System Updates
Is there a way to be automatically notified of BIOS and other system updates?
Thanks, but is there a way to sign up to be notified of a BIOS update or is it up to each customer to repeatedly check the Framework page? Also, there were a number of driver updates that I found on the Framework site that were not part of the normal system update - is it the same process of repeatedly checking the site?
Did you look at the knowledgebase page that has no version numbers or anything else to give you a hint that anything has changed for your hardware?
Did you search for a thread with no replies from two years ago?
How about semi-related threads with no resolution?
Well, then why do you care? It doesn’t change that often.
It isn’t a bug, it is a feature.
Whoa, whoa, take a look at the Community Guidelines!
Please treat people with respect, and this applies to everybody.
