OS: Linux
Framework 13 11th gen
Not sure if this has happened to anyone else, but today the laptop “blipped”.
At first I thought, I had run the battery to 0, which happens from time to time as the power was not connected. However, the power light was still on, which was unusual.
The machine was unresponsive, so I rebooted. There was a green light on boot that I didn’t notice before. Ever since then, the speed has been very slow. Booting has taken 5-10 minutes. Emacs has taken 86 seconds to load. Not normal.
I’m not sure where to start debugging this. Did something happen to the disk? Did something happen to the motherboard? I’m considering buying another disk tomorrow.
I have a SK Hynix Gold 1TB and here are the current hdparm results. Does anyone have any hdparm results for comparison?
$ sudo hdparm -tT /dev/nvme0n1
/dev/nvme0n1:
Timing cached reads: 1824 MB in 2.00 seconds = 913.57 MB/sec
Timing buffered disk reads: 914 MB in 3.00 seconds = 304.41 MB/sec
$ sudo hdparm -tT --direct /dev/nvme0n1
/dev/nvme0n1:
Timing O_DIRECT cached reads: 1980 MB in 2.00 seconds = 991.83 MB/sec
Timing O_DIRECT disk reads: 3192 MB in 3.00 seconds = 1064.00 MB/sec
$ sudo nvme list
Node Generic SN Model Namespace Usage Format FW Rev
/dev/nvme0n1 /dev/ng0n1 AS12T000710102J18 SHGP31-1000GM-2 1 1.00 TB / 1.00 TB 512 B + 0 B 41061C20
$ sudo nvme smart-log /dev/nvme0n1
Smart Log for NVME device:nvme0n1 namespace-id:ffffffff
critical_warning : 0
temperature : 48°C (321 Kelvin)
available_spare : 100%
available_spare_threshold : 10%
percentage_used : 0%
endurance group critical warning summary: 0
Data Units Read : 2,840,256 (1.45 TB)
Data Units Written : 7,748,319 (3.97 TB)
host_read_commands : 34,864,625
host_write_commands : 191,313,748
controller_busy_time : 191
power_cycles : 187
power_on_hours : 14,089
unsafe_shutdowns : 100
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 41°C (314 Kelvin)
Temperature Sensor 2 : 46°C (319 Kelvin)
Thermal Management T1 Trans Count : 0
Thermal Management T2 Trans Count : 0
Thermal Management T1 Total Time : 0
Thermal Management T2 Total Time : 0
$ sudo nvme self-test /dev/nvme0n1 --self-test-code 1h
Device Self Test Log for NVME device:nvme0n1
Current operation : 0
Current Completion : 0%
Self Test Result[0]:
Operation Result : 0
Self Test Code : 1
Valid Diagnostic Information : 0
Power on hours (POH) : 0x3709
Vendor Specific : 0 0
Self Test Result[1]:
Operation Result : 0xf
Self Test Result[2]:
Self Test Result[3]:
Self Test Result[4]:
Self Test Result[5]:
Self Test Result[6]:
