Disk Performance Severely Impacted when on Battery (vs AC)
Framework 13 DIY Intel 11th Gen i5-1135G7, BIOS 03.17
Computer feels really sluggish on battery power. I was able to show that Disk speed (Samsung SSD 980 PRO 1TB) in particular is noticeably impacted:
On Battery Power:
sudo hdparm -Tt /dev/nvme0n1p2
/dev/nvme0n1p2:
 Timing cached reads:   1828 MB in  2.00 seconds = 914.97 MB/sec
 Timing buffered disk reads: 832 MB in  3.01 seconds = 276.39 MB/sec
On AC Power:
/dev/nvme0n1p2:
 Timing cached reads:   30862 MB in  2.00 seconds = 15452.98 MB/sec
 Timing buffered disk reads: 4312 MB in  3.00 seconds = 1436.76 MB/sec
Things I’ve ruled out:
  • CPU temps (I manually set the Fan to 80%, and confirmed that Temps are very low)
sudo fw-ectool temps all
--sensor name -------- temperature -------- ratio (fan_off and fan_max) --
F75303_Local          305 K (= 32 C)           0% (313 K and 335 K)
F75303_CPU            305 K (= 32 C)           0% (313 K and 342 K)
F75303_DDR            304 K (= 31 C)           0% (313 K and 335 K)
Battery               304 K (= 31 C)           0% (313 K and 323 K)
PECI                  310 K (= 37 C)           0% (377 K and 378 K)
  • Memory usage
free -m
               total        used        free      shared  buff/cache   available
Mem:           31885        7469       21944        1517        4449       24415
Swap:          32767           0       32767
Here are some diagnostics on the battery:
upower -i /org/freedesktop/UPower/devices/battery_BAT1
  native-path:          BAT1
  vendor:               NVT
  model:                Framewo
  serial:               0109
  power supply:         yes
  updated:              Thu 22 Feb 2024 12:33:42 PM EST (8 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               charging
    warning-level:       none
    energy:              45.5532 Wh
    energy-empty:        0 Wh
    energy-full:         46.9238 Wh
    energy-full-design:  55.0088 Wh
    energy-rate:         4.5122 W
    voltage:             17.392 V
    charge-cycles:       195
    time to full:        18.2 minutes
    percentage:          97%
    capacity:            85.3024%
    technology:          lithium-ion
    icon-name:          'battery-full-charging-symbolic'
  History (charge):
    1708623192	97.000	charging
  History (rate):
    1708623222	4.512	charging
    1708623192	4.558	charging
    1708623169	4.605	charging
    1708623139	4.635	charging
Look into apst, likely something on your system limits the max power state of your ssd on battery (which may be a reasonable thing to do to improve battery life).
Maybe, but that is extreme. That is 15+ times lower read throughput rates for buffers (RAM) here, and the disks are on spinning disk levels.
But to be honest, 1400MB/s is kinda slow.
@Steven_McClain Did you do these in singleuser mode?
In BIOS settings there’s a setting called PCIE Dynamic Link Power Management, it’s said to reduce PCIE speed when on battery, disable it and see if that works.
Well, it reduces it to PCIe gen3 speed levels if I read it well.
Just make sure nothing else runs when you do the test.
