Fingerprint Sensor repeatedly reporting update
I’m encountering an issue where the OS reports that the fingerprint sensor is updated on every system start. The GUI suggests that the fingerprint sensor still needs to update (attache screenshot). Clicking that button should show a change log, but it never completes downloading.
As far as I can tell, it’s the same issue as in this post which was never resolved.
Distributor ID: Ubuntu
Description: Ubuntu 24.04.3 LTS
Release: 24.04
Codename: noble
Framework Laptop 13 (AMD Ryzen 7040Series)
└─Fingerprint Sensor:
Device ID: 23ec719b6aabc2d2dac5176c232f0da7a21881b0
Summary: Match-On-Chip fingerprint sensor
Current version: 01000334
Vendor: Goodix (USB:0x27C6)
Install Duration: 10 seconds
Serial Number: UID734B6B17_XXXX_MOC_B0
GUID: 1e8c8470-a49c-571a-82fd-19c9fa32b8c3 ← USB\VID_27C6&PID_609C
Device Flags: • Updatable
• Supported on remote server
• Device stages updates
• Device can recover flash failures
• Signed Payload
I have the same issue
