[TRACKING] Battery flipping between charging and discharging / Draws from battery even on AC
It’s bounced through several local models - and validated, yes, but the logic is sound. I am aware the FW13 doesn’t draw that under NORMAL conditions it’s a potential hypothetical worst case load. Strix can have it’s TLP fiddled relatively easily i.e via smokeless. Matrices are there to illustrate behaviour.
Regards the 5V ‘not supported’ there is nothing inherent other than EC policy stopping 5V sources from charging the F13, and it’s fully supported by the ISL9241. The FW16 is a question mark on this front and will depend on if UVLO is enabled on the Buck Boost IC or not, information I don’t have. For the FW13 tho it’s pure policy.
@jwp
You will actually need to test your theory. I.e. make your changes to the firmware and see if they actually fix a problem for you.
I have no idea if it will help or not.
Last night I tested using 11000 and 12000 input current values while gaming on my FW 16, and a miraculous thing happened… my device just worked! It would pull between 0-2W from the battery every once in a while to top up, but on average it was running entirely on AC power and pulling a steady 215W. Both 11k and 12k input currents seemed to cap out at about 215W draw, but I’m pretty sure that’s just because that’s how much power it needed.
If I didn’t also have a 180W PSU that I used sometimes, I would configure KDE to auto execute the ectool command on plug-in, but oh well. I’ll just run it manually as I don’t want to forget about a 240W override when I’m plugging in a 180W adapter, or some other random charger.
Thank you so much for the help guys! I’ve spent the last 2 months tinkering with and trying to get my Framework to work the way I want, and now that I have… I gotta remember what it was I was doing before that started lol.
@Kieran_Levin
You mentioned that the current sense resistor might not be accurate, thus the 85% limit being applied by the EC.
Would you be able to tell us the component part number for the current sense resistors used in the FW13 and FW16, so that we can improve our measurements.
For more than 10A current, using resistor is not a good way because of the waste power and the added voltage drop (the latter makes the battery to drain even when the load is not maxed), the use of hall effect sensors is highly recommended.
using a value lower than 100% assumes that the tolerance is downward, i.e. actual resistance is lower, this leads to higher actual current at a given sensed current.
However, real world testing concludes that this is not the case.
I think I’m in the same boat as many others here and have a problem related to battery power management. Yesterday, I played Shadow of the Tomb Raider for a while, and after 25-30 minutes, the laptop started throttling extremely (sound crackling, FPS dropping below 10 frames per second, the whole system becoming extremely slow). After I managed to shut down the laptop and restart it a few minutes later, the problem persisted. Even testing the RAM takes up to a minute instead of a few seconds.
The problem first occurred when I set up the device with Windows to check the hardware for errors. Under FurMark, the entire system slowed down, and at first, I thought it was overheating. However, the temperatures only reached a maximum of 85°C on the CPU and GPU/VRAM.
… Something else I’ve noticed with Manjaro, which I’m now using instead of Windows, is that when I plug in the power adapter (240W USB-C charger), the laptop switches between charging and AC power every second. This is indicated by the LED flashing on and off. If I unplug the adapter and wait a moment, everything is usually fine.
What do I need to do to change this behavior? I have the Framework 16 with RX7700S GPU module.
FYI upower regressed again in 2026, the battery symbol alternates between battery and battery with AC plug symbol when charged to the set limit
Thanks! Not happening on my Arch system but I haven’t updated everything for a while. I’ll hold off on update upower then.
Let me add what I’ve experienced for completeness’ sake.
My config:
  • OS: Gentoo Linux
  • Machine: Framework 13 with 7840U CPU
  • UEFI: Latest firmware as provided to me through the stable channel of LVFS.
  • Bought in Januari 2024. Have been running for 2 years without any issue.
Started encountering this for the first time today, after I had my latop unplugged for a little under 2 hours, wherein my battery charge dropped to 77%.
Then after it charged back up, the cycling started with the battery at 100%. It also doesn’t matter if the system is under load, even with all cores at 100%, it still cycles.
  • Power supply always present according to /sys/class/power_supply/ACAD/uevent
  • LED near charge port never off, have always used the Framework 60W PSU that came with it.
  • Battery state toggles between: “Discharging” and “Not charging” as seen in /sys/class/power_supply/BAT1/uevent.
Don’t know if I have provided any new information with this (haven’t read the entire thread), but hopefully my “never having this problem for 2 years and it then suddenly appearing” is also useful info.
I would also like to add I did not do any updates in the past few weeks or so, so nothing should’ve changed programmatically about the system, which would lead me to believe the issue might at the very least be partially hardware related, or perhaps be influenced by battery age/condition.
Finally my machine is usually on/not-suspended and powered through USB-C. I have a tendency to use it more like a desktop than a laptop, except for it also being a desktop you can carry. Current uptime 15 days.
In case it’s of any interest to people here, I had ChatGPT make a small script that automatically detects the 180W / 240W chargers and then apply 100% rating input charge limit override. I’m a software engineer, and both tested the code and reviewed the code, in case anyone’s sensitive about not trusting the AI.
Just for the record and @Matt_Hartley - opening a support ticket doesn’t do anything. I’ve opened a ticket almost 2 months ago, and there has been 0 feedback from support
I didn’t have any fantasy that it was going to change anything. Coming to 5 years. A multi-generation issue… The talk about support ticket is just, IMO, BS at this point.
This needs action, result. …and there’s neither.
It’s almost like Burton with their Step On:
Leaving their community disappointed.
It would be interesting to hear if anyone else with the battery flip problem and an Intel 13gen updated to the 3.09 firmware and has similar issues as I have:
Ever since I updated, the battery status became almost useless. Reporting absolutely insane numbers in short bursts
I’ve done some experimentation with my FW 16 on using ectool to override that 90% limit, just to see if this would help me avoid battery drain (and it does). This seems to work fine on my unit for a short period of time, however after about 30-60 minutes or so (from memory) during heavy load, that override seems to become unstable and the safety cutoffs will kick in, resetting the connection to the PSU. This, I imagine, is not surprising to you (nor me). I suspect the fact that it’s stable for a period of time before that however may be related to some component on the board heating up and losing either efficiency or accuracy… but I am not an expert in power delivery.
Is there any chance that I might be able to stabilize a higher current by actively cooling a component that’s heating up? If so, would you be willing to help me identify that component on the FW 16 (7040HS) board?
For context regarding other misc. mods to my unit: https://community.frame.work/t/all-the-modifications-ive-made-to-my-fw-16-so-far/
The hysteresis loop by the battery extender update doesn’t fix the root cause. Despite chargecontrol being set to Charge mode = IDLE (1), the battery still gradually decrease even on sustained gaming load when using a 60W charger. Instead of flipping up and down between 79% to 80%, the new BIOS version just flip down only from 80% to 75%, then recharge to 80% before a new “cycle”.
As shown here
$ sudo ectool chargestate show
ac = 1
chg_voltage = 16584mV
chg_current = 0mA
chg_input_current = 2700mA
batt_state_of_charge = 80%
ac = 1
chg_voltage = 16464mV
chg_current = 0mA
batt_state_of_charge = 79%
ac = 1
chg_voltage = 16448mV
chg_current = 0mA
batt_state_of_charge = 78%
ac = 1
chg_voltage = 16336mV
chg_current = 0mA
batt_state_of_charge = 77%
ac = 1
chg_current = 0mA
chg_input_current = 0mA
batt_state_of_charge = 76%
Before charging again (voltage and current goes back to CC-CV 17.6V 2.74A)
ac = 1
chg_voltage = 17600mV
chg_current = 2740mA
The discharge duration is about an hour, and charging is about a few minutes after that.
So apparently, instead of blocking the battery charging circuit, the old BIOS just kept the chg_voltage to the battery’s current voltage, any fluctuation causes battery flipping. However in the newer BIOS with hysteresis, the battery BFET is apparently off so only discharging side of the “flip” can be done, but the chg_voltage still matches the battery voltage instead of setting to 17800mV.
Setting that higher would only get rid of the mini discharge blips from the battery changing it’s estimated soc but those are tiny and would never cause the 1H cycle.
The bulk of the discharge here are the big blips from the P3T power limit.
Has anyone experimented with changing P3T power limit?
How does behaviour change as a result?
Yes, me
I initially just implemented wetting it to the calculated charger value instead of that + 89W for the battery.
Setting it to less than 100W on a 100W charger eliminated the big big battery dips completely cb15 and cyberpunk built in benchmark being within margin of error of the stock 179W. Setting it to much less than the 89W caused measurable reduction in performance so I capped the bottom to that, it still mostly eliminated big battery dips on a 65W charger.
I don’t mind the battery dip under peak 53W (PL2/FPPT) load, but I’m wary about the constant battery dip/flip under sustained 35W(PL1/SPPT) or even 30W(SPL) load. Since when gaming the actual draw from the adapter is about 42-46W, less than 60WX0.9=54W, there shouldn’t be any sustained dip. With the latest BIOS, gaming on 60W no longer flip at 80%, but slowly discharges to 75% under an hour then charges back to 80% within 10 minutes.
Is there a good P3T power limit to allow dipping under FPPT but disallow SPPT dipping?
