I’m using a Framework laptop with Ubuntu Budgie 21.10. Having some difficulty at the moment setting TLP config to enable battery charge start and stop thresholds - I enter the details into /etc/tlp.conf and then run tlp start, but the following output comes from tlp-stat -b:
--- TLP 1.5.0 --------------------------------------------
+++ Battery Care
Plugin: generic
Supported features: none available
+++ Battery Status: BAT1
/sys/class/power_supply/BAT1/manufacturer = NVT
/sys/class/power_supply/BAT1/model_name = Framewo
/sys/class/power_supply/BAT1/cycle_count = 0 (or not supported)
/sys/class/power_supply/BAT1/charge_full_design = 3572 [mAh]
/sys/class/power_supply/BAT1/charge_full = 3328 [mAh]
/sys/class/power_supply/BAT1/charge_now = 2662 [mAh]
/sys/class/power_supply/BAT1/current_now = 583 [mA]
/sys/class/power_supply/BAT1/status = Discharging
/sys/class/power_supply/BAT1/charge_control_start_threshold = (not available)
/sys/class/power_supply/BAT1/charge_control_end_threshold = (not available)
Charge = 80.0 [%]
Capacity = 93.2 [%]
No matter what the values entered in the config file, nothing changes - and tlp setcharge results in this: Error: battery charge thresholds not available.
From the number of other posts in here where users are using TLP, it seems probable that this isn’t a question of incompatible hardware. What am I missing? Can anyone help me work this one out?
