[SOLVED] Framework 13 bezel connection issue and ssd question
Hi guys, I am new to Framework and just received my laptop 13. It is going to run Linux Mint XFCE when the RAM cards come and is in the Intel ultra series one generation of CPUs. I think it looks very sleek and I love it, but when I was assembling the bezel, I noticed that it didn’t completely snap into the bottom of the chassis, and when I tried to open the laptop again(no input cover installed at this point), and one side of the bezel, the one side that didn’t completely connect to the chassis got caught and snagged on some of the interior(pictures will hopefully explain this), and when it happened I tried to fix the bezel that had come apart with some superglue, but when I go to open and close it, even if I have the input cover installed, it still snags and the bezel bends. Should I look into buying a replacement bezel for my laptop, or what can I do? Unrelated, but the SSD I bought for this laptop is an Adata legend 860, and it comes with an adhesive heatsink. I was wondering if I could attach it to the SSD and it would still fit within the laptop? Either way I appreciate any help received.
You should reach out to Support about your bezel!
Actually nevermind, I got it fixed. Bezel still has superglue on it, but it fits into place now. I had to route one of the cables properly.
