I’ve already triggered the lockout once, so am keen to increase this!
I can see that on Windows (bitlocker w/ TPM+PIN) the TPM lockout is configurable - so there must be a way to increase this from the OS - but my searching so far has not helped find a solution. I’ve not found a way to change this in the BIOS either.
If anyone knows how to do this, I’d be really grateful for any pointers!
The command above sets the lockout period to 600 seconds (10 mins), and increases the number of permitted attempts to 10.
I think the ‘dictionary’ term was throwing me off (isn’t it a lockout to protect against all brute force attacks, not just dictionary?) but it definitely seems to be the right way to do it.
