Swapping keycaps
I’m a fn-ctrl type, not the ctrl-fn that the Framework 12’s keyboard comes as. I see in the UEFI settings that I can swap them functionally, which meets 80% of the need. That other 20% is making the labeling reflect reality.
Is it possible to swap the keycaps?
Hi Colin! The FMWK laptop keycaps aren’t meant to be removed individually.
On Framework Laptop 13, I saw someone had swapped the keycaps unofficially.
Another solution is using keycap stickers. For example, you may choose the gray color and the position of the symbols from the page and order.
You can also check other stickers from the link below.
List of company or individually driven projects - Keyboard
The stickers are a great idea! Takes the risk of breaking a key out. :slight_smile:
+1 on a swapping feature, I did this trying out different keymappings on an old macbook and thought that the fw12 would be easy to swap as well as I now wanted to try out colemak.
