I tried an eGPU on the fw12, I have an i3,32Gb Ram, 1Tb AddLink NVMe. I did not run any benchmarks, the results are mostly subjective.
For the eGPU I used an m.2 2230 to PCIe x16 slot(Chenyang Oculink SFF-8612 £35 ~$50), with an oculink cable inbetween
GPU: 1080ti
PSU: 350W BeQuiet!
Storage: 256Gb Expansion Card
OS: Bazzite
Monitor: 3440x1440 (21:9)
I tested 3 games:
Star Wars BattleFront 2 - Graphics were able to run much better, but the CPU just not seem to be able to handle the game, it suffers from cumulating input lag until it fully locks up
Just Cause 4 - Big improvement in graphics, 40-50fps 1920x800, however I would get random hangs where the game would just lock up.
Supreme Commander 2 - Runs well I at 1920x800 no issues with it
During the tests powerstat reported CPU power usage 50W
The nice thing was it just worked, albeit with the top cover off.
I do wonder if it’s possible to run a cable internally to the rear middle, cutting a hole between the fan openings to create a permanent Oculink port. Of course it would only work while the screen is folded back, but it could be a nice permanent solution.
It’s not really possible to have a “non diy” setup without opening or modifying the computer as the 12 has no usb4 or any other form of externally exposed pcie.
You could stream games from a different computer if that counts as a workaround but that’s about it.
I don’t know what you are going to use an eGPU for, but I assume it is either for content creation or playing video games. Both highly favor multi-channel memory, especially gaming.
Yeah, but that is also not the same as two concurrent streams of data transfer.
That is important. Like for example, the secret sauce for the Steam Deck APU is 4x channel memory (for heavy iGPU usage, I know, but nevertheless).
Whatever you do with an eGPU, I bet you would get significantly higher performance on the same device and same amount of RAM just switching to dual channel.
Also, as was noted, the Laptop 12 doesn’t have USB4 or Thunderbolt 4, so running an eGPU without opening it up and sacrificing an M.2 SSD slot is impossible, save for the lack of hot plugging.
All I am trying to do is to say that if any person chooses the Laptop 12, they would not get a pleasant experience using an eGPU and keep using it as a completely assembled portable device. Which is the direct answer to the question I tried to answer.
TL;DR
If you want to buy the Laptop 12 to actively use it with an eGPU, I would recommend literally anything else that has USB4 / Thunderbolt (with 4x PCIe lanes) instead, like the Laptop 13.
That is just normal dual channel lpddr5 (with ddr5 they split each previously 64bit channel into 2 32bit ones) so with that way of counting the fw12 is already dual channel. But counting each dimm as 2 channels is kinda stupid so almost noone does it.
Given the fw12 ended up being too expensive to really fit the cheap segment them not even putting one usb4 port on the thing seems like a sub-obtimal choice. But I suppose the 12 has plenty of those (unfortunate keyboard matrix, no backlight even as an option…). If they wanted the super entry level option they could allways have added it to the much more expensive i5 model and not to the i3 one so they could keep the price floor but well that ship has sailed.
