolution: 3840x2160
API: EGL Message: EGL data unavailable in console, eglinfo missing.
Info: Tools: x11: xrandr
Audio:
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
API: ALSA v: k6.12.10-amd64 status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active
Network:
Message: No PCI device data found.
Drives:
Local Storage: total: 3.64 TiB used: 6.68 GiB (0.2%)
Info:
Memory: total: 16 GiB note: est. available: 15.41 GiB used: 3.09 GiB (20.1%)
Processes: 290 Uptime: 3m Init: systemd Shell: Bash inxi: 3.3.37
$ dpkg -s firmware-sof-signed | grep Version
Version: 2024.09.2-1
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: 92HD95 Analog [92HD95 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [SAMSUNG]
Subdevices: 0/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
$ wpctl status
PipeWire 'pipewire-0' [1.2.7, …]
└─ Clients:
33. WirePlumber [1.2.7, …, pid:799]
34. pipewire [1.2.7, …, pid:800]
43. gnome-shell [1.2.7, …, pid:918]
47. WirePlumber [export] [1.2.7, …, pid:799]
56. GNOME Shell Volume Control [1.2.7, …, pid:918]
57. GNOME Volume Control Media Keys [1.2.7, …, pid:1058]
58. xdg-desktop-portal [1.2.7, …, pid:1335]
59. Firefox [1.2.7, …, pid:1104]
65. PulseAudio Volume Control [1.2.7, …, pid:2409]
85. wpctl [1.2.7, …, pid:2859]
Audio
├─ Devices:
│ 48. Built-in Audio [alsa]
├─ Sinks:
│ * 55. Built-in Audio Digital Stereo (HDMI) [vol: 0.94]
├─ Sources:
├─ Filters:
└─ Streams:
35. Firefox
62. output_FL > SAMSUNG:playback_FL [active]
79. output_FR > SAMSUNG:playback_FR [active]
66. PulseAudio Volume Control
68. input_FL < SAMSUNG:monitor_FL [active]
69. monitor_FL
70. input_FR < SAMSUNG:monitor_FR [active]
71. monitor_FR
67. PulseAudio Volume Control
74. input_FL
75. monitor_FL
76. input_FR
77. monitor_FR
78. PulseAudio Volume Control
63. input_FL < Firefox:output_FL [active]
80. monitor_FL
81. input_FR < Firefox:output_FR [active]
82. monitor_FR
Video
├─ Devices:
├─ Sinks:
├─ Sources:
├─ Filters:
└─ Streams:
Settings
└─ Default Configured Devices:
0. Audio/Sink alsa_output.pci-0000_00_1f.3.hdmi-stereo
$ pw-cli info 55
permissions: rwxm-
type: PipeWire:Interface:Node/3
* input ports: 2/65
* output ports: 2/0
* state: "running"
* properties:
* alsa.card = "0"
* alsa.card_name = "HDA Intel PCH"
* alsa.class = "generic"
* alsa.components = "HDA:111d7695,f1110001,00100101 HDA:80862812,80860101,00100000"
* alsa.device = "3"
* alsa.driver_name = "snd_hda_intel"
* alsa.id = "HDMI 0"
* alsa.long_card_name = "HDA Intel PCH at 0x605d1c8000 irq 194"
* alsa.mixer_name = "IDT 92HD95"
* alsa.name = "SAMSUNG"
* alsa.resolution_bits = "16"
* alsa.subclass = "generic-mix"
* alsa.subdevice = "0"
* alsa.subdevice_name = "subdevice #0"
* alsa.sync.id = "00000000:00000000:00000000:00000000"
* api.alsa.card.longname = "HDA Intel PCH at 0x605d1c8000 irq 194"
* api.alsa.card.name = "HDA Intel PCH"
* api.alsa.path = "hdmi:0"
* api.alsa.pcm.card = "0"
* api.alsa.pcm.stream = "playback"
* audio.channels = "2"
* audio.position = "FL,FR"
* card.profile.device = "8"
* device.api = "alsa"
* device.class = "sound"
* device.id = "48"
* device.profile.description = "Digital Stereo (HDMI)"
* device.profile.name = "hdmi-stereo"
* device.routes = "1"
* factory.name = "api.alsa.pcm.sink"
* media.class = "Audio/Sink"
* node.description = "Built-in Audio Digital Stereo (HDMI)"
* node.name = "alsa_output.pci-0000_00_1f.3.hdmi-stereo"
* node.nick = "SAMSUNG"
* node.pause-on-idle = "false"
* object.path = "alsa:acp:PCH:8:playback"
* port.group = "playback"
* priority.driver = "696"
* priority.session = "696"
* factory.id = "19"
* clock.quantum-limit = "8192"
* client.id = "47"
* node.driver = "true"
* node.loop.name = "data-loop.0"
* library.name = "audioconvert/libspa-audioconvert"
* object.id = "55"
* object.serial = "66"
* node.max-latency = "16384/48000"
* api.alsa.period-size = "1024"
* api.alsa.period-num = "32"
* api.alsa.headroom = "0"
* params: (9)
* 3 (Spa:Enum:ParamId:EnumFormat) r-
* 1 (Spa:Enum:ParamId:PropInfo) r-
* 2 (Spa:Enum:ParamId:Props) rw
* 4 (Spa:Enum:ParamId:Format) rw
* 10 (Spa:Enum:ParamId:EnumPortConfig) r-
* 11 (Spa:Enum:ParamId:PortConfig) rw
* 15 (Spa:Enum:ParamId:Latency) rw
* 16 (Spa:Enum:ParamId:ProcessLatency) rw
* 17 (Spa:Enum:ParamId:Tag) rw
Edit 1: alsa’s speaker-test does not show any errors:
$ speaker-test -D hdmi:CARD=PCH,DEV=0 -c 2
speaker-test 1.2.13
Playback device is hdmi:CARD=PCH,DEV=0
Stream parameters are 48000Hz, S16_LE, 2 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 524288
Period size range from 32 to 262144
Periods = 4
was set period_size = 12000
was set buffer_size = 48000
0 - Front Left
1 - Front Right
Time per period = 5.000615
0 - Front Left
1 - Front Right
Kernel option snd-intel-dspcfg.dsp_driver=3 or snd-intel-dspcfg.dsp_driver=1 did not fix the issue (suggested here in 2023: [RESOLVED] No Audio via HDMI - #15 by WERRY_Brice)
Edit 2: No audio board installed.
Edit 3: Likely duplicate of [TRACKING] Audio over HDMI on Ubuntu not working on 11th gen Intel Framework Audio via HDMI works after waking up from suspend (but is silent after reboot) ![]()
