Track pad keeps double clicking (and holding in some cases) when im only touching with 1 finger!
Fedora 44 KDE
Which kernel are you using?
7.2.10-200.fc44.x86_64 (64-bit)
Which Framework Laptop 13 model are you using? x7 358H 13 pro
So issue started probably last week but I’ve had this laptop for about a week. When using the haptic touchpad of the framework 13 pro sometimes it triggers a two finger touch (right click) instead of a one finger even when my palm is elevated and only my index is touching the darn thing.
- Is this a known issue?
- Can it be fixed on my part?
- Is it a hardware issue?
My friend also recently got his 13 pro and claims similar behavior when he thinks he is just fat fingering it, when really he isn’t.
Do you have a Mouse & Trackpad Settings screen in Fedora, and would you take a screenshot of it and post it here? Some distros have palm rejection settings - we might as well see all of your settings in one go.
Sure here you go!
OK, great stuff. If it was me, I’d try the live CD for a different distro, maybe Ubuntu. I think one could test it without an install i.e. just pop it onto a memory stick.
Just to add another data point, I’m running into the same issues with my 13 pro on Debian.
