Techdraw for Expansion Card
I m thinking of making my own Expansion cards, and with the Data on the Github i cant rally visualize and plan because i have no real dimensions to work of. The modules im thinking of designing are a origami Ethernet Port like fujitsu (Low profile ethernet expansion card (maybe) - #30 by Daniel-L) and something like the DongleHider (DongleHider+ - Multiple dongles and a normal USB A socket) that also has a combo audio jack.
If someone has a Techdraw of the Expansion Cards or the Framework Team can update the Github it would be much appreciated.
And sorry if it sounds rude, English is my second Language.
We have 2D drawings of the PCBA along with 3D CAD here: ExpansionCards/Mechanical at main · FrameworkComputer/ExpansionCards · GitHub
You can take measurements off of the CAD. In practice for 3D printing that should be sufficient since the critical dimensions won’t really hold anyway.
Thank you for your quick reply, After 2 hours of CAD tinkering i am almost finished withe my own CAD file for FreeCad, of wich i can make a Techdraw. The only 1 Problem i have, is the Openscad file from Github an enclosure without a 0.2 mm Aluminum lid?
Sorry it took such a long time to release but University stress and me wanting to release a prototype module of a origami Ethernet Port (fujitsu) Expansion card took far longer than imagined. The prototype is going to take much longer because of space constraints and difficulty finding the right parts. This is also my first electronics Project.
