❯ fwupdmgr enable-remote lvfs-testing
║ Enable new remote? ║
║ The LVFS is a free service that operates as an independent legal entity and ║
║ has no connection with Pop!_OS. Your distributor may not have verified any ║
║ of the firmware updates for compatibility with your system or connected ║
║ devices. All firmware is provided only by the original equipment ║
║ manufacturer. ║
║ This remote contains firmware which is not embargoed, but is still being ║
║ tested by the hardware vendor. You should ensure you have a way to manually ║
║ downgrade the firmware if the firmware update fails. ║
║ Enabling this functionality is done at your own risk, which means you have ║
║ to contact your original equipment manufacturer regarding any problems ║
║ caused by these updates. Only problems with the update process itself ║
║ should be filed at https://github.com/pop-os/pop/issues. ║
Agree and enable the remote? [Y|n]: y
Authenticating… [ \ ]
Do you want to refresh this remote now? (Requires internet connection) [Y|n]: y
Downloading… [***************************************]
Successfully enabled and refreshed remote
❯ sudo fwupdmgr update
[sudo] password for mark:
No updatable devices
❯ sudo dmidecode -s bios-version
03.10
And p.: Today the option has returned:
Devices with no available firmware updates:
• UEFI Device Firmware
• WDS100T1X0E-00AFY0
║ Upgrade System Firmware from 0.0.3.16 to 0.0.3.17? ║
║ Due to an incompatibility between our BIOS and recent versions of fwupdmgr ║
║ please set DisableCapsuleUpdateOnDisk=true in /etc/fwupd/uefi_capsule.conf ║
║ before applying this update. ║
║ Updating the BIOS firmware will erase NVRAM boot variables. Press F3 during ║
║ boot to manually select a desired boot entry after the update has completed ║
║ if you run into this issue. ║
║ Changes in this release ║
║ • Add setup menu option in advanced tab to enable standalone operation ║
║ mode. This will modify onboard LED behavior to skip presence checks for ║
║ chassis open, display, battery and C cover. ║
║ • Change low battery power LED behavior from red to white. ║
║ Fixes in this release ║
║ • Improve battery life when HDMI/DP expansion cards are attached but no ║
║ display is connected. ║
║ • Add support for Capsule on Disk for future updates to improve LVFS ║
║ compatibility. ║
║ • Fix pressing F12 key during boot will system hang when BIOS quiet boot ║
║ is disabled. ║
║ • Correct BIOS setup item TPM availability missing word. ║
║ Laptop must remain plugged into a power source for the duration of the ║
║ update to avoid damage. ║
Perform operation? [Y|n]:
Without me doing anything. So it must have been either pop_os or lvfs I guess… Updating now.
After enabling lvfs-testing, a manual refresh operation would have pulled the new BIOS option right away. In your case, it auto-refreshed at some point later.
