Hey everyone. Long time Linux user and been running Manjaro as my primary OS for work for years. I just got a new laptop and decided to make it closer to Arch by installing EndeavourOS. So far it looks great and feels great but I have not been able to get SteamVR running. Every time I run it, a few seconds into starting up I am provided error 109 and that the headset is not communicating with the laptop. When I look at KDE display manager, it is not detecting the headset no matter what I do. I tried to disable direct output in SteamVR developers menu and that isn’t working. Others on reddit and other forums say that if doing that step and it doesn’t work then there is a hardware issue on the headset or the cable is bad. However, the headset works perfectly on my old laptop running windows. I think it is a driver issue and I am not sure how to proceed.
When installing Steam, a prompt asked which driver to use and I used the default recommended for amdvlk - so not sure if I made a mistake here. Also, I have enabled proton support for my entire library but I am not seeing anything around that for error 109.
I have the framework 16 with the dedicated 7700s card. When looking down at it, I am using the left frontmost expansion slot for USB, the left middle slot for display port, and a Valve Index. According to the specs the middle slot supports DP out and the front slot supports USB speeds of 3.2 which should be fine for this. I have also tried using a DP to TB3 cable (what I have to use on my Windows laptop as it doesn’t have a DP out) in the furthest back left side slot which should support everything.
Steam VR shows communications with the headset just not as a display. I have also tried both X11 and Wayland, and get the same error on both.
Any help would be great and hopefully someone knows a quick fix for this.
I did not know that, I thought it was routed to the the top two ports with display. But I guess that makes sense. I’ll try that and see if it was just me not knowing and that would make me feel way better
Those ports and one of the middle ports can do DP alt mode but that’s through the GPU in the CPU (or APU I believe is what AMD calls it). It doesn’t run through the 7700S.
This was the fix for it. It now starts but now I have to figure out how to use it. I have the issue some others have where menu’s load but you can’t see anything, but that is outside of FW’s stuff.
@Lupin - I will need to check when I can get it fully working. It started up now but still unplayable because I think I am missing some libraries.
So I tackled this a few weeks ago and had some success! Goal was to get Outer Wilds running in VR and I managed to do that, but then life hit and I haven’t been able to play for more than 30 minutes. I imagine you’ll want to do different things, so think of the following more as a clue than guide.
Setup: Steam Index, Tumbleweed, KDE (doesn’t work in Gnome), USB-C (on dGPU) → 8K DisplayPort adapter
Same error 109, and after a fair amount of research I finally landed on SteamVR is a steaming pile. In fact, I never got it to run.
The SteamVR room setup/calibration worked well enough, so start there (I knew I was onto something when the lights inside the headset turned on).
