As a Developer I use some keys like Pos1, End, PageUp, PageDown, Print (for Screenshots), all F Keys on a daily basis. They are available on the main keyboard. But they often require a two hand key combination with fn on the left and cursor on the right. Using the F Keys as a primary, the media keys are harder to reach.
I don’t use the num pad to keep my keys in the middle of the laptop. So I have two spacer sized places available. It would be nice to have an additional column of keys, with some space to the main key board, on each side. Or two rows.
I would like to have on the right side from top to bottom print, pos1, pageUp, pageDown, end, contextMenu, and on the left side: more brightness, less brightness, louder, quiter, mute, keyboard brightness.
My current laptop has a very similar key column on the right.
The rgb Macropad doesn’t work for me. It moves the main keyboard to a side and the keys have a different style.
