SSD drive and RAM compatibility for Framework 13
SSD drive and RAM compatibility (moved here)
Hi,
I want to know if Framework laptop 13 will support this
Corsair 64GB (2x32GB) CMK64GX5M2B5600Z40 Vengeance CL40 5600MHz DDR5 RAM Corsair 64GB (2x32GB) CMK64GX5M2B5600Z40 Vengeance CL40 5600MHz DDR5 RAM - msy.com.au
Kingston 4TB NV2 M.2 NVMe SSD Kingston 4TB NV2 M.2 NVMe SSD - msy.com.au
Please advise
Thank you
That Corsair is full size DIMMs, not SO-DIMMs. They wouldn’t even fit physically in a Framework.
NV2 is a standard 2280 NVMe drive, so I assume it’ll work fine. But I personally never tried it, so I can’t say for sure.
Hi,
Thank you for your reply.
Can you please check if these RAMs will work?
Crucial 64GB (2x32GB) CT2K32G48C40S5 4800MHz SODIMM DDR5 RAM Crucial 64GB (2x32GB) CT2K32G48C40S5 4800MHz SODIMM DDR5 RAM - msy.com.au
Silicon Power 64GB (2x32GB) SP064GBSVU480F22 4800Mhz CL40 DDR5 SODIMM Laptop RAM Silicon Power 64GB (2x32GB) SP064GBSVU480F22 4800Mhz CL40 DDR5 SODIMM Laptop RAM - msy.com.au
I intend to buy Framework laptop 13 AMD Ryzen™ 7 7840U Batch 10 and using Ubuntu as operating system.
Please advise
Thank you
Though those are proper DDR5 SODIMMs, look for 5600 MHz SODIMMs.
Take a look at Memory compatibility FW 13 AMD Ryzen™ 7040U series DDR5-SODIMM-5600MT/s
