Stylus suddenly stopped working
Which Linux distro are you using? Ubuntu
Which release version? 25.10
Which kernel are you using? Linux 6.17.0-6-generic
Which BIOS version are you using? 03.04
Which Framework Laptop 12 model are you using? (13th Gen Intel® Core™) Framework Laptop 12 13th Gen Intel Core
Apologies in advance for being such a novice. Yesterday morning my Lenovo Precison Pen 2 was working just fine on my Framework 12 running Ubuntu 25.10 and then in the afternoon it wasn’t able to write or otherwise work as a stylus. To try to fix this all I could find to do, which I did, was
  1. charge the pen from a computer instead of a plug-in charger;
  2. change the protocol in the BIOS from MPP to USI and back again.
I also bought a Penoval USI 2.0 pen and set the BIOS to USI. This pen also doesn’t work.
I am able to use the touchscreen with my fingers.
The only diagnostics I can find to try are xinput and libinput debug-events. Using libinput showed nothing for the stylus in either case, but does for using my finger on the touchscreen. The output from xinput is below.
Thanks in advance,
Bruce
bruce@FW12:~$ xinput list
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ xwayland-pointer:16 id=6 [slave pointer (2)]
⎜ ↳ xwayland-relative-pointer:16 id=7 [slave pointer (2)]
⎜ ↳ xwayland-pointer-gestures:16 id=8 [slave pointer (2)]
⎜ ↳ xwayland-touch:16 id=10 [slave pointer (2)]
⎜ ↳ xwayland-tablet stylus:16 id=11 [slave pointer (2)]
⎜ ↳ xwayland-tablet eraser:16 id=12 [slave pointer (2)]
⎜ ↳ xwayland-tablet cursor:16 id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ xwayland-keyboard:16 id=9 [slave keyboard (3)]
